[Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
My last working release is 15.8.b. I need FredoScale. But this is working only with 15.9.d. and higher. Unfortunately, when I install 16.2. version all plugins stop to work. I menitoned it above. would like to install version 15.9.d, but I can not find this version anywhere. Is possible to download it somewhere?
Here is my error message:
Error Loading File Fredo6_!LibFredo6.rb Error: #<NameError: uninitialized constant Traductor> c:/users/mcesak/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:362:in `startup' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:143:in `process' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:151:in `<module:LibFredo6_Loader>' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in `<top (required)>' Error Loading File Fredo6_Curviloft.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `-' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:47:in `<module:Fredo6>' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>' Error Loading File Fredo6_FredoScale.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `-' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in `<module:Fredo6>' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in `<top (required)>' Error Loading File Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `-' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in `<module:Fredo6>' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>' Error Loading File Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `-' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in `<module:Fredo6>' C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>' -
Not here. Only recent versions are hosted.
You seem to have a wrong installation of LibFredo6 v16.3b.
Open the Ruby console and copy / paste UI.openURL LibFredo6.sudir.
I will open the Windows Explorer in the Sketchup Plugin directory.
Locate the folder Fredo6_!LibFredo6 and erase it.
Then reinstall LibFredo6
By the way, it will also useful that you give us the content of what appears in the Ruby console when you invoke the menu Window > LibFredo6 Settings .... > Fredo6 Plugins Information for Sketcucation Support.
After deleting the folder
Fredo6_!LibFredo6and reinstalling the plugin, the folder reappears, and the issue remains unresolved. In the "Fredo6 Plugins Information for SketchUcation Support" section, the console output looks like this:
The SketchUcation tools is not installed get its RBZ from the PluginStore, then install it using the Extension Manager...
It installs the SCFLicensing stuff with it... -
Could you please seelct the text IN the Ruby console and copy / paste it here. This will help to have a global view on your installation.
I tried three different versions of LibFredo6. The version 15.8 b. On this version works all other plugins, except FredoScale, which I really need. On version 16.1 g, I can see Icons of FredoScale, but no one plugins is working. I can click on icon, but they are inactive. When I install version 16.2 or higher the icons of all plugins disappears and ruby console is empty. Aaaaarch. I delete LibFredo6 from root directory, but nothing help.
@fredo6
Here is what is in ruby console. I dont know why is this not loaded. May be this is the problem. But how can I fix it? - LibFredo6 E6 Binary NOT loaded -
Can you pleae select the text in the Ruby console and paste it here as text, no as screen capture.
I cannot help with partial information.
Thanks.
Hi! I can't install the plugin, it allways stays like this (see image), can somebody help me? thank you! !
What plugin are you trying to install? I can't see anything related to a problem with an extension in your screenshot. I do see you are using tags incorrectly but that doesn't have anything to do with installing extensions.
As Dave says, your posts in the LibFredo6 thread says nothing about that ?
It does nothing on its own, but supports most of Fredo6's extensions.
If you are having problems with one of his extensions please post in its thread, and explain what the problem is with at least some clues so we can try and help you.
Also - as Dave points out - you have your active Tag [previously called 'layers'] set up wrongly - named 'Etiquetas' in your language. All geometry -i.e. edges and faces - should be made/associated with 'Untagged' - i.e. 'Sin etiqueta' - you can then assign different Tags to selected groups and component-instances, using the Entity Info panel ['InformaciĂłn de la entidad'] - later it can be used to control their visibility whilst modelling and editing... -
Hello Fredo6,
I am using SketchUp 2026 on macOS with TopoShaper 2.7b and LibFredo6 15.9c.
TopoShaper fails when analysing the initial selection. The Ruby Console reports:
NameError: undefined local variable or method 'accept_current_selection'
I tried to download LibFredo6 16.3b from the official SketchUcation page, but the download reports a database connection error. The file page also shows a size of 0.00 MB, and clicking Download leads to a “File does not exist” message for LibFredo6.rbz.
Could you please check the download link and advise whether LibFredo6 16.3b fixes this selection error on SketchUp 2026 for Mac?
Thank you.
Hello Fredo6,
Thank you.
The installation did not work for me. I received an error message when I tried to use the add command. Any ideas?
Ruby error message :
Fredo6 Plugins Information on 2026-10-27 12:42:22 +0100
- Platform: x64-mswin64_140 - Ruby: 3.2.2
- Sketchup: 25.0.571
- LibFredo6: v16.3b
- LibFredo6 E6 Binary loaded
- LibFredo6 W6 Binary loaded
- LibFredo6 H6 Binary loaded
- Sketchucation Tools: 5.0.8
#<NoMethodError: undefined methodcall' for nil:NilClass> c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:190:inSHGetFolderPathW'
c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:134:inget_system_dir' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:102:inget_localappdata_dir'
c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:340:intransfer_to_public' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:380:ininitialize'
c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:innew' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:indynamic_token'
C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rb6:860:ininfo' C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb6:382:inblock in populate_support_menu'
C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb6:1573:in `block in add_command'
Register LoginAdvertisement
