    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 178.4k Views 41 Watching
    • mitcorbM
      mitcorb
      Now, this is a nice little "gem" by a really talented guy. 👍
      Edit: However, something in my installation will not complete the skinning process? Also, notably, I ran the ruby once with the console open to track the activity and nothing displayed, so I cannot provide any info beyond the following:
      WinXPtabletpc pro edition SU7.1xxx
      Curvishear.rb placed in Plugins folder.
      EDIT, AGAIN: Ok, I was dazzled by the video clip, and did not read at the bottom that automatic skinning is not available, yet. But, I will leave this post here as a lesson to myself that I must pay attention.
      fredo's classic bezier curves used, 1" tall at low end, 30" tall at high end.
      • C
        CodyV1
        This is great! How ironic 😮 I find this on the site when X Games rolls in. I think this would be great if it somehow incorperated banking. I'll be saving time by the hours with this on road courses 😍
        Be There
        http://www.facebook.com/#!/profile.php?id=100000814922209
        • halroachH
          halroach
          Hi Fredo,
          I know the plugin contains the word curve in it 😎 ... but would there be a way to get it to work on any geometry that isn't necessarily a curve?
          I may have confused the plugin's functionality.
          I guess I was thinking of something a bit different for ramp creations. You would push a curved surface onto a straight plane. Like Joint Push Pull but to a horizontal surface. You would use it when you have the ramp already created but don't have the base for it... how does that sound?
          FlexTools - Super Quick Windows, Doors, Slats...
          • M
            Macker
            Would it be able to do a ramp with say a "T junction" half way up? I'm just thinking about how to go about doing roads on uneven sites, which often have various junctions and so on.
            Check out my blog @ http://macviz.blogspot.co.uk
            • mitcorbM
              mitcorb
              @Macker:
              I just tried a simple T Junction with Bezier curves, but I stubbed the ends with straight segments and ran the ruby. The script could not decide which end to set as the low elevation and which to set as the high. So it basically did both elevations for all four stubs, leaving a wire frame mesh as a group.
              However, after throwing that away, I did a simple ramp and added Bezier plan profiles to the curvishear ramp and pushpulled the stubs up to the nearest point above and then adjusted them to coincide with the main slope. Not necessarily the best way, but one possible solution while we wait for any enhancements to this handy little tool.
              Best Regards,
              mitcorb
              • K
                kobus
                Respect, Fredo.
                Every once in a while a gem like this is there exactly when I need it.
                I'm going to include "difficult ramp for parking" here so people get this topic at the top of the list when searching. Many thanks !
                you should be interested in the future. you will spend the rest of your life there
                • G
                  grim
                  fredo
                  i realise this was just a quickie ruby but it is a good one that i use
                  however i am haveing trouble in SU8 is there a problem and does it need updating
                  regards
                  grim
                  • thomthomT
                    It helps to describe what the trouble is.
                    (Operations fails, error messages, messages in the Ruby Console?)
                    • KrisidiousK
                      Krisidious
                      punctuation helps too... are those questions or statements?
                      By: Kristoff Rand
                        If some modifications are made for the V8, what are the results for the previous versions?
                        • thomthomT
                          Should be none - Ruby 1.8.6 has stricter parsing which has been the biggest cause of the incompatibility.
                          • fredo6F
                            fredo6
                            @grim said:
                            fredo
                            regards
                            grim
                            CurviShear should work in SU8.
                            Do you experience problems?
                            Fredo
                            • M
                              monkeybss
                              Thanks, I very much needed this, life is going to be easier now...
                              • G
                                grim
                                fredo
                                yes i seem to have a problem see image attached , with a single arc it works fine, with a double arc and weld plugin used i get a mess
                                regerds grim
                                SU8 curvishear problem
                                • fredo6F
                                  fredo6
                                  @grim said:
                                  fredo
                                  regerds grim
                                  Could you post the skp file so that I have a look
                                  Fredo
                                  • R
                                    rv1974
                                    Hi fredo!
                                    Please take a look at this:
                                    http://www.scriptspot.com/3ds-max/scripts/ant-stitcher-fast-and-easy-way-to-connect-two-meshes-in-3ds-max
                                    If only you could add a similar feature it'd become a mega hit!
                                    • A
                                      arjunmax09
                                      I'm trying to make a ramp using curvishear and curviloft but not getting the desired result. I've attached a video of what exactly happens during the process
                                      trying to make Ramp.rar
                                      when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                      • jeff hammondJ
                                        jeff hammond
                                        arjun,
                                        try using the 3rd icon in curviloft.. skinning of shapes
                                        dotdotdot
                                        • A
                                          arjunmax09
                                          arjun,
                                          i tried using that but nothing happens..can you post a video or some screenshots?? I've uploaded the model btw..
                                          rr5 low.skp
                                          • D
                                            Daniel S
                                            @arjunmax09 said:
                                            arjun,
                                            Works for me...
                                            Like Jeff said.. try using the 3rd icon... not the first one:
                                            Here I attach the result:
                                            rr5 low.skp
                                            Daniel S
                                            • 2 / 4
