    Sculptris
    69 Posts 23 Posters 18.3k Views 23 Watching
    • charly2008C Offline
      charly2008
      If i try to export the model as 3ds, Sketchup crashes. I don't know why.
      • pyrolunaP Offline
        pyroluna
        whohooo supercool!!
        I had to try this out at once!
        So I did:
          As Sculptris can export colors and depth buffer you can make any after effect in your favorite 3D package 😎
          By Taron (administrator of Dr Petter'site πŸ˜‰
          http://img99.imageshack.us/img99/3461/sheeple.jpg
          http://img189.imageshack.us/img189/2074/muscleape2.jpg
          Auto Portrait
          http://img69.imageshack.us/img69/9866/taron.jpg
          http://img337.imageshack.us/img337/459/butterflies.jpg
          http://img441.imageshack.us/img441/3096/foldeye.jpg
          • tridemT Offline
            tridem
            I used Blender as translator... 😳
            • jo-keJ Offline
              jo-ke
              how can I convert the model to 3ds?
              sculptris allows only obj and sc1
              I tried to import the obj-file with the obj-importer plugin, then su was calculating but nothing appears.
              what can I do?
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                I tried to do that, but the modell doesn't appear in blender.
                what importpresets did you use?
                "ceate scene"?
                http://www.zz7.de
                • tridemT Offline
                  tridem
                  Be sure there's nothing in Blender...I remember that was totally out of scale and far from axis center and for this reason (?..I believe...) hidden in Blender viewport.
                  • jo-keJ Offline
                    jo-ke
                    OK but when i reimported the 3ds file to su there was only the square of blender
                    http://www.zz7.de
                    • tridemT Offline
                      tridem
                      Sorry...I'm very inexpert with Blender, I tried this way once and somehow it worked but I cannot help you further πŸ˜’
                      • HieruH Offline
                        Hieru
                        I'm struggling with this as well. Does anyone have any suggestions?
                        I tried importing a Sculptris .obj into Wings3D, but it crashes every time.
                        www.davidhier.co.uk
                        • EscapeArtistE Offline
                          EscapeArtist
                          You can try converting using FBXConverterUI from Autodesk, last I checked it was still available and free.
                          You'll have to convert from format "A", your starting format i.e. .OBJ; to .FBX and then to "B", your desired format, i.e .3DS. It works OK, but the output isn't exactly always what I wanted.
                          You an also try using Blender to import/export your desired format.
                          As far as the model not being visible, try "zoom extents" to see if it appears. Also try increasing the view distance (view > view properties > clip end (set to max, 10,000). Also, consider your model may have been put inside the box.
                          • HieruH Offline
                            Hieru
                            Thanks, I'll give your suggestions a go.
                            www.davidhier.co.uk
                              Sculptris goes to California 😎
                              The mini Zbrush creator DrPetter (Sculptris) goes to Zbrush land! πŸ˜‰
                              And integrates the Z Team 😎
                                Khai
                                and no news if it'll stay free or go fee...
                                  see Dr Petter words πŸ˜‰
                                  You have yet a cool free version, no ? πŸ˜‰
                                    Khai
                                    actually..not as such, I don't. it crashes constantly with any OBJ brought into it, from any program I use to create them.. and they are OBJ's that other programs have no issues with at all..... I was hoping there would be a fix to the OBJ support..
                                      Maybe you don't import the good obj format πŸ˜’
                                      Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                                        Khai
                                        lets see. OBJ's from Blender, UVMapper Pro, Poser, trueSpace, Wings3D, Hexagon.... I've had it crash with cubes tri'd or not tri'd.
                                        sorry I did do my homework trying to get it to work, but so far I've had no luck with it.
                                          KiraNL
                                          I played arround with this one too, very nice altho very buggy too.
                                          Some of my creations:
                                          http://img829.imageshack.us/img829/7388/workinprogressct.png
                                          http://img534.imageshack.us/img534/3164/frontsidep.png
                                          And a little video, dont know how to include youtube, but heres the link:
                                          http://www.youtube.com/watch?v=-Tv329_Oexo
                                          • artysmediaA Offline
                                            artysmedia
                                            hello:
                                            One month ago i started using sculptris. Now i will show you my third model.
                                            http://farm7.static.flickr.com/6209/6025777804_0031189871.jpg
                                            Devil Chiu 01 por artysmedia, en Flickr
                                            More, laterrrrr πŸ’š
                                            Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                            Blog: Artysmedia
                                            • 2 / 4
