    Best way to delete entities
    19 Posts 9 Posters 8.4k Views 9 Watching
    • X
      xiobus
      Anyone know the best way to delete all the entities except for one layer? I also noticed when you do a foreach entity delete it does not remove them all here is the code
      model = Sketchup.active_model
      entities = model.active_entities
      entities.each { | entity| entities.erase_entities entity }
      • thomthomT
        To delete one entity: use Entity.erase!
        entity = Sketchup.active_model.active_entities[0] entity.erase!
        To delete multiple:
        model = Sketchup.active_model entities = model.active_entities model.active_entities.erase_entities entities
        The reason you find, in your example, the only only delete some, is that you iterate the same collection of entities you erase from. So the indexes reshuffles without the .each method adjusting for it.
        To make it work, use the array of the Entities collection:
        model = Sketchup.active_model entities = model.active_entities entities.to_a.each { | entity| entity.erase! }
        this way you are working on a array copy of the entities collection which isn't affected when you erase entities. But when erasing multiple entities, use the previous example: Entities.erase_entities
        • daikuD
          daiku
          Thom is correct. It's a Ruby No-no to delete items from a container as you iterate through them.
          Clark Bremer
          http://www.northernlightstimberframing.com
          • fredo6F
            fredo6
            You could take inspiration of the following code snippet
            lst_del = model.entities.find_all { |e| e.layer != my_layer_to_keep }
            model.entities.erase_entities lst_del
            Be careful with that code, because the code is really 'destructive'.
            Note that it only check layer at first level. If there is a component or group at first level, which contains some geometry put on your leyer-to-keep, then it will be erased. To overcome this, you would have to loop on all components and groups in the model (there's no API method to get the list of entities on a given layer).
            Fredo
            • M
              MartinRinehart
              As recursive code is fun, I was going to write something to solve this problem, but I thought better of it. Can anyone suggest an example of a sensible model that does not keep groups/components on a single layer with their entities?
              Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
              • TIGT
                Almost all 'properly' structured models have ALL base geometry on 'Layer0' and their containers - Groups or Component Instances - put on specific layers - so a group with its contents on different a layer id the NORM rather than the exception ?
                The only time you move base geometry onto a layer other than the Default [Layer0 et al] is if you are doing something complex like showing hiding bits in Scenes...
                • daikuD
                  daiku
                  Almost all 'properly' structured models have ALL base geometry on 'Layer0'...[/quote]
                  I agree. Is there a ruby out there that will "sanitize" you model to enforce this "rule"? It would ignore groups and comps, but any base geometry would be moced to layer0. CB.
                  Clark Bremer
                  • J
                    Jim
                    Hi Clark,
                    There is such a plugin here:
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=7638&hilit=default+layer
                    • daikuD
                      daiku
                      Excellent. Thanks Tig.
                      Clark Bremer
                      • TIGT
                        I agree.
                        See this: http://forums.sketchucation.com/viewtopic.php?p=115749#p115749
                        copy/paste the code into a file called something like default_layer_geometry.rb in the Plugins folder...
                        • artmusicstudioA
                          artmusicstudio
                          [quote="thomthom"]To delete one entity: use Entity.erase!
                          hi tig,
                          in my first ruby i have already managed it to copy one master-component (created with ruby at [0,0,0] and copying it, where ever i want.
                          after placing it in all places wanted, i would like
                          to DELETE this particular master-component.
                          i found your code:
                          entity.erase!
                          but how can i define , which component is to be deleted? is there a name somewhere? or index, i could "memorize" while creating the master component? is the [0] maybe a place for a definition?
                          thanx a lot for helping!
                          stan
                          • TIGT
                            @Stan
                            How are you making the initial component instance?
                            How are you 'copying' it ?
                            To have done that you must have had a 'reference' to its definition - let's say it's called ' defn'...
                            To find that definition's first instance and then to delete it use:
                            defn.instances.first.erase!
                            • artmusicstudioA
                              artmusicstudio
                              hi tig,
                              probably i have a mistake in the component-description.
                              i define a master component (two tubes).
                              #DEF PFOSTEN MASTER COMPONENT
                                 pfm1 = [0, 0, 0+thickness]
                                 pfm2 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
                                 pfm3 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
                                 pfm4 = [0, 0, 0+thickness+sl]
                                 group = entities.add_group
                                 entities2 = group.entities
                                 new_line = entities2.add_line pfm1, pfm2
                                              length = new_line.length
                                              centerpoint = pfm1
                                              vector = pfm2
                                              vector = vector.normalize!
                                              edges = entities2.add_circle centerpoint, vector, pradius
                                              kreis = entities2.add_face edges
                                              kreis.pushpull length
                                 new_line2 = entities2.add_line pfm3, pfm4
                                              length2 = new_line2.length
                                              centerpoint2 = pfm4
                                 	            vector2 = pfm3
                                          vector2 = vector.normalize!
                              	    edges2 = entities2.add_circle centerpoint2, vector2, pradius/3
                              	    kreis2 = entities2.add_face edges2
                                              kreis2.pushpull -length2
                                 masterpfostenl = group.to_component
                              and then copy it to different places to ponits pf1,2,3:
                              componentinstance =
                              entities.add_instance(masterpfostenl.definition, pf1)
                              componentinstance =
                              entities.add_instance(masterpfostenr.definition, pf3)
                              componentinstance =
                              entities.add_instance(mittelpfostenm.definition, pf5)
                              after all components are placed, i will try the
                              defn.instances.first.erase! (have still to find out, how to point the right "instances-group"
                              thanx
                              stan
                              • TIGT
                                You have got it !
                                defn = masterpfostenl.definition
                                The masterpfostenl is a reference to the first 'instance' of the new 'definition'...
                                Then see my previous example...
                                BUT to delete it it use masterpfostenl.erase!
                                Because you already have a reference to it, which you have set up early on...
                                • artmusicstudioA
                                  artmusicstudio
                                  yes sir,
                                  it works perfectly. so this deletes the master-component.
                                  i just wonder, how then can be identified the ,daughter'-components.
                                  per x,y,z ?
                                  anyway, thank you very much for this solution.
                                  stan
                                  • TIGT
                                    @stan
                                    Assuming 'defn' is a reference to the component's definition then
                                    defn.instances
                                    gives you a list of all current instances, in the order of their creation.
                                    let's say you want to find the first one [remember that arrays start at 0 NOT 1 !]
                                    instance = defn.instances[0]
                                    To find out where it is in its current context use
                                    point = instance.transformation.origin
                                    There are also other transformation properties available to get the orientation of the objetc's x/y/zaxis too...
                                    There are also some methods available to get rotations, scaling etc from the instance.transformation search for them - here's an example... http://sketchucation.com/forums/viewtopic.php?p=411972#p411972
                                    • Al HartA
                                      Al Hart
                                      I couldn't get this to work:
                                      I get thi error:
                                      Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
                                      <main>:in `erase_entities'
                                      But I was able to get this to work: (adding .to_a which probably serves to isolate the entities array)
                                      model.active_entities.erase_entities entities.to_a
                                      Al Hart
                                      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
                                      IRender nXt from Render Plus
                                      • TIGT
                                        The entities.erase_entities(array)
                                        Expects an array NOT an entities collection, so adding .to_a resolves that.
                                        BUT entites.clear! is even easier.
                                        • Al HartA
                                          Al Hart
                                          great - that's what I was looking for anyway
                                          Al Hart
