    [Plugin] UV Toolkit
    377 Posts 86 Posters 415.1k Views 86 Watching
      I don't quite remember what I did. But what I do is somewhat special for quad-faces with textures stretched to fit.
      Think you need some different handling for a general rotate method...
        Jim
        It works for square textures (where the image is square) but distorts rectangular ones.
          I think what you need to do is sample four points in a quadratic formation of the face's plane and then shift the 3Dpoints.
            @pixero said:
            First, an option to keep the scale of a texture when rotating.
            That's a mighty small image there... can't see much what's going on.
            The rotate feature is meant for textures stretched to fit quad-faces. Special purpose rotate. SU already got rotate methods built in - When you activate SU's texture gizmo - you have a Rotate sub-menu.
            • PixeroP
              Pixero
              Here's my two requests for a great tool:
              http://imagecloset.com/28/a429772e52af5cc3266b8d5eb74ce6f3/UVrotate.jpg
              Second, add it to the right click menu for easier access.
              Edit: Fixed the image size. πŸ˜’
              • PixeroP
                Pixero
                Still its great to be able to select a bunch of faces and rotate at the same time.
                You cant do that with SU's build in tools can you?
                  No you can't. Good point. I could add that feature. πŸ‘
                  • PixeroP
                    Pixero
                    I'm using it to rotate the texture on leaves on trees so doing it manually isn't an option. πŸ˜‰
                    And don't forget the right click menu...
                      Only thing though, about which points should it rotate...?
                      • PixeroP
                        Pixero
                        Can't you just swap the UV "scale"?
                        I mean like it is now but with an option to keep the scale on the X and Y axis.
                        (Rotating the points so that Points A,B,C,D would be D,A,B,C or something like that.)
                          There is no such fixed points. The one for the quad-faces works like that because you can use the four vertices of the face. But you can't do that when you have differently shaped faces and/or want to preserve scale.
                          With SU, you have to generate the set of points yourself and query the face. So when rotating, I need one anchor point.
                            hm... or maybe it won't be a problem.... hmm
                            • PixeroP
                              Pixero
                              Ok, what would you suggest.
                              Center of face? Or a window where you can choose like in Profile Builder?
                              http://i.imagehost.org/0489/menu.jpg
                                That's the thing: what would you determine as centre of face for something like this? (or top,left,right,etc...)
                                • PixeroP
                                  Pixero
                                  Center of bounding box maybe?
                                  • GaieusG
                                    @thomthom said:
                                    [attachment=0:3sro2dfg]<!-- ia0 -->centerofface.png<!-- ia0 -->[/attachment:3sro2dfg]
                                    What kind of a quad is that, Thom?
                                      πŸ˜„ The exotic kind. πŸ˜‰
                                      My point was - that when you don't deal with regular quad-faces - it's much harder to predict desired result.
                                        The thing is - would picking the "centre" (however it's defined) be any different, as just picking the first vertex I can get? At all seem rather arbitrary in terms of the result.
                                          @pixero said:
                                          Would it be possible to have an option for it to automagicly recognise the lenght direction based on witch side is longest on a quad and rotate it to match that.
                                          Like if I want to rotate some UVs on a branch to line up the texture with the trees branches length direction. Would be cool.
                                          Am I making myself clear? πŸ˜•
                                          Are we talking about rotating on quads strictly? I was under the impression this would be a general purpose rotation.
                                          • PixeroP
                                            Pixero
                                            • 18
                                            • 19
                                            • 5 / 19
