    [Plugin] Edge Tools
    211 Posts 74 Posters 285.2k Views 74 Watching
    • K Offline
      kizner
      THANK A LOT - I WAS LOOKING FOR YOUR PLUGINS- THIS IS MUST HAVE IN ALL SKP.
      EVERY BODY SHOULD TRY
        # 2.0.3 - 10.05.2011
        #		 * VCB input now accepts all array format variants.
        #		 * Fixed namespace compatibility with TT_Lib 2.5.4
        Requires TT_Lib 2.5.4
        • Rich O BrienR Online
          πŸ‘
          Thanks Thom
            That one was for you Rich! πŸ˜‰
              You've moved up in my favourite person list. Your now 82nd πŸ‘
              • EdsonE Offline
                Edson
                thom,
                I have run into a small problem: when I hover over the icons on the toolbar I get no feedback as to what each icon refers to. to be more precise, the name of the tools do not appear. I am on mac. do you have a fix for that? or, is there any place where I could find what each icon in the toolbar means?
                http://www.mahfuz.arq.br
                  hmm... no tooltips...? how odd...
                  and you get it on other plugins`?
                  I don't see why there should be a difference for OSX on this... πŸ˜•
                  • EdsonE Offline
                    Edson
                    I do not get it with any other plugin, including your own. all the others work fine. edge tools is the only one in which the problem appears.
                    • wind-borneW Offline
                      wind-borne
                      @edson said:
                      thom,
                      I noticed on my Mac if Edge tools toolbar is horizontal there was no feedback yet works fine vertical.
                      "To read between the lines was easier than to follow the text."OSX 10.11.6
                      %(#BF80BF)[SU 8 pro
                      • EdsonE Offline
                        Edson
                        not so in mine. no feedback either way.
                        • jeff hammondJ Offline
                          jeff hammond
                          position the toolbar vertically then quit sketchup.. relaunch and the tooltips should work.
                          dotdotdot
                            eh? Is this a know OSX issue?
                            what an bizzare one... πŸ˜• πŸ˜’
                            • EdsonE Offline
                              Edson
                              bizarre indeed! the tooltips are working now! and what a useful plugin this is! πŸ‘ thanks for it, thom.
                                jeff hammond
                                it's hard to say since sketchup is the only app i use that allows you to drag a toolbar to the top of the screen and it will switch to horizontal orientation.
                                it's very weird toolbar behavior in OSX world so i doubt it's a known issue since no apps do it.
                                i just stumbled upon it one day when i tried 1001bit toolbar across the top of my screen.
                                (bonzai has a few horizontal toolbars but their tooltips (vert&horizontal) aren't standard so they've done something to modify the icons/tooltips)
                                dotdotdot
                                • N Offline
                                  nicasiojoel
                                  Thom, Thanks a lot. This should be a must on all sketchup user. A very useful plug. It makes work easier and faster.
                                    2.0.4 - 11.07.2011
                                    • Close All Edge Gaps: Heals closed edges.
                                    • Close All Edge Gaps: Undoable.
                                    • Close All Edge Gaps: Inputbox store values correctly.
                                      πŸ‘
                                      • EarthMoverE Offline
                                        EarthMover
                                        Nice update. Thanks Thomthom!! πŸ‘
                                        Content Creator at Skapeup
                                        • mitcorbM Offline
                                          mitcorb
                                          Hi, ThomThom:
                                          Thank you again for this excellent tool. And thank you for the 2.0.4 update. Will you be inserting info on the update in the first post?
                                            hm.. was just a minor update, really needed?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 6 / 11
