    Curviloft (Beta) Plugin Tutorial
    45 Posts 21 Posters 58.8k Views 21 Watching
      czloser
      so cool
        jbrfrk
        thank u so much charle
        J=K
          tfdesign
          This is a great thread, but is anyone else experiencing problems with pages loading, supposedly because of the sheer amount of image files having to load? I'm finding this thread pretty slow to view. 😞
            robert111
            charly can you make tuot for this modeling with subdivide and smooth
            thanks charly
            • charly2008C Offline
              charly2008
              Hi Curviloft Fans,
              some CurviArt variations from a basic form.
              Charly
                jose-91
                very impressive. thanks for posting these examples!
                • brookefoxB Offline
                  brookefox
                  Thanks, Charly. I hope to tame the powerful beast with the insights you have shared, or at least not be consumed by it.
                  ~ Brooke
                    brookefox
                    When I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
                    ~ Brooke
                      lapx
                      Charly,
                      I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number?
                      also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this.
                      How can this be done? See attached skp file.
                      column.skp
                        Lapx
                        Is this the result you seek?
                        Select the three 'profiles' of edges and run CurviLoft.
                        The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form...
                          brookefox
                          The start point may not matter depending on the Vx setting.
                          Note the black previews which if I orbit during, causes the whole operation to be discarded.
                          The first pics show 1,2,3 from the bottom up.
                          Here from the top down.
                          ~ Brooke
                          • micioneM Offline
                            micione
                            Hi all,
                            Watching this tutorial, I found the window (red arrow) in the photo.
                            Does anybody know tell me the path to find it?
                            Thanks in advance
                            • micioneM Offline
                              micione
                              Sorry,
                              photo.
                                charly2008
                                Hi Roberto,
                                you will find it in the Tools menu.
                                Charly
                                • micioneM Offline
                                  micione
                                  Charly,
                                  Thank you very much.
                                  (I tried to send a private message, but evidently you have not received).
                                    ccs1987
                                    Awesome tutorials
                                    Sketchup 8 pro
                                    Vray
                                    Intel Xeon W3520 2.67Ghz
                                    12Gb Ram
                                    Nvdia Quadro FX 1800
                                    • LanaL Offline
                                      Lana
                                      Very good . I learned a lot here . Thank you all .
                                      • sketchartist023S Offline
                                        sketchartist023
                                        I have not been able to manipulate the GUI interface with this tool, so I am left with overlapping issues in my model 😕 I am not sure what to do, but wow this tool is amazing so far! My concept is taking a plane lettering and then using a half circle guide flow to reform it to a rectangle below the lettering facing the same direction. SO, just a morphed half loop from letter to poly. But always get overlapping and face issues since I cannot use the points on the GUI. I wish I could do this stuff above! Will keep trying 😄
                                          If you'd like help, upload an example SKP file so we can see what you are trying to do.
                                          • 2 / 3
