    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 343 Posters 2.3m Views 340 Watching
      I was with a guy who had SU 8 : Radial Bending don't display the orange horizontal lines and makes not the rounding volume : only an inclined volume! ๐Ÿ˜ฎ
      • fredo6F Offline
        fredo6
        I think he needs to activate the dicer
        • press F4
        • or Contextual menu
        Fredo
          What is a dicer ?
            @pilou said:
            What is a dicer ?
            Sort of a mandoline. ๐Ÿ˜„
              "a sort of mandoline"
              the little cuting rakes ?
              https://files.meilleurduchef.com/mdc/photo/produit/bck/mandoline-du-chef/mandoline-du-chef-1-640.jpg
              More abstract for that! ๐Ÿ˜„
              http://www.woodbrass.com/images/woodbrass/SANTOS+Y+MAYOR+MANDOLINE.JPG
                The first one is what I was referring to although if you could push it through the strings of the second one, you'd get a similar result. ๐Ÿ˜„
                  Sure but more difficult to extract slices of cucumber falling inside! ๐Ÿ’š
                    Good point. ๐Ÿ˜„
                    • P Offline
                      penumbra
                      Fredo,
                      latest release seems to have an issue that at the end of stretching operation and click outside of group, instead of accepting the scale change it springs back to original shape, when I repeat the operation a second time, then the change is accepted. is happening consistently on every drawing.
                      I am on SU 2015, windows 7.
                      Any thoughts?
                      Thanks.
                        I just tried and I'm not seeing it. Could you upload an SKP file in which this happens?
                        • P Offline
                          penumbra
                          File attached. If you don't see the behavior when trying to stretch any of the building elements you see here then I must have interference from another plugin.
                          Stretching.skp
                            Which direction are you trying to stretch them in?
                              Actually, I do see it in your model when I try stretching the large building.
                              • P Offline
                                penumbra
                                I use the scale to target tool and also I invoke the input dialog box via the TAB key. Either way the issue exists in any stretching direction.
                                • P Offline
                                  penumbra
                                  Thanks for looking at it. And now for the great search of the other offending plugin... How I wish there was a quicker way to detect and find plugin clashes.
                                  Edit: On second thought. If Dave is seeing it also then there is a little issue with the plugin? Unless Dave and I have a similar plugin clashing with it?
                                    I think we need Fredo's input.
                                    • fredo6F Offline
                                      fredo6
                                      Thanks for signaling. This is a side effect of the fix for bugsplat in SU2017.
                                      I fixed it and will re-publish.
                                      By the way, the fact that it work the second time is due to the fact that the first time, FredoScale chains two operations
                                      • Make Unique
                                      • Stretching
                                      The bug was due to an unvolontary Undo, but the make Unique remained, so that it works fine the second time.
                                      Fredo
                                      • P Offline
                                        penumbra
                                        Thanks fredo.
                                        • fredo6F Offline
                                          fredo6
                                          NEW RELEASE: FredoScale v3.0a - 14 Jan 17
                                          FredoScale 3.0a is a maintenance release providing corrections to previous versions, and should be installed for all SU Versions.
                                          See main post of this thread for Download.
                                          Fredo
                                          • gudio83G Offline
                                            gudio83
                                            Any idea how to resolve this bug?
                                            SU2017 x64, Win10
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 56
                                            • 57
                                            • 46 / 57
