    [Plugin Library] LibFredo6 - v16.4a - 11 Nov 26
    2.3k Posts 593 Posters 13.9m Views 595 Watching
      Rich O Brien Moderator @Bublifuk21
      @Bublifuk21 said:
      absolutely doesn not work for me
      That's rather vague. Please provide more concise information.
      • B
        Bublifuk21
        My last working release is 15.8.b. I need FredoScale. But this is working only with 15.9.d. and higher. Unfortunately, when I install 16.2. version all plugins stop to work. I menitoned it above. would like to install version 15.9.d, but I can not find this version anywhere. Is possible to download it somewhere?
        • B
          Bublifuk21
          Here is my error message:
          Error Loading File Fredo6_!LibFredo6.rb
          Error: #<NameError: uninitialized constant Traductor>
          c:/users/mcesak/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:362:in `startup'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:143:in `process'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:151:in `<module:LibFredo6_Loader>'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in `<top (required)>'
          Error Loading File Fredo6_Curviloft.rb
          Error: #<TypeError: can't convert nil into an exact number>
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `-'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `<top (required)>'
          C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:47:in `<module:Fredo6>'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>'
          Error Loading File Fredo6_FredoScale.rb
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in `<module:Fredo6>'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in `<top (required)>'
          Error Loading File Fredo6_JointPushPull.rb
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in `<module:Fredo6>'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
          Error Loading File Fredo6_RoundCorner.rb
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in `<module:Fredo6>'
          C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
          fredo6F 1 Reply Last reply
            Not here. Only recent versions are hosted.
            • fredo6F
              fredo6 @Bublifuk21
              @Bublifuk21
              You seem to have a wrong installation of LibFredo6 v16.3b.
              Open the Ruby console and copy / paste UI.openURL LibFredo6.sudir.
              I will open the Windows Explorer in the Sketchup Plugin directory.
              Locate the folder Fredo6_!LibFredo6 and erase it.
              Then reinstall LibFredo6
              By the way, it will also useful that you give us the content of what appears in the Ruby console when you invoke the menu Window > LibFredo6 Settings .... > Fredo6 Plugins Information for Sketcucation Support.
              Dave RD 1 Reply Last reply
                Dave R @fredo6
                @fredo6 should it be
                without the final period?
                • fredo6F
                  fredo6 @Dave R
                  Yes, definitely. Good you point it out,
                    maria0p03 Newcomers
                    After deleting the folder Fredo6_!LibFredo6 and reinstalling the plugin, the folder reappears, and the issue remains unresolved. In the "Fredo6 Plugins Information for SketchUcation Support" section, the console output looks like this:
                    TIGT fredo6F 2 Replies Last reply
                      TIG Moderator @maria0p03
                      @maria0p03
                      The SketchUcation tools is not installed get its RBZ from the PluginStore, then install it using the Extension Manager...
                      It installs the SCFLicensing stuff with it...
                      • fredo6F
                        fredo6 @maria0p03
                        @maria0p03
                        Could you please seelct the text IN the Ruby console and copy / paste it here. This will help to have a global view on your installation.
                        B 1 Reply Last reply
                        • B
                          Bublifuk21
                          I tried three different versions of LibFredo6. The version 15.8 b. On this version works all other plugins, except FredoScale, which I really need. On version 16.1 g, I can see Icons of FredoScale, but no one plugins is working. I can click on icon, but they are inactive. When I install version 16.2 or higher the icons of all plugins disappears and ruby console is empty. Aaaaarch. I delete LibFredo6 from root directory, but nothing help.
                          • B
                            Bublifuk21 @fredo6
                            Here is what is in ruby console. I dont know why is this not loaded. May be this is the problem. But how can I fix it? - LibFredo6 E6 Binary NOT loaded
                            • fredo6F
                              fredo6 @Bublifuk21
                              @Bublifuk21
                              Can you pleae select the text in the Ruby console and paste it here as text, no as screen capture.
                              I cannot help with partial information.
                              Thanks.
                                dingom
                                Hi! I can't install the plugin, it allways stays like this (see image), can somebody help me? thank you! !problem.jpg
                                  Dave R @dingom
                                  What plugin are you trying to install? I can't see anything related to a problem with an extension in your screenshot. I do see you are using tags incorrectly but that doesn't have anything to do with installing extensions.
                                    As Dave says, your posts in the LibFredo6 thread says nothing about that ?
                                    It does nothing on its own, but supports most of Fredo6's extensions.
                                    If you are having problems with one of his extensions please post in its thread, and explain what the problem is with at least some clues so we can try and help you.
                                    Also - as Dave points out - you have your active Tag [previously called 'layers'] set up wrongly - named 'Etiquetas' in your language. All geometry -i.e. edges and faces - should be made/associated with 'Untagged' - i.e. 'Sin etiqueta' - you can then assign different Tags to selected groups and component-instances, using the Entity Info panel ['InformaciĂłn de la entidad'] - later it can be used to control their visibility whilst modelling and editing...
                                      jesuscarrazoni Newcomers
                                      Hello Fredo6,
                                      I am using SketchUp 2026 on macOS with TopoShaper 2.7b and LibFredo6 15.9c.
                                      TopoShaper fails when analysing the initial selection. The Ruby Console reports:
                                      NameError: undefined local variable or method 'accept_current_selection'
                                      I tried to download LibFredo6 16.3b from the official SketchUcation page, but the download reports a database connection error. The file page also shows a size of 0.00 MB, and clicking Download leads to a “File does not exist” message for LibFredo6.rbz.
                                      Could you please check the download link and advise whether LibFredo6 16.3b fixes this selection error on SketchUp 2026 for Mac?
                                      Thank you.
                                        Hello Fredo6,
                                        Thank you.
                                        • G
                                          goyatea Newcomers
                                          The installation did not work for me. I received an error message when I tried to use the add command. Any ideas?
                                            Rich O Brien Moderator @goyatea
                                            Please share the error message, your SketchUp version and Operating System
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 115 / 116
