    Sculptris
    69 Posts 23 Posters 19.6k Views 23 Watching
      As Sculptris can export colors and depth buffer you can make any after effect in your favorite 3D package 😎
      By Taron (administrator of Dr Petter'site πŸ˜‰
      http://img99.imageshack.us/img99/3461/sheeple.jpg
      http://img189.imageshack.us/img189/2074/muscleape2.jpg
      Auto Portrait
      http://img69.imageshack.us/img69/9866/taron.jpg
      http://img337.imageshack.us/img337/459/butterflies.jpg
      http://img441.imageshack.us/img441/3096/foldeye.jpg
      • tridemT Offline
        tridem
        I used Blender as translator... 😳
        • jo-keJ Offline
          jo-ke
          how can I convert the model to 3ds?
          sculptris allows only obj and sc1
          I tried to import the obj-file with the obj-importer plugin, then su was calculating but nothing appears.
          what can I do?
          http://www.zz7.de
          • jo-keJ Offline
            jo-ke
            I tried to do that, but the modell doesn't appear in blender.
            what importpresets did you use?
            "ceate scene"?
            http://www.zz7.de
            • tridemT Offline
              tridem
              Be sure there's nothing in Blender...I remember that was totally out of scale and far from axis center and for this reason (?..I believe...) hidden in Blender viewport.
              • jo-keJ Offline
                jo-ke
                OK but when i reimported the 3ds file to su there was only the square of blender
                http://www.zz7.de
                • tridemT Offline
                  tridem
                  Sorry...I'm very inexpert with Blender, I tried this way once and somehow it worked but I cannot help you further πŸ˜’
                  • HieruH Offline
                    Hieru
                    I'm struggling with this as well. Does anyone have any suggestions?
                    I tried importing a Sculptris .obj into Wings3D, but it crashes every time.
                    www.davidhier.co.uk
                    • EscapeArtistE Offline
                      EscapeArtist
                      You can try converting using FBXConverterUI from Autodesk, last I checked it was still available and free.
                      You'll have to convert from format "A", your starting format i.e. .OBJ; to .FBX and then to "B", your desired format, i.e .3DS. It works OK, but the output isn't exactly always what I wanted.
                      You an also try using Blender to import/export your desired format.
                      As far as the model not being visible, try "zoom extents" to see if it appears. Also try increasing the view distance (view > view properties > clip end (set to max, 10,000). Also, consider your model may have been put inside the box.
                      • HieruH Offline
                        Hieru
                        Thanks, I'll give your suggestions a go.
                        www.davidhier.co.uk
                          Sculptris goes to California 😎
                          The mini Zbrush creator DrPetter (Sculptris) goes to Zbrush land! πŸ˜‰
                          And integrates the Z Team 😎
                            Khai
                            and no news if it'll stay free or go fee...
                              see Dr Petter words πŸ˜‰
                              You have yet a cool free version, no ? πŸ˜‰
                                Khai
                                actually..not as such, I don't. it crashes constantly with any OBJ brought into it, from any program I use to create them.. and they are OBJ's that other programs have no issues with at all..... I was hoping there would be a fix to the OBJ support..
                                  Maybe you don't import the good obj format πŸ˜’
                                  Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                                    Khai
                                    lets see. OBJ's from Blender, UVMapper Pro, Poser, trueSpace, Wings3D, Hexagon.... I've had it crash with cubes tri'd or not tri'd.
                                    sorry I did do my homework trying to get it to work, but so far I've had no luck with it.
                                      KiraNL
                                      I played arround with this one too, very nice altho very buggy too.
                                      Some of my creations:
                                      http://img829.imageshack.us/img829/7388/workinprogressct.png
                                      http://img534.imageshack.us/img534/3164/frontsidep.png
                                      And a little video, dont know how to include youtube, but heres the link:
                                      http://www.youtube.com/watch?v=-Tv329_Oexo
                                      • artysmediaA Offline
                                        artysmedia
                                        hello:
                                        One month ago i started using sculptris. Now i will show you my third model.
                                        http://farm7.static.flickr.com/6209/6025777804_0031189871.jpg
                                        Devil Chiu 01 por artysmedia, en Flickr
                                        More, laterrrrr πŸ’š
                                        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                        Blog: Artysmedia
                                        • StilTegS Offline
                                          StilTeg
                                          Damn, I definitely need to improve my skills in Sculptris ...
                                          doing technical engineering on SketchUp ... without plugins
                                          • BoxB Offline
                                            I saw this thread this morning so downloaded Sculptris, watched a couple of Vids and after mucking about for a while I produced this.
                                            Very nice program.
                                            I guess now I should learn about rendering.
                                            • 2 / 4
