    Sculptris
    69 Posts 23 Posters 19.6k Views 23 Watching
    • jo-keJ Offline
      jo-ke
      I tried to do that, but the modell doesn't appear in blender.
      what importpresets did you use?
      "ceate scene"?
      http://www.zz7.de
      • tridemT Offline
        tridem
        Be sure there's nothing in Blender...I remember that was totally out of scale and far from axis center and for this reason (?..I believe...) hidden in Blender viewport.
        • jo-keJ Offline
          jo-ke
          OK but when i reimported the 3ds file to su there was only the square of blender
          http://www.zz7.de
          • tridemT Offline
            tridem
            Sorry...I'm very inexpert with Blender, I tried this way once and somehow it worked but I cannot help you further πŸ˜’
            • HieruH Offline
              Hieru
              @jo-ke said:
              how can I convert the model to 3ds?
              sculptris allows only obj and sc1
              I'm struggling with this as well. Does anyone have any suggestions?
              I tried importing a Sculptris .obj into Wings3D, but it crashes every time.
              www.davidhier.co.uk
              • EscapeArtistE Offline
                EscapeArtist
                You can try converting using FBXConverterUI from Autodesk, last I checked it was still available and free.
                You'll have to convert from format "A", your starting format i.e. .OBJ; to .FBX and then to "B", your desired format, i.e .3DS. It works OK, but the output isn't exactly always what I wanted.
                You an also try using Blender to import/export your desired format.
                As far as the model not being visible, try "zoom extents" to see if it appears. Also try increasing the view distance (view > view properties > clip end (set to max, 10,000). Also, consider your model may have been put inside the box.
                • HieruH Offline
                  Hieru
                  Thanks, I'll give your suggestions a go.
                  www.davidhier.co.uk
                    Sculptris goes to California 😎
                    The mini Zbrush creator DrPetter (Sculptris) goes to Zbrush land! πŸ˜‰
                    And integrates the Z Team 😎
                      Khai
                      and no news if it'll stay free or go fee...
                        see Dr Petter words πŸ˜‰
                        You have yet a cool free version, no ? πŸ˜‰
                          Khai
                          actually..not as such, I don't. it crashes constantly with any OBJ brought into it, from any program I use to create them.. and they are OBJ's that other programs have no issues with at all..... I was hoping there would be a fix to the OBJ support..
                            Maybe you don't import the good obj format πŸ˜’
                            Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                              Khai
                              lets see. OBJ's from Blender, UVMapper Pro, Poser, trueSpace, Wings3D, Hexagon.... I've had it crash with cubes tri'd or not tri'd.
                              sorry I did do my homework trying to get it to work, but so far I've had no luck with it.
                                KiraNL
                                I played arround with this one too, very nice altho very buggy too.
                                Some of my creations:
                                http://img829.imageshack.us/img829/7388/workinprogressct.png
                                http://img534.imageshack.us/img534/3164/frontsidep.png
                                And a little video, dont know how to include youtube, but heres the link:
                                http://www.youtube.com/watch?v=-Tv329_Oexo
                                • artysmediaA Offline
                                  artysmedia
                                  hello:
                                  One month ago i started using sculptris. Now i will show you my third model.
                                  http://farm7.static.flickr.com/6209/6025777804_0031189871.jpg
                                  Devil Chiu 01 por artysmedia, en Flickr
                                  More, laterrrrr πŸ’š
                                  Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                  Blog: Artysmedia
                                  • StilTegS Offline
                                    StilTeg
                                    Damn, I definitely need to improve my skills in Sculptris ...
                                    doing technical engineering on SketchUp ... without plugins
                                    • BoxB Offline
                                      I saw this thread this morning so downloaded Sculptris, watched a couple of Vids and after mucking about for a while I produced this.
                                      Very nice program.
                                      I guess now I should learn about rendering.
                                      • soloS Offline
                                        Got a link to the vids?
                                        • BoxB Offline
                                          I just went to the forum for sculptris and found the first sticky with what seemed relevant to getting started.
                                          The links are in the thread.
                                          ZBrushCentral
                                          (www.zbrushcentral.com)
                                          • soloS Offline
                                            πŸ‘
                                            Very helpful tutorial, I have been using it without watching any tutorial (as I never found one)
                                            Expect brilliant models...I'm energized.
                                            • 2 / 4
