    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 169.3k Views 41 Watching
    • mitcorbM Offline
      mitcorb
      @Macker:
      I just tried a simple T Junction with Bezier curves, but I stubbed the ends with straight segments and ran the ruby. The script could not decide which end to set as the low elevation and which to set as the high. So it basically did both elevations for all four stubs, leaving a wire frame mesh as a group.
      However, after throwing that away, I did a simple ramp and added Bezier plan profiles to the curvishear ramp and pushpulled the stubs up to the nearest point above and then adjusted them to coincide with the main slope. Not necessarily the best way, but one possible solution while we wait for any enhancements to this handy little tool.
      Best Regards,
      mitcorb
        kobus
        Respect, Fredo.
        Every once in a while a gem like this is there exactly when I need it.
        I'm going to include "difficult ramp for parking" here so people get this topic at the top of the list when searching. Many thanks !
        you should be interested in the future. you will spend the rest of your life there
          grim
          fredo
          i realise this was just a quickie ruby but it is a good one that i use
          however i am haveing trouble in SU8 is there a problem and does it need updating
          regards
          grim
            It helps to describe what the trouble is.
            (Operations fails, error messages, messages in the Ruby Console?)
            • KrisidiousK Offline
              Krisidious
              punctuation helps too... are those questions or statements?
              By: Kristoff Rand
                If some modifications are made for the V8, what are the results for the previous versions?
                  Should be none - Ruby 1.8.6 has stricter parsing which has been the biggest cause of the incompatibility.
                  • fredo6F Offline
                    @grim said:
                    fredo
                    regards
                    grim
                    CurviShear should work in SU8.
                    Do you experience problems?
                      monkeybss
                      Thanks, I very much needed this, life is going to be easier now...
                        grim
                        fredo
                        yes i seem to have a problem see image attached , with a single arc it works fine, with a double arc and weld plugin used i get a mess
                        regerds grim
                        SU8 curvishear problem
                        • fredo6F Offline
                          @grim said:
                          fredo
                          regerds grim
                          Could you post the skp file so that I have a look
                            rv1974
                            Hi fredo!
                            Please take a look at this:
                            http://www.scriptspot.com/3ds-max/scripts/ant-stitcher-fast-and-easy-way-to-connect-two-meshes-in-3ds-max
                            If only you could add a similar feature it'd become a mega hit!
                              arjunmax09
                              I'm trying to make a ramp using curvishear and curviloft but not getting the desired result. I've attached a video of what exactly happens during the process
                              trying to make Ramp.rar
                              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                              • jeff hammondJ Offline
                                arjun,
                                try using the 3rd icon in curviloft.. skinning of shapes
                                  arjunmax09
                                  arjun,
                                  i tried using that but nothing happens..can you post a video or some screenshots?? I've uploaded the model btw..
                                  rr5 low.skp
                                    Daniel S
                                    @arjunmax09 said:
                                    arjun,
                                    Works for me...
                                    Like Jeff said.. try using the 3rd icon... not the first one:
                                    Here I attach the result:
                                    rr5 low.skp
                                    Daniel S
                                      arjunmax09
                                      @daniel s said:
                                      Works for me...
                                      [attachment=1:1596wm15]<!-- ia1 -->skin.jpg<!-- ia1 -->[/attachment:1596wm15]
                                      Daniel S
                                      Daniel...i used the same button for making the ramp...i select all the edges but nothing happens..Please upload screenshots or a video of how you actually make the ramp...I'm using SU 8 Pro..??
                                        Daniel S
                                        Just select the ramp and click the button. A small video showing how the skinning of the ramp is made:
                                        I´m using SU8 Pro too.
                                        Do you have the latests versions of Curviloft and LibFredo6?
                                        For checking the latest version of curviloft go to "Tools>Fredo6 Collection>Curviloft>About..." should say Curviloft v1.0c.
                                        For checking the latest version of LibFredo6 go to "Window>LibFredo6 Settings>About..." should say LibFredo6 v3.5c.
                                        If you don´t have that versions you can download them from here: http://forums.sketchucation.com/viewtopic.php?f=323&t=28586
                                        If you have the correct ones, try to make the ramp with the ruby console open (go to Window>Ruby Console). Perhaps the ruby console shows an error that you can copy and paste here.
                                        Daniel S
                                          arjunmax09
                                          I had the recent versions. I just checked the way you told. But I overwrote the files with freshly downloaded ones anyway. Eventually I was able to make the ramp that you made. That file had another ramp too. I can't make that one.. I've made a new file of that ramp and a video of what exactly happens. Please check and tell me what to do.
                                          RAmp another try.rar
                                            Daniel S
                                            Here you have to use another plugin called weld.rb (you can download it at http://www.smustard.com/script/Weld)
                                            I attach a video showing how to make it work and .skp files.
                                            Daniel S
                                            ramp new welded.skp
                                            ramp new final.skp
                                            ramp new video.wmv
                                            • 2 / 4
