    Sculptris
    69 Posts 23 Posters 21.9k Views 23 Watching
    • K Offline
      Khai
      I think your going to be doing some cleanup there...!
      • charly2008C Offline
        charly2008
        i used the new N-Gone Check. In my Wikinger.skp it counted 12567 N-Gons. I tried to triangulate the model but without success.
        Karl
          remus
          You could always try saving it as a .3ds then importing it back in to SU.
            charly2008
            If i try to export the model as 3ds, Sketchup crashes. I don't know why.
            • pyrolunaP Offline
              pyroluna
              whohooo supercool!!
              I had to try this out at once!
              So I did:
                As Sculptris can export colors and depth buffer you can make any after effect in your favorite 3D package ๐Ÿ˜Ž
                By Taron (administrator of Dr Petter'site ๐Ÿ˜‰
                http://img99.imageshack.us/img99/3461/sheeple.jpg
                http://img189.imageshack.us/img189/2074/muscleape2.jpg
                Auto Portrait
                http://img69.imageshack.us/img69/9866/taron.jpg
                http://img337.imageshack.us/img337/459/butterflies.jpg
                http://img441.imageshack.us/img441/3096/foldeye.jpg
                • tridemT Offline
                  tridem
                  I used Blender as translator... ๐Ÿ˜ณ
                  • jo-keJ Offline
                    jo-ke
                    how can I convert the model to 3ds?
                    sculptris allows only obj and sc1
                    I tried to import the obj-file with the obj-importer plugin, then su was calculating but nothing appears.
                    what can I do?
                    http://www.zz7.de
                    • jo-keJ Offline
                      jo-ke
                      I tried to do that, but the modell doesn't appear in blender.
                      what importpresets did you use?
                      "ceate scene"?
                      http://www.zz7.de
                      • tridemT Offline
                        tridem
                        Be sure there's nothing in Blender...I remember that was totally out of scale and far from axis center and for this reason (?..I believe...) hidden in Blender viewport.
                        • jo-keJ Offline
                          jo-ke
                          OK but when i reimported the 3ds file to su there was only the square of blender
                          http://www.zz7.de
                          • tridemT Offline
                            tridem
                            Sorry...I'm very inexpert with Blender, I tried this way once and somehow it worked but I cannot help you further ๐Ÿ˜’
                            • HieruH Offline
                              Hieru
                              I'm struggling with this as well. Does anyone have any suggestions?
                              I tried importing a Sculptris .obj into Wings3D, but it crashes every time.
                              www.davidhier.co.uk
                              • EscapeArtistE Offline
                                EscapeArtist
                                You can try converting using FBXConverterUI from Autodesk, last I checked it was still available and free.
                                You'll have to convert from format "A", your starting format i.e. .OBJ; to .FBX and then to "B", your desired format, i.e .3DS. It works OK, but the output isn't exactly always what I wanted.
                                You an also try using Blender to import/export your desired format.
                                As far as the model not being visible, try "zoom extents" to see if it appears. Also try increasing the view distance (view > view properties > clip end (set to max, 10,000). Also, consider your model may have been put inside the box.
                                • HieruH Offline
                                  Hieru
                                  Thanks, I'll give your suggestions a go.
                                  www.davidhier.co.uk
                                    Sculptris goes to California ๐Ÿ˜Ž
                                    The mini Zbrush creator DrPetter (Sculptris) goes to Zbrush land! ๐Ÿ˜‰
                                    And integrates the Z Team ๐Ÿ˜Ž
                                    • K Offline
                                      Khai
                                      and no news if it'll stay free or go fee...
                                        see Dr Petter words ๐Ÿ˜‰
                                        You have yet a cool free version, no ? ๐Ÿ˜‰
                                        • K Offline
                                          Khai
                                          actually..not as such, I don't. it crashes constantly with any OBJ brought into it, from any program I use to create them.. and they are OBJ's that other programs have no issues with at all..... I was hoping there would be a fix to the OBJ support..
                                            Maybe you don't import the good obj format ๐Ÿ˜’
                                            Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                                            • 2 / 4
