    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.2k Posts 346 Posters 2.9m Views 344 Watching
      Actually, I do see it in your model when I try stretching the large building.
        penumbra
        I use the scale to target tool and also I invoke the input dialog box via the TAB key. Either way the issue exists in any stretching direction.
          penumbra
          Thanks for looking at it. And now for the great search of the other offending plugin... How I wish there was a quicker way to detect and find plugin clashes.
          Edit: On second thought. If Dave is seeing it also then there is a little issue with the plugin? Unless Dave and I have a similar plugin clashing with it?
            I think we need Fredo's input.
            • fredo6F Offline
              Thanks for signaling. This is a side effect of the fix for bugsplat in SU2017.
              I fixed it and will re-publish.
              By the way, the fact that it work the second time is due to the fact that the first time, FredoScale chains two operations
              • Make Unique
              • Stretching
              The bug was due to an unvolontary Undo, but the make Unique remained, so that it works fine the second time.
                penumbra
                Thanks fredo.
                • fredo6F Offline
                  NEW RELEASE: FredoScale v3.0a - 14 Jan 17
                  FredoScale 3.0a is a maintenance release providing corrections to previous versions, and should be installed for all SU Versions.
                  • gudio83G Offline
                    gudio83
                    Any idea how to resolve this bug?
                    SU2017 x64, Win10
                      What bug? Your screen shot doesn't clearly indicate a problem.
                      • gudio83G Offline
                        gudio83
                        the menu bar is small and i can't resize it. I must scroll every time to see all options / results.
                        This bug appear only on "Labels with areas". The same problem on my PC and my laptop.
                          So this has nothing to do with FredoScale.
                          • fredo6F Offline
                            SU2017 x64, Win10
                            SU2017 has changed a few things in the dimensioning of web dialogs.
                            Normally, you should be able to resize and adjust the size, which would be kept for the next use.
                            I just have one doubt: not sure I released the fix in FredoTools 3.0a (i.e. the capability to resize the dialog box).
                            • E Offline
                              elfis
                              First of all that you for the best plugin in sketchup. Enginsh is not my native language so I record this short clip to explain my problem.
                              When I copy group of objects and start to stretching one of them I'm getting this conflict.
                              I know there is problem with components when they all not unique but why with groups ?
                              It was fine before format of windows with different versions of plugin.
                              For now i'm using Sketchup 2016 and latest plugin with libs.
                              Kind Regards
                              Patrick
                              ps. Sorry if this is noob question.
                              • fredo6F Offline
                                In Sketchup, a group just copied behaves like Components...
                                ...unless you just edit (i.e. double click) the group you copied.
                                This is probably for optimization.
                                • E Offline
                                  elfis
                                  Hi, thanks for the answer . Before I have never have this problem, I found small fix on this "model" by removing group of objects inside this group.
                                  Group Tree
                                  • array81A Offline
                                    array81
                                    I installed the last version but I have only the "box" tools, no "target" tools. Any ideas?
                                      They don't show even after you enabled them and restarted SketchUp?
                                        georgeoakblaster
                                        Is there a way to get the dimension tags to update after you resize using the 'box stretching' feature? At the moment I re-add them manually to get them to update to the correct measurement.
                                        Thanks for this great plugin Fredo.
                                          @georgeoakblaster said:
                                          Like this?
                                            georgeoakblaster
                                            Thanks,
                                            I should have mentioned this is when using 'enter new dimensions' which is on the right click dialogue box.
                                            George
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 57
                                            • 58
                                            • 47 / 58
