    Best way to delete entities
    19 Posts 9 Posters 8.4k Views 9 Watching
    • daikuD
      daiku
      Excellent. Thanks Tig.
      Clark Bremer
      http://www.northernlightstimberframing.com
        @daiku said:
        Almost all 'properly' structured models have ALL base geometry on 'Layer0'...
        I agree.
        Is there a ruby out there that will "sanitize" you model to enforce this "rule"? It would ignore groups and comps, but any base geometry would be moced to layer0. CB.
        See this: http://forums.sketchucation.com/viewtopic.php?p=115749#p115749
        copy/paste the code into a file called something like default_layer_geometry.rb in the Plugins folder...
        • artmusicstudioA
          artmusicstudio
          [quote="thomthom"]To delete one entity: use Entity.erase!
          entity = Sketchup.active_model.active_entities[0] entity.erase!
          hi tig,
          in my first ruby i have already managed it to copy one master-component (created with ruby at [0,0,0] and copying it, where ever i want.
          after placing it in all places wanted, i would like
          to DELETE this particular master-component.
          i found your code:
          entity.erase!
          but how can i define , which component is to be deleted? is there a name somewhere? or index, i could "memorize" while creating the master component? is the [0] maybe a place for a definition?
          thanx a lot for helping!
          stan
            @Stan
            How are you making the initial component instance?
            How are you 'copying' it ?
            To have done that you must have had a 'reference' to its definition - let's say it's called ' defn'...
            To find that definition's first instance and then to delete it use:
            defn.instances.first.erase!
            • artmusicstudioA
              artmusicstudio
              hi tig,
              probably i have a mistake in the component-description.
              i define a master component (two tubes).
              #DEF PFOSTEN MASTER COMPONENT
                 model = Sketchup.active_model
                 entities = model.active_entities
                 pfm1 = [0, 0, 0+thickness]
                 pfm2 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
                 pfm3 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
                 pfm4 = [0, 0, 0+thickness+sl]
                 group = entities.add_group
                 entities2 = group.entities
                 new_line = entities2.add_line pfm1, pfm2
                              length = new_line.length
                              centerpoint = pfm1
                              vector = pfm2
                              vector = vector.normalize!
                              edges = entities2.add_circle centerpoint, vector, pradius
                              kreis = entities2.add_face edges
                              kreis.pushpull length
                 new_line2 = entities2.add_line pfm3, pfm4
                              length2 = new_line2.length
                              centerpoint2 = pfm4
                 	            vector2 = pfm3
                          vector2 = vector.normalize!
              	    edges2 = entities2.add_circle centerpoint2, vector2, pradius/3
              	    kreis2 = entities2.add_face edges2
                              kreis2.pushpull -length2
                 masterpfostenl = group.to_component
              and then copy it to different places to ponits pf1,2,3:
              componentinstance =
              entities.add_instance(masterpfostenl.definition, pf1)
              componentinstance =
              entities.add_instance(masterpfostenr.definition, pf3)
              componentinstance =
              entities.add_instance(mittelpfostenm.definition, pf5)
              after all components are placed, i will try the
              defn.instances.first.erase! (have still to find out, how to point the right "instances-group"
              thanx
              stan
                You have got it !
                defn = masterpfostenl.definition
                The masterpfostenl is a reference to the first 'instance' of the new 'definition'...
                Then see my previous example...
                BUT to delete it it use masterpfostenl.erase!
                Because you already have a reference to it, which you have set up early on...
                • artmusicstudioA
                  artmusicstudio
                  yes sir,
                  it works perfectly. so this deletes the master-component.
                  i just wonder, how then can be identified the ,daughter'-components.
                  per x,y,z ?
                  anyway, thank you very much for this solution.
                  stan
                    @stan
                    Assuming 'defn' is a reference to the component's definition then
                    defn.instances
                    gives you a list of all current instances, in the order of their creation.
                    let's say you want to find the first one [remember that arrays start at 0 NOT 1 !]
                    instance = defn.instances[0]
                    To find out where it is in its current context use
                    point = instance.transformation.origin
                    There are also other transformation properties available to get the orientation of the objetc's x/y/zaxis too...
                    There are also some methods available to get rotations, scaling etc from the instance.transformation search for them - here's an example... http://sketchucation.com/forums/viewtopic.php?p=411972#p411972
                    • Al HartA
                      Al Hart
                      I couldn't get this to work:
                      model.active_entities.erase_entities entities
                      I get thi error:
                      Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
                      <main>:in `erase_entities'
                      But I was able to get this to work: (adding .to_a which probably serves to isolate the entities array)
                      model.active_entities.erase_entities entities.to_a
                      Al Hart
                      IRender nXt from Render Plus
                        The entities.erase_entities(array)
                        Expects an array NOT an entities collection, so adding .to_a resolves that.
                        BUT entites.clear! is even easier.
                        • Al HartA
                          Al Hart
                          great - that's what I was looking for anyway
                          Al Hart
                          With your input, this post could be even better šŸ’—
