[Plugin][$] FredoScale - v3.6a - 01 Apr 24
What bug? Your screen shot doesn't clearly indicate a problem.
the menu bar is small and i can't resize it. I must scroll every time to see all options / results.
This bug appear only on "Labels with areas". The same problem on my PC and my laptop. -
So this has nothing to do with FredoScale.
@gudio83 said:
Any idea how to resolve this bug?
SU2017 x64, Win10SU2017 has changed a few things in the dimensioning of web dialogs.
Normally, you should be able to resize and adjust the size, which would be kept for the next use.
I just have one doubt: not sure I released the fix in FredoTools 3.0a (i.e. the capability to resize the dialog box).
First of all that you for the best plugin in sketchup. Enginsh is not my native language so I record this short clip to explain my problem.
When I copy group of objects and start to stretching one of them I'm getting this conflict.
I know there is problem with components when they all not unique but why with groups ?
It was fine before format of windows with different versions of plugin.
For now i'm using Sketchup 2016 and latest plugin with libs.Kind Regards
Patrickps. Sorry if this is noob question.
In Sketchup, a group just copied behaves like Components...
...unless you just edit (i.e. double click) the group you copied.
This is probably for optimization.
Fredo
Fredo
Hi, thanks for the answer . Before I have never have this problem, I found small fix on this "model" by removing group of objects inside this group.
I installed the last version but I have only the "box" tools, no "target" tools. Any ideas?
They don't show even after you enabled them and restarted SketchUp?
Is there a way to get the dimension tags to update after you resize using the 'box stretching' feature? At the moment I re-add them manually to get them to update to the correct measurement.
Thanks for this great plugin Fredo.
@georgeoakblaster said:
Thanks,
I should have mentioned this is when using 'enter new dimensions' which is on the right click dialogue box.
George
Maybe you could post a screen shot of what you are trying to describe because it isn't clear.
The New Dimension window is intended to allow you to type in the new dimension.
What is the "dimension tag" you refer to?
Hey guys. I've recently discovered radial bend and its just brilliant. Its really helping me with some illustrations I'm doing. I was wondering if there's a way for the materials to bend as well as the model. So far the materials either stay the same or go a bit skew-whiff, they don't bend in the same directions as the face they're on. Any way of doing this?
Unfortunately, Radial Bend creates a lot of new faces and triangulation due to slicing. So, reconstructing the original texturing would be kind of big headache!
In general, texturing should be done on final shapes.Fredo
Ok thanks Fredo. That's good to know
Why?
https://youtu.be/FgNyfpZPVfARobert
@robertwan said:
Why?
'By default', FredoScale Stretching makes the component unique before operating on it.
The issue is that I did not provision an option to apply to all instances instead.Fredo
Is there any way around it? I expect so. Upload your SKP so we can see what you've got so far.
