    Get Link for Official Sketchup Bug Reporting
    28 Posts 14 Posters 8.6k Views 14 Watching
    • V Offline
      victor hugo
      Thanks TIG.
      The one that gives the splat is "Fredo6: Joint Push Pull Interactive v3.1a"
      is there a way to recover to previous version?
      Thanks for your reply.
      • TIGT Online
        The tool itself is NOT known to cause issues.
        Have you also got and installed the very latest Lib for Fredo's tools - available from the PluginStore http://sketchucation.com/pluginstore?pln=LibFredo6
        Works fine for me and many other users...
        It it's still failing with that latest Lib in tandem... then it might be 'innocent', BUT clashing with a 'less kindly' script...
        Do you have any of the known quarantined/rogues loading too ?
        SketchyPhysics, some Vray betas, older Podiums, Matchbox, etc...
        If so, try again without those...
        • V Offline
          victor hugo
          I have other plugins from Fredo and the Joint Push Pull Interactive v3.1a is the one not working, it was ok before this version and I can't go back to previous one..
          I don't have any quarantined ones I saw the quarantined topic already.
          Thanks.
            slbaumgartner
            @thomthom said:
            Use this link:
            http://help.sketchup.com/en/contact
            to make official bug reports to SketchUp
            When I submit the form at this link I get back an error message about invalid login, despite the fact that the form says nothing about needing a login and has no place to put one!
            • tt_suT Offline
              tt_su
              That form is no longer active. Instead go via: http://help.sketchup.com/en/contact
                slbaumgartner
                They should take it down if it is defunct!
                • tt_suT Offline
                  tt_su
                  It will be. No one knew that existed any more.
                  • P Offline
                    pgarmyn
                    The official forum to post a bug.
                    Looking to other posts on this forum... I have not the impression that the SU team is on this forum.
                    My bug report on the official SU forum :
                    https://productforums.google.com/forum/m/#!category-topic/sketchup/sketchup-pro/ZEGIk9xpp6U
                    On sketchucation :
                    http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57365%26amp;p=521587#p521587
                    • 2 / 2
