    [Plugin] UV Toolkit
    377 Posts 86 Posters 375.9k Views 86 Watching
      I think what you need to do is sample four points in a quadratic formation of the face's plane and then shift the 3Dpoints.
        @pixero said:
        First, an option to keep the scale of a texture when rotating.
        That's a mighty small image there... can't see much what's going on.
        The rotate feature is meant for textures stretched to fit quad-faces. Special purpose rotate. SU already got rotate methods built in - When you activate SU's texture gizmo - you have a Rotate sub-menu.
        • PixeroP Offline
          Pixero
          Here's my two requests for a great tool:
          http://imagecloset.com/28/a429772e52af5cc3266b8d5eb74ce6f3/UVrotate.jpg
          Second, add it to the right click menu for easier access.
          Edit: Fixed the image size. πŸ˜’
          • PixeroP Offline
            Pixero
            Still its great to be able to select a bunch of faces and rotate at the same time.
            You cant do that with SU's build in tools can you?
              No you can't. Good point. I could add that feature. πŸ‘
              • PixeroP Offline
                Pixero
                I'm using it to rotate the texture on leaves on trees so doing it manually isn't an option. πŸ˜‰
                And don't forget the right click menu...
                  Only thing though, about which points should it rotate...?
                  • PixeroP Offline
                    Pixero
                    Can't you just swap the UV "scale"?
                    I mean like it is now but with an option to keep the scale on the X and Y axis.
                    (Rotating the points so that Points A,B,C,D would be D,A,B,C or something like that.)
                      There is no such fixed points. The one for the quad-faces works like that because you can use the four vertices of the face. But you can't do that when you have differently shaped faces and/or want to preserve scale.
                      With SU, you have to generate the set of points yourself and query the face. So when rotating, I need one anchor point.
                        hm... or maybe it won't be a problem.... hmm
                        • PixeroP Offline
                          Pixero
                          Ok, what would you suggest.
                          Center of face? Or a window where you can choose like in Profile Builder?
                          http://i.imagehost.org/0489/menu.jpg
                            That's the thing: what would you determine as centre of face for something like this? (or top,left,right,etc...)
                            • PixeroP Offline
                              Pixero
                              Center of bounding box maybe?
                                @thomthom said:
                                [attachment=0:3sro2dfg]<!-- ia0 -->centerofface.png<!-- ia0 -->[/attachment:3sro2dfg]
                                What kind of a quad is that, Thom?
                                  πŸ˜„ The exotic kind. πŸ˜‰
                                  My point was - that when you don't deal with regular quad-faces - it's much harder to predict desired result.
                                    The thing is - would picking the "centre" (however it's defined) be any different, as just picking the first vertex I can get? At all seem rather arbitrary in terms of the result.
                                      @pixero said:
                                      Would it be possible to have an option for it to automagicly recognise the lenght direction based on witch side is longest on a quad and rotate it to match that.
                                      Like if I want to rotate some UVs on a branch to line up the texture with the trees branches length direction. Would be cool.
                                      Am I making myself clear? πŸ˜•
                                      Are we talking about rotating on quads strictly? I was under the impression this would be a general purpose rotation.
                                      • PixeroP Offline
                                        Pixero
                                          Can you show a little screenshot of your starting point and your desired result?
                                            There's a 'Center of Gravity' script somewhere - 'centroid.rb' - by TBD that adds a cpoint at the CoG of a face.
                                            I can't find it so here it is againcentroid.rb
                                            • 6
                                            • 7
                                            • 18
                                            • 19
                                            • 5 / 19
