    Sculptris
    69 Posts 23 Posters 20.8k Views 23 Watching
    • EscapeArtistE Offline
      EscapeArtist
      Yep, functions quite a bit like zbrush, obviously without the complexity or toolset. I found it easier to use though. Good fun, and it works quite well for what it is.
      • charly2008C Offline
        charly2008
        Hi Remus,
        I used the triangulate Faces by selection. But the N-Gon Check says there are still N-Gons in the model. What can i do else?
        Karl
        Wikinger.zip
          Khai
          I think your going to be doing some cleanup there...!
            charly2008
            i used the new N-Gone Check. In my Wikinger.skp it counted 12567 N-Gons. I tried to triangulate the model but without success.
            Karl
              remus
              You could always try saving it as a .3ds then importing it back in to SU.
                charly2008
                If i try to export the model as 3ds, Sketchup crashes. I don't know why.
                • pyrolunaP Offline
                  pyroluna
                  whohooo supercool!!
                  I had to try this out at once!
                  So I did:
                    As Sculptris can export colors and depth buffer you can make any after effect in your favorite 3D package 😎
                    By Taron (administrator of Dr Petter'site 😉
                    http://img99.imageshack.us/img99/3461/sheeple.jpg
                    http://img189.imageshack.us/img189/2074/muscleape2.jpg
                    Auto Portrait
                    http://img69.imageshack.us/img69/9866/taron.jpg
                    http://img337.imageshack.us/img337/459/butterflies.jpg
                    http://img441.imageshack.us/img441/3096/foldeye.jpg
                    • tridemT Offline
                      tridem
                      I used Blender as translator... 😳
                      • jo-keJ Offline
                        jo-ke
                        how can I convert the model to 3ds?
                        sculptris allows only obj and sc1
                        I tried to import the obj-file with the obj-importer plugin, then su was calculating but nothing appears.
                        what can I do?
                        http://www.zz7.de
                        • jo-keJ Offline
                          jo-ke
                          I tried to do that, but the modell doesn't appear in blender.
                          what importpresets did you use?
                          "ceate scene"?
                          http://www.zz7.de
                          • tridemT Offline
                            tridem
                            Be sure there's nothing in Blender...I remember that was totally out of scale and far from axis center and for this reason (?..I believe...) hidden in Blender viewport.
                            • jo-keJ Offline
                              jo-ke
                              OK but when i reimported the 3ds file to su there was only the square of blender
                              http://www.zz7.de
                              • tridemT Offline
                                tridem
                                Sorry...I'm very inexpert with Blender, I tried this way once and somehow it worked but I cannot help you further 😒
                                • HieruH Offline
                                  Hieru
                                  I'm struggling with this as well. Does anyone have any suggestions?
                                  I tried importing a Sculptris .obj into Wings3D, but it crashes every time.
                                  www.davidhier.co.uk
                                    EscapeArtist
                                    You can try converting using FBXConverterUI from Autodesk, last I checked it was still available and free.
                                    You'll have to convert from format "A", your starting format i.e. .OBJ; to .FBX and then to "B", your desired format, i.e .3DS. It works OK, but the output isn't exactly always what I wanted.
                                    You an also try using Blender to import/export your desired format.
                                    As far as the model not being visible, try "zoom extents" to see if it appears. Also try increasing the view distance (view > view properties > clip end (set to max, 10,000). Also, consider your model may have been put inside the box.
                                    • HieruH Offline
                                      Hieru
                                      Thanks, I'll give your suggestions a go.
                                      www.davidhier.co.uk
                                        Sculptris goes to California 😎
                                        The mini Zbrush creator DrPetter (Sculptris) goes to Zbrush land! 😉
                                        And integrates the Z Team 😎
                                          Khai
                                          and no news if it'll stay free or go fee...
                                            see Dr Petter words 😉
                                            You have yet a cool free version, no ? 😉
                                            • 2 / 4
