    Best way to delete entities
    19 Posts 9 Posters 8.4k Views 9 Watching
      @martinrinehart said:
      If there is a component or group at first level, which contains some geometry put on your leyer-to-keep, then it will be erased.
      As recursive code is fun, I was going to write something to solve this problem, but I thought better of it. Can anyone suggest an example of a sensible model that does not keep groups/components on a single layer with their entities?
      Almost all 'properly' structured models have ALL base geometry on 'Layer0' and their containers - Groups or Component Instances - put on specific layers - so a group with its contents on different a layer id the NORM rather than the exception ?
      The only time you move base geometry onto a layer other than the Default [Layer0 et al] is if you are doing something complex like showing hiding bits in Scenes...
      • daikuD
        daiku
        Almost all 'properly' structured models have ALL base geometry on 'Layer0'...[/quote]
        I agree. Is there a ruby out there that will "sanitize" you model to enforce this "rule"? It would ignore groups and comps, but any base geometry would be moced to layer0. CB.
        Clark Bremer
        http://www.northernlightstimberframing.com
          Jim
          Hi Clark,
          There is such a plugin here:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=7638&hilit=default+layer
          • daikuD
            daiku
            Excellent. Thanks Tig.
            Clark Bremer
              I agree.
              See this: http://forums.sketchucation.com/viewtopic.php?p=115749#p115749
              copy/paste the code into a file called something like default_layer_geometry.rb in the Plugins folder...
              • artmusicstudioA
                artmusicstudio
                [quote="thomthom"]To delete one entity: use Entity.erase!
                entity = Sketchup.active_model.active_entities[0] entity.erase!
                hi tig,
                in my first ruby i have already managed it to copy one master-component (created with ruby at [0,0,0] and copying it, where ever i want.
                after placing it in all places wanted, i would like
                to DELETE this particular master-component.
                i found your code:
                entity.erase!
                but how can i define , which component is to be deleted? is there a name somewhere? or index, i could "memorize" while creating the master component? is the [0] maybe a place for a definition?
                thanx a lot for helping!
                stan
                  @Stan
                  How are you making the initial component instance?
                  How are you 'copying' it ?
                  To have done that you must have had a 'reference' to its definition - let's say it's called ' defn'...
                  To find that definition's first instance and then to delete it use:
                  defn.instances.first.erase!
                  • artmusicstudioA
                    artmusicstudio
                    hi tig,
                    probably i have a mistake in the component-description.
                    i define a master component (two tubes).
                    #DEF PFOSTEN MASTER COMPONENT
                       model = Sketchup.active_model
                       entities = model.active_entities
                       pfm1 = [0, 0, 0+thickness]
                       pfm2 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
                       pfm3 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
                       pfm4 = [0, 0, 0+thickness+sl]
                       group = entities.add_group
                       entities2 = group.entities
                       new_line = entities2.add_line pfm1, pfm2
                                    length = new_line.length
                                    centerpoint = pfm1
                                    vector = pfm2
                                    vector = vector.normalize!
                                    edges = entities2.add_circle centerpoint, vector, pradius
                                    kreis = entities2.add_face edges
                                    kreis.pushpull length
                       new_line2 = entities2.add_line pfm3, pfm4
                                    length2 = new_line2.length
                                    centerpoint2 = pfm4
                       	            vector2 = pfm3
                                vector2 = vector.normalize!
                    	    edges2 = entities2.add_circle centerpoint2, vector2, pradius/3
                    	    kreis2 = entities2.add_face edges2
                                    kreis2.pushpull -length2
                       masterpfostenl = group.to_component
                    and then copy it to different places to ponits pf1,2,3:
                    componentinstance =
                    entities.add_instance(masterpfostenl.definition, pf1)
                    componentinstance =
                    entities.add_instance(masterpfostenr.definition, pf3)
                    componentinstance =
                    entities.add_instance(mittelpfostenm.definition, pf5)
                    after all components are placed, i will try the
                    defn.instances.first.erase! (have still to find out, how to point the right "instances-group"
                    thanx
                    stan
                      You have got it !
                      defn = masterpfostenl.definition
                      The masterpfostenl is a reference to the first 'instance' of the new 'definition'...
                      Then see my previous example...
                      BUT to delete it it use masterpfostenl.erase!
                      Because you already have a reference to it, which you have set up early on...
                      • artmusicstudioA
                        artmusicstudio
                        yes sir,
                        it works perfectly. so this deletes the master-component.
                        i just wonder, how then can be identified the ,daughter'-components.
                        per x,y,z ?
                        anyway, thank you very much for this solution.
                        stan
                          @stan
                          Assuming 'defn' is a reference to the component's definition then
                          defn.instances
                          gives you a list of all current instances, in the order of their creation.
                          let's say you want to find the first one [remember that arrays start at 0 NOT 1 !]
                          instance = defn.instances[0]
                          To find out where it is in its current context use
                          point = instance.transformation.origin
                          There are also other transformation properties available to get the orientation of the objetc's x/y/zaxis too...
                          There are also some methods available to get rotations, scaling etc from the instance.transformation search for them - here's an example... http://sketchucation.com/forums/viewtopic.php?p=411972#p411972
                          • Al HartA
                            Al Hart
                            I couldn't get this to work:
                            model.active_entities.erase_entities entities
                            I get thi error:
                            Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
                            <main>:in `erase_entities'
                            But I was able to get this to work: (adding .to_a which probably serves to isolate the entities array)
                            model.active_entities.erase_entities entities.to_a
                            Al Hart
                            IRender nXt from Render Plus
                              The entities.erase_entities(array)
                              Expects an array NOT an entities collection, so adding .to_a resolves that.
                              BUT entites.clear! is even easier.
                              • Al HartA
                                Al Hart
                                great - that's what I was looking for anyway
                                Al Hart
                                With your input, this post could be even better šŸ’—
