Curviloft (Beta) Plugin Tutorial
Hi Troy,
i used perpendicular faces along a perpendicular edge and scaled each individual face.
Charly
Nice. Thank. this is a great plug in for doing gothic details!
To clarify, Perpendicular faces is a plugin. Check it out here:
It is useful for things like this.
Hi Curviloft Friends,
here some different ideas.
Charly
Amazing stuff. I have a laughable question. Can you please tell me where I find the sub division options you have used at the start of your tutorial? I can`t seem to find it!
Guy
Hi Guy,
the subdivision is done automatically By Curviloft. The bending of the objects is done by orthogonal junction by Bezier curves. See Image below.
Charly
With simple geometric shapes can be created the most amazing ornaments. If, for example, useful for stucco.
Charly
Robert111 was asking for a Tutorial for this crown Object shown in the image below. The original model i deleted some weeks ago.
Draw some curves. Place some faces with the perpendicular faces plugin. scale each face as you want.
Connect all Faces with Curviloft and make it group. Copy and flip the copy and put it together and group it again and copy the new goup. The new group may now scaled if you want more thickness for example.
Rotate or flip the group to the z-direction and place it at a circle. Than make Rotate copy, that's all.
I have also made the edge with perpendicular faces and Curviloft.
Charly
thanks charly , you are very generous
Hi Pilou,
I didn't understand your english sentences not correct.
Charly
Maybe it's more clear like this
(click image if scroll bar)
It's a pity
we can use component for Curviloft
but alas Edit component don't make tranformations on the result
Or I miss something
Pilou,
I understood it still not likely. The Curviloft object is a new group. The two components remain as components. The Curviloft object you can edit and change. Or you explode all objects and then you can change the result as you want.
Charly
That is the problem
Imagine : you have your gem
Just edit the component (face) and you will have an infinities of variation without pain
But alas that is not possible
Here example with Component Stringer
I modify just the component and all is modified
and here with Curviloft
so cool
thank u so much charle
This is a great thread, but is anyone else experiencing problems with pages loading, supposedly because of the sheer amount of image files having to load? I'm finding this thread pretty slow to view.
charly can you make tuot for this modeling with subdivide and smooth
thanks charly
Hi Curviloft Fans,
some CurviArt variations from a basic form.
Charly
very impressive. thanks for posting these examples!
