    Curviloft (Beta) Plugin Tutorial
    45 Posts 21 Posters 60.9k Views 21 Watching
      The Curviloft object is a new group. The two components remain as components.
      That is the problem 😄
      Imagine : you have your gem
      Just edit the component (face) and you will have an infinities of variation without pain 😉
      But alas that is not possible 😞
      Here example with Component Stringer
      I modify just the component and all is modified
      and here with Curviloft
      • C
        czloser
        so cool
          jbrfrk
          thank u so much charle
          J=K
          • T
            tfdesign
            This is a great thread, but is anyone else experiencing problems with pages loading, supposedly because of the sheer amount of image files having to load? I'm finding this thread pretty slow to view. 😞
              robert111
              charly can you make tuot for this modeling with subdivide and smooth
              thanks charly
              • charly2008C
                charly2008
                Hi Curviloft Fans,
                some CurviArt variations from a basic form.
                Charly
                  jose-91
                  very impressive. thanks for posting these examples!
                  • brookefoxB
                    brookefox
                    Thanks, Charly. I hope to tame the powerful beast with the insights you have shared, or at least not be consumed by it.
                    ~ Brooke
                    • brookefoxB
                      brookefox
                      When I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
                      ~ Brooke
                      • L
                        lapx
                        Charly,
                        I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number?
                        also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this.
                        How can this be done? See attached skp file.
                        column.skp
                          Lapx
                          Is this the result you seek?
                          Select the three 'profiles' of edges and run CurviLoft.
                          The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form...
                          • brookefoxB
                            brookefox
                            The start point may not matter depending on the Vx setting.
                            Note the black previews which if I orbit during, causes the whole operation to be discarded.
                            The first pics show 1,2,3 from the bottom up.
                            Here from the top down.
                            ~ Brooke
                            • micioneM
                              micione
                              Hi all,
                              Watching this tutorial, I found the window (red arrow) in the photo.
                              Does anybody know tell me the path to find it?
                              Thanks in advance
                              • micioneM
                                micione
                                Sorry,
                                photo.
                                • charly2008C
                                  charly2008
                                  Hi Roberto,
                                  you will find it in the Tools menu.
                                  Charly
                                  • micioneM
                                    micione
                                    Charly,
                                    Thank you very much.
                                    (I tried to send a private message, but evidently you have not received).
                                    • C
                                      ccs1987
                                      Awesome tutorials
                                      Sketchup 8 pro
                                      Vray
                                      Intel Xeon W3520 2.67Ghz
                                      12Gb Ram
                                      Nvdia Quadro FX 1800
                                      • LanaL
                                        Lana
                                        Very good . I learned a lot here . Thank you all .
                                        • sketchartist023S
                                          sketchartist023
                                          I have not been able to manipulate the GUI interface with this tool, so I am left with overlapping issues in my model 😕 I am not sure what to do, but wow this tool is amazing so far! My concept is taking a plane lettering and then using a half circle guide flow to reform it to a rectangle below the lettering facing the same direction. SO, just a morphed half loop from letter to poly. But always get overlapping and face issues since I cannot use the points on the GUI. I wish I could do this stuff above! Will keep trying 😄
                                            If you'd like help, upload an example SKP file so we can see what you are trying to do.
                                            • 2 / 3
