    Curviloft (Beta) Plugin Tutorial
    45 Posts 21 Posters 60.0k Views 21 Watching
    • charly2008C Offline
      charly2008
      Hi Guy,
      the subdivision is done automatically By Curviloft. The bending of the objects is done by orthogonal junction by Bezier curves. See Image below.
      Charly
        charly2008
        With simple geometric shapes can be created the most amazing ornaments. If, for example, useful for stucco.
        Charly
        Curviloft99.skp
          charly2008
          Robert111 was asking for a Tutorial for this crown Object shown in the image below. The original model i deleted some weeks ago.
          Draw some curves. Place some faces with the perpendicular faces plugin. scale each face as you want.
          Connect all Faces with Curviloft and make it group. Copy and flip the copy and put it together and group it again and copy the new goup. The new group may now scaled if you want more thickness for example.
          Rotate or flip the group to the z-direction and place it at a circle. Than make Rotate copy, that's all.
          I have also made the edge with perpendicular faces and Curviloft.
          Charly
            robert111
            thanks charly , you are very generous
              charly2008
              Hi Pilou,
              I didn't understand your english sentences not correct.
              Charly
                Maybe it's more clear like this 😄
                (click image if scroll bar)
                  It's a pity
                  we can use component for Curviloft ☀
                  but alas Edit component don't make tranformations on the result 😮
                  Or I miss something 😉
                    charly2008
                    Pilou,
                    I understood it still not likely. The Curviloft object is a new group. The two components remain as components. The Curviloft object you can edit and change. Or you explode all objects and then you can change the result as you want.
                    Charly
                      That is the problem 😄
                      Imagine : you have your gem
                      Just edit the component (face) and you will have an infinities of variation without pain 😉
                      But alas that is not possible 😞
                      Here example with Component Stringer
                      I modify just the component and all is modified
                      and here with Curviloft
                        czloser
                        so cool
                          jbrfrk
                          thank u so much charle
                          J=K
                            tfdesign
                            This is a great thread, but is anyone else experiencing problems with pages loading, supposedly because of the sheer amount of image files having to load? I'm finding this thread pretty slow to view. 😞
                              robert111
                              charly can you make tuot for this modeling with subdivide and smooth
                              thanks charly
                                charly2008
                                Hi Curviloft Fans,
                                some CurviArt variations from a basic form.
                                Charly
                                  jose-91
                                  very impressive. thanks for posting these examples!
                                  • brookefoxB Offline
                                    brookefox
                                    Thanks, Charly. I hope to tame the powerful beast with the insights you have shared, or at least not be consumed by it.
                                    ~ Brooke
                                      brookefox
                                      When I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
                                      ~ Brooke
                                        lapx
                                        Charly,
                                        I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number?
                                        also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this.
                                        How can this be done? See attached skp file.
                                        column.skp
                                          Lapx
                                          Is this the result you seek?
                                          Select the three 'profiles' of edges and run CurviLoft.
                                          The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form...
                                            brookefox
                                            The start point may not matter depending on the Vx setting.
                                            Note the black previews which if I orbit during, causes the whole operation to be discarded.
                                            The first pics show 1,2,3 from the bottom up.
                                            Here from the top down.
                                            ~ Brooke
                                            • 2 / 3
