    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • S
      SUFractal
      WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
      Thanks!
      • TIGT
        Thanks!
        Window > Preferences > Extensions... activate it! 😉
        • R
          robert111
          charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
          thanks charly
          • charly2008C
            charly2008
            Hi Robert,
            the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
            Charly
            Curviloft99.skp
            • R
              robert111
              thanks charly , and for the seconde image ( black one) ??????
              • charly2008C
                charly2008
                the black background is from Glöbals --> HDR-probe within Kerkythea.
                • charly2008C
                  charly2008
                  new model with different materials.
                  • majidM
                    majid
                    first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                      I believe that plug section is not yet finalized!
                      try 2 faces and path by Kirill 2008
                      • fredo6F
                        fredo6
                        Coudl you post the model, because there should be no problem with that case.
                        Fredo
                        • mariochaM
                          mariocha
                          I had a similar problem.
                          Solved by getting one face slightly out of the plane of the other.
                          If this can help. 😄
                          %(#008000)[Mario C.
                          • majidM
                            majid
                            If this can help. 😄
                            yes mate it workes for me too, nice trick 😉
                            and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                            co-planar faces question
                              I have same result 😮
                              and this
                              don't works for me 😞
                              bug_or_not.skp
                              • TIGT
                                Introduce a 'vertical face' half way round the loop and do it in two steps ?
                                • mariochaM
                                  mariocha
                                  ...don't works for me ...
                                  Hum... just to be sure, one of the faces is not flat on the ground, right ?
                                  %(#008000)[Mario C.
                                  • D
                                    DIEGO-RODRIGUEZ
                                      Ah oK 😄
                                      But that is not normal 😉
                                      • fredo6F
                                        fredo6
                                        Ah oK 😄
                                        I cannot really say that this is normal 😆
                                        This is simply a small problem when the two faces are in parallel planes. It is part of the fixes I will release. The issue is just that the contours are connected in reverse directions.
                                        Fredo
                                        • D
                                          DIEGO-RODRIGUEZ
                                          Hi Fred.
                                          a question.
                                          is normal that generates the mesh outside the component or group that I'm working?
                                          • fredo6F
                                            fredo6
                                            @diego-rodriguez said:
                                            Hi Fred.
                                            a question.
                                            It's part of the bug fixed but not yet released.
                                            This was already signaled. see that post
                                            Fredo
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 65
                                            • 66
                                            • 19 / 66
