    [Plugin Library] LibFredo6 - v16.4a - 11 Nov 26
    2.3k Posts 593 Posters 13.9m Views 595 Watching
    • B
      Bajwa
      I am facing issues using Fredo scale plugin and thru paint issues just like before version 16.a but then it resolved and I install new versions of all Fredo plugins avilable on skechucation and Fredo library as well now problem is Fredo plugins are not working properly at all especially Fredo scale and thru paint I have paid licences of both and it is not recognizes the licence on every turning on of my PC as well I tried installing new version of extension store tool as well
      Can u please help me or give me RBZ file of libfredo 16.a so that I can use smoothly
      I have 4 version installed in my PC 21 24 25 and 26 skechup's
      B 1 Reply Last reply
      • B
        Bublifuk21 @Dave R
        @Dave-R unfortunately, it does not work for me. I have installed Extensionstore v5.0.8., but I see only button continue, but it not work. I think, there is problem may be with firewall, or something like that, because my PC is in domain, which is not directly on internet. But all other updates are function normally. Sketchucation.jpg
        • B
          Bajwa @Bajwa
          @fredo6
          @tig
          • fredo6F
            NEW RELEASE: LibFredo6 v16.3a - 20 Oct 26
            LibFredo6 16.3a is a maintenance release. It includes changes related to:
            • Compatibility SU2027
            • Bug Fixing
            If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.1a. Otherwise, LOTT will not be activated
            1 Reply Last reply 😊
            • fredo6F
              NEW RELEASE: LibFredo6 v16.3b - 21 Oct 26
              • Fix for FredoTools which may not work with v16.3a
              • Bug Fixing
              If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.2a. Otherwise, LOTT will not be activated
              B 1 Reply Last reply πŸ™
              • B
                Bublifuk21 @fredo6
                @fredo6 Dear fredo6, the new release 16.3b absolutely doesn not work for me. I am so sad.
                  Rich O Brien Moderator @Bublifuk21
                  That's rather vague. Please provide more concise information.
                  • B
                    Bublifuk21
                    My last working release is 15.8.b. I need FredoScale. But this is working only with 15.9.d. and higher. Unfortunately, when I install 16.2. version all plugins stop to work. I menitoned it above. would like to install version 15.9.d, but I can not find this version anywhere. Is possible to download it somewhere?
                    • B
                      Bublifuk21
                      Here is my error message:
                      Error Loading File Fredo6_!LibFredo6.rb
                      Error: #<NameError: uninitialized constant Traductor>
                      c:/users/mcesak/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:362:in `startup'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:143:in `process'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:151:in `<module:LibFredo6_Loader>'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in `<top (required)>'
                      Error Loading File Fredo6_Curviloft.rb
                      Error: #<TypeError: can't convert nil into an exact number>
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `-'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `<top (required)>'
                      C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:47:in `<module:Fredo6>'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>'
                      Error Loading File Fredo6_FredoScale.rb
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in `<module:Fredo6>'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in `<top (required)>'
                      Error Loading File Fredo6_JointPushPull.rb
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in `<module:Fredo6>'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
                      Error Loading File Fredo6_RoundCorner.rb
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in `<module:Fredo6>'
                      C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                      fredo6F 1 Reply Last reply
                        Not here. Only recent versions are hosted.
                        • fredo6F
                          fredo6 @Bublifuk21
                          @Bublifuk21
                          You seem to have a wrong installation of LibFredo6 v16.3b.
                          Open the Ruby console and copy / paste UI.openURL LibFredo6.sudir.
                          I will open the Windows Explorer in the Sketchup Plugin directory.
                          Locate the folder Fredo6_!LibFredo6 and erase it.
                          Then reinstall LibFredo6
                          By the way, it will also useful that you give us the content of what appears in the Ruby console when you invoke the menu Window > LibFredo6 Settings .... > Fredo6 Plugins Information for Sketcucation Support.
                          Dave RD 1 Reply Last reply
                            Dave R @fredo6
                            @fredo6 should it be
                            without the final period?
                            • fredo6F
                              fredo6 @Dave R
                              Yes, definitely. Good you point it out,
                                maria0p03 Newcomers
                                After deleting the folder Fredo6_!LibFredo6 and reinstalling the plugin, the folder reappears, and the issue remains unresolved. In the "Fredo6 Plugins Information for SketchUcation Support" section, the console output looks like this:
                                TIGT fredo6F 2 Replies Last reply
                                  TIG Moderator @maria0p03
                                  @maria0p03
                                  The SketchUcation tools is not installed get its RBZ from the PluginStore, then install it using the Extension Manager...
                                  It installs the SCFLicensing stuff with it...
                                  • fredo6F
                                    fredo6 @maria0p03
                                    @maria0p03
                                    Could you please seelct the text IN the Ruby console and copy / paste it here. This will help to have a global view on your installation.
                                    • B
                                      Bublifuk21
                                      I tried three different versions of LibFredo6. The version 15.8 b. On this version works all other plugins, except FredoScale, which I really need. On version 16.1 g, I can see Icons of FredoScale, but no one plugins is working. I can click on icon, but they are inactive. When I install version 16.2 or higher the icons of all plugins disappears and ruby console is empty. Aaaaarch. I delete LibFredo6 from root directory, but nothing help.
                                      • B
                                        Bublifuk21 @fredo6
                                        Here is what is in ruby console. I dont know why is this not loaded. May be this is the problem. But how can I fix it? - LibFredo6 E6 Binary NOT loaded
                                        • fredo6F
                                          fredo6 @Bublifuk21
                                          @Bublifuk21
                                          Can you pleae select the text in the Ruby console and paste it here as text, no as screen capture.
                                          I cannot help with partial information.
                                          Thanks.
                                            dingom
                                            Hi! I can't install the plugin, it allways stays like this (see image), can somebody help me? thank you! !problem.jpg
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 115 / 116
