    [Plugin] UV Toolkit
    377 Posts 86 Posters 398.4k Views 86 Watching
      Jim
      Looking at your UV Tools, you are shifting the positions of points in 2 arrays. Is it as simple using a rotation on the arrays (around face.normal at face.bounds.center, maybe) instead of shifting? I'll try that.
        I don't quite remember what I did. But what I do is somewhat special for quad-faces with textures stretched to fit.
        Think you need some different handling for a general rotate method...
          Jim
          It works for square textures (where the image is square) but distorts rectangular ones.
            I think what you need to do is sample four points in a quadratic formation of the face's plane and then shift the 3Dpoints.
              @pixero said:
              First, an option to keep the scale of a texture when rotating.
              That's a mighty small image there... can't see much what's going on.
              The rotate feature is meant for textures stretched to fit quad-faces. Special purpose rotate. SU already got rotate methods built in - When you activate SU's texture gizmo - you have a Rotate sub-menu.
              • PixeroP
                Pixero
                Here's my two requests for a great tool:
                http://imagecloset.com/28/a429772e52af5cc3266b8d5eb74ce6f3/UVrotate.jpg
                Second, add it to the right click menu for easier access.
                Edit: Fixed the image size. 😒
                • PixeroP
                  Pixero
                  Still its great to be able to select a bunch of faces and rotate at the same time.
                  You cant do that with SU's build in tools can you?
                    No you can't. Good point. I could add that feature. 👍
                    • PixeroP
                      Pixero
                      I'm using it to rotate the texture on leaves on trees so doing it manually isn't an option. 😉
                      And don't forget the right click menu...
                        Only thing though, about which points should it rotate...?
                        • PixeroP
                          Pixero
                          Can't you just swap the UV "scale"?
                          I mean like it is now but with an option to keep the scale on the X and Y axis.
                          (Rotating the points so that Points A,B,C,D would be D,A,B,C or something like that.)
                            There is no such fixed points. The one for the quad-faces works like that because you can use the four vertices of the face. But you can't do that when you have differently shaped faces and/or want to preserve scale.
                            With SU, you have to generate the set of points yourself and query the face. So when rotating, I need one anchor point.
                              hm... or maybe it won't be a problem.... hmm
                              • PixeroP
                                Pixero
                                Ok, what would you suggest.
                                Center of face? Or a window where you can choose like in Profile Builder?
                                http://i.imagehost.org/0489/menu.jpg
                                  That's the thing: what would you determine as centre of face for something like this? (or top,left,right,etc...)
                                  • PixeroP
                                    Pixero
                                    Center of bounding box maybe?
                                    • GaieusG
                                      @thomthom said:
                                      [attachment=0:3sro2dfg]<!-- ia0 -->centerofface.png<!-- ia0 -->[/attachment:3sro2dfg]
                                      What kind of a quad is that, Thom?
                                        😄 The exotic kind. 😉
                                        My point was - that when you don't deal with regular quad-faces - it's much harder to predict desired result.
                                          The thing is - would picking the "centre" (however it's defined) be any different, as just picking the first vertex I can get? At all seem rather arbitrary in terms of the result.
                                            @pixero said:
                                            Would it be possible to have an option for it to automagicly recognise the lenght direction based on witch side is longest on a quad and rotate it to match that.
                                            Like if I want to rotate some UVs on a branch to line up the texture with the trees branches length direction. Would be cool.
                                            Am I making myself clear? 😕
                                            Are we talking about rotating on quads strictly? I was under the impression this would be a general purpose rotation.
                                            • 18
                                            • 19
                                            • 5 / 19
