    Sculptris
    69 Posts 23 Posters 23.1k Views 23 Watching
    • tridemT
      tridem
      I used Blender as translator... 😳
      • jo-keJ
        jo-ke
        how can I convert the model to 3ds?
        sculptris allows only obj and sc1
        I tried to import the obj-file with the obj-importer plugin, then su was calculating but nothing appears.
        what can I do?
        http://www.zz7.de
        • jo-keJ
          jo-ke
          I tried to do that, but the modell doesn't appear in blender.
          what importpresets did you use?
          "ceate scene"?
          http://www.zz7.de
          • tridemT
            tridem
            Be sure there's nothing in Blender...I remember that was totally out of scale and far from axis center and for this reason (?..I believe...) hidden in Blender viewport.
            • jo-keJ
              jo-ke
              OK but when i reimported the 3ds file to su there was only the square of blender
              http://www.zz7.de
              • tridemT
                tridem
                Sorry...I'm very inexpert with Blender, I tried this way once and somehow it worked but I cannot help you further πŸ˜’
                • HieruH
                  Hieru
                  I'm struggling with this as well. Does anyone have any suggestions?
                  I tried importing a Sculptris .obj into Wings3D, but it crashes every time.
                  www.davidhier.co.uk
                  • EscapeArtistE
                    EscapeArtist
                    You can try converting using FBXConverterUI from Autodesk, last I checked it was still available and free.
                    You'll have to convert from format "A", your starting format i.e. .OBJ; to .FBX and then to "B", your desired format, i.e .3DS. It works OK, but the output isn't exactly always what I wanted.
                    You an also try using Blender to import/export your desired format.
                    As far as the model not being visible, try "zoom extents" to see if it appears. Also try increasing the view distance (view > view properties > clip end (set to max, 10,000). Also, consider your model may have been put inside the box.
                    • HieruH
                      Hieru
                      Thanks, I'll give your suggestions a go.
                      www.davidhier.co.uk
                        Sculptris goes to California 😎
                        The mini Zbrush creator DrPetter (Sculptris) goes to Zbrush land! πŸ˜‰
                        And integrates the Z Team 😎
                        • K
                          Khai
                          and no news if it'll stay free or go fee...
                            see Dr Petter words πŸ˜‰
                            You have yet a cool free version, no ? πŸ˜‰
                            • K
                              Khai
                              actually..not as such, I don't. it crashes constantly with any OBJ brought into it, from any program I use to create them.. and they are OBJ's that other programs have no issues with at all..... I was hoping there would be a fix to the OBJ support..
                                Maybe you don't import the good obj format πŸ˜’
                                Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                                • K
                                  Khai
                                  lets see. OBJ's from Blender, UVMapper Pro, Poser, trueSpace, Wings3D, Hexagon.... I've had it crash with cubes tri'd or not tri'd.
                                  sorry I did do my homework trying to get it to work, but so far I've had no luck with it.
                                  • K
                                    KiraNL
                                    I played arround with this one too, very nice altho very buggy too.
                                    Some of my creations:
                                    http://img829.imageshack.us/img829/7388/workinprogressct.png
                                    http://img534.imageshack.us/img534/3164/frontsidep.png
                                    And a little video, dont know how to include youtube, but heres the link:
                                    http://www.youtube.com/watch?v=-Tv329_Oexo
                                    • artysmediaA
                                      artysmedia
                                      hello:
                                      One month ago i started using sculptris. Now i will show you my third model.
                                      http://farm7.static.flickr.com/6209/6025777804_0031189871.jpg
                                      Devil Chiu 01 por artysmedia, en Flickr
                                      More, laterrrrr πŸ’š
                                      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                      Blog: Artysmedia
                                      • StilTegS
                                        StilTeg
                                        Damn, I definitely need to improve my skills in Sculptris ...
                                        doing technical engineering on SketchUp ... without plugins
                                        • BoxB
                                          I saw this thread this morning so downloaded Sculptris, watched a couple of Vids and after mucking about for a while I produced this.
                                          Very nice program.
                                          I guess now I should learn about rendering.
                                          • soloS
                                            Got a link to the vids?
                                            • 2 / 4
