    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • E
      elfis
      @fredo6 said:
      In Sketchup, a group just copied behaves like Components...
      ...unless you just edit (i.e. double click) the group you copied.
      This is probably for optimization.
      Hi, thanks for the answer . Before I have never have this problem, I found small fix on this "model" by removing group of objects inside this group.
      Group Tree
      • array81A
        array81
        I installed the last version but I have only the "box" tools, no "target" tools. Any ideas?
          They don't show even after you enabled them and restarted SketchUp?
          • G
            georgeoakblaster
            Is there a way to get the dimension tags to update after you resize using the 'box stretching' feature? At the moment I re-add them manually to get them to update to the correct measurement.
            Thanks for this great plugin Fredo.
              @georgeoakblaster said:
              Like this?
              • G
                georgeoakblaster
                Thanks,
                I should have mentioned this is when using 'enter new dimensions' which is on the right click dialogue box.
                George
                  Maybe you could post a screen shot of what you are trying to describe because it isn't clear.
                  The New Dimension window is intended to allow you to type in the new dimension.
                  What is the "dimension tag" you refer to?
                  • K
                    kevsterman
                    Hey guys. I've recently discovered radial bend and its just brilliant. Its really helping me with some illustrations I'm doing. I was wondering if there's a way for the materials to bend as well as the model. So far the materials either stay the same or go a bit skew-whiff, they don't bend in the same directions as the face they're on. Any way of doing this?
                    "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                    • fredo6F
                      Unfortunately, Radial Bend creates a lot of new faces and triangulation due to slicing. So, reconstructing the original texturing would be kind of big headache!
                      In general, texturing should be done on final shapes.
                      • K
                        kevsterman
                        Ok thanks Fredo. That's good to know πŸ‘
                        • K
                          kevsterman
                          Hi guys. I have another question regarding radial bend. As you can see from the image all of the lines denoting brickwork haven't bended as I was expecting. I'm not sure why. Is it a parameter problem or maybe something to do with the model? Its probably something really easy I'm missing πŸ˜•
                          • robertWanR
                            robertWan
                            Why? 😞
                            https://youtu.be/FgNyfpZPVfA
                            Robert
                            • fredo6F
                              @robertwan said:
                              Why? 😞
                              Robert
                              'By default', FredoScale Stretching makes the component unique before operating on it.
                              The issue is that I did not provision an option to apply to all instances instead.
                                Is there any way around it? I expect so. Upload your SKP so we can see what you've got so far.
                                • L
                                  Lorand
                                  File attached.
                                  FScale test.skp
                                  • L
                                    Lorand
                                    Hi all,
                                    Great plugin like all Fredo6 ones, thank you sir.
                                    Problem: Imagine a simple Chinese lamp - equilateral triangles at the top and bottom and FredoScale TWIST for elegantly getting the surfaces between them - but the TWIST function twists around the axis of the boundary box not the axis through the centers of the bottom and top triangles and the result is skewed. Same goes for any odd sided polygons: those two centers are different. Is there any way to use TWIST and get the "expected" result?
                                    Thank you in advance,
                                    Lorand
                                      I see what you're getting at. It happens with shapes whose sections have an odd number of sides. It's due to the way they fit in their bounding box. I don't know if it's something Fredo can modify but an immediate solution to get around it is to put the triangle in the center of a square.
                                      • L
                                        Lorand
                                        Nice idea, thank you. Lorand
                                          jtri
                                          I am using the Radial Bend tool to model a "splayed" end of an object. A couple of questions. I know it is just a few steps to copy and flip a face and then finish the end, but was wondering if I missed a command in the tool that would allow this to be done off a center line so that you could use a model, bend one face and the opposite face would bend the same but in the opposite direction? If there a better tool I should consider for this type of modeling please let me know.
                                          Thanks for a great tool and all the support
                                          Splay end.skp
                                            I don't know of a tool that would do what you ask. I think using an extension to bend the surface would be more work than just drawing the curves before extruding it.
                                            By the way, how did you draw this and manage to get all the faces inside out?
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 58
                                            • 59
                                            • 47 / 59
