    [Plugin] UV Toolkit
    377 Posts 86 Posters 415.1k Views 86 Watching
      @pixero said:
      First, an option to keep the scale of a texture when rotating.
      That's a mighty small image there... can't see much what's going on.
      The rotate feature is meant for textures stretched to fit quad-faces. Special purpose rotate. SU already got rotate methods built in - When you activate SU's texture gizmo - you have a Rotate sub-menu.
      • PixeroP
        Pixero
        Here's my two requests for a great tool:
        http://imagecloset.com/28/a429772e52af5cc3266b8d5eb74ce6f3/UVrotate.jpg
        Second, add it to the right click menu for easier access.
        Edit: Fixed the image size. πŸ˜’
        • PixeroP
          Pixero
          Still its great to be able to select a bunch of faces and rotate at the same time.
          You cant do that with SU's build in tools can you?
            No you can't. Good point. I could add that feature. πŸ‘
            • PixeroP
              Pixero
              I'm using it to rotate the texture on leaves on trees so doing it manually isn't an option. πŸ˜‰
              And don't forget the right click menu...
                Only thing though, about which points should it rotate...?
                • PixeroP
                  Pixero
                  Can't you just swap the UV "scale"?
                  I mean like it is now but with an option to keep the scale on the X and Y axis.
                  (Rotating the points so that Points A,B,C,D would be D,A,B,C or something like that.)
                    There is no such fixed points. The one for the quad-faces works like that because you can use the four vertices of the face. But you can't do that when you have differently shaped faces and/or want to preserve scale.
                    With SU, you have to generate the set of points yourself and query the face. So when rotating, I need one anchor point.
                      hm... or maybe it won't be a problem.... hmm
                      • PixeroP
                        Pixero
                        Ok, what would you suggest.
                        Center of face? Or a window where you can choose like in Profile Builder?
                        http://i.imagehost.org/0489/menu.jpg
                          That's the thing: what would you determine as centre of face for something like this? (or top,left,right,etc...)
                          • PixeroP
                            Pixero
                            Center of bounding box maybe?
                            • GaieusG
                              @thomthom said:
                              [attachment=0:3sro2dfg]<!-- ia0 -->centerofface.png<!-- ia0 -->[/attachment:3sro2dfg]
                              What kind of a quad is that, Thom?
                                πŸ˜„ The exotic kind. πŸ˜‰
                                My point was - that when you don't deal with regular quad-faces - it's much harder to predict desired result.
                                  The thing is - would picking the "centre" (however it's defined) be any different, as just picking the first vertex I can get? At all seem rather arbitrary in terms of the result.
                                    @pixero said:
                                    Would it be possible to have an option for it to automagicly recognise the lenght direction based on witch side is longest on a quad and rotate it to match that.
                                    Like if I want to rotate some UVs on a branch to line up the texture with the trees branches length direction. Would be cool.
                                    Am I making myself clear? πŸ˜•
                                    Are we talking about rotating on quads strictly? I was under the impression this would be a general purpose rotation.
                                    • PixeroP
                                      Pixero
                                        Can you show a little screenshot of your starting point and your desired result?
                                          There's a 'Center of Gravity' script somewhere - 'centroid.rb' - by TBD that adds a cpoint at the CoG of a face.
                                          I can't find it so here it is againcentroid.rb
                                          • PixeroP
                                            Pixero
                                            See image in my updated post above.
                                            • 18
                                            • 19
                                            • 5 / 19
