    [Plugin Library] LibFredo6 - v16.4a - 11 Nov 26
    2.3k Posts 596 Posters 15.6m Views 598 Watching
    • fredo6F
      fredo6 @maria0p03
      @maria0p03
      Could you please seelct the text IN the Ruby console and copy / paste it here. This will help to have a global view on your installation.
      B 1 Reply Last reply
      • B
        Bublifuk21
        I tried three different versions of LibFredo6. The version 15.8 b. On this version works all other plugins, except FredoScale, which I really need. On version 16.1 g, I can see Icons of FredoScale, but no one plugins is working. I can click on icon, but they are inactive. When I install version 16.2 or higher the icons of all plugins disappears and ruby console is empty. Aaaaarch. I delete LibFredo6 from root directory, but nothing help.
        • B
          Bublifuk21 @fredo6
          Here is what is in ruby console. I dont know why is this not loaded. May be this is the problem. But how can I fix it? - LibFredo6 E6 Binary NOT loaded
          fredo6F 1 Reply Last reply
          • fredo6F
            fredo6 @Bublifuk21
            @Bublifuk21
            Can you pleae select the text in the Ruby console and paste it here as text, no as screen capture.
            I cannot help with partial information.
            Thanks.
              dingom
              Hi! I can't install the plugin, it allways stays like this (see image), can somebody help me? thank you! !problem.jpg
              Dave RD 1 Reply Last reply
                Dave R @dingom
                What plugin are you trying to install? I can't see anything related to a problem with an extension in your screenshot. I do see you are using tags incorrectly but that doesn't have anything to do with installing extensions.
                  As Dave says, your posts in the LibFredo6 thread says nothing about that ?
                  It does nothing on its own, but supports most of Fredo6's extensions.
                  If you are having problems with one of his extensions please post in its thread, and explain what the problem is with at least some clues so we can try and help you.
                  Also - as Dave points out - you have your active Tag [previously called 'layers'] set up wrongly - named 'Etiquetas' in your language. All geometry -i.e. edges and faces - should be made/associated with 'Untagged' - i.e. 'Sin etiqueta' - you can then assign different Tags to selected groups and component-instances, using the Entity Info panel ['Información de la entidad'] - later it can be used to control their visibility whilst modelling and editing...
                    jesuscarrazoni Newcomers
                    Hello Fredo6,
                    I am using SketchUp 2026 on macOS with TopoShaper 2.7b and LibFredo6 15.9c.
                    TopoShaper fails when analysing the initial selection. The Ruby Console reports:
                    NameError: undefined local variable or method 'accept_current_selection'
                    I tried to download LibFredo6 16.3b from the official SketchUcation page, but the download reports a database connection error. The file page also shows a size of 0.00 MB, and clicking Download leads to a “File does not exist” message for LibFredo6.rbz.
                    Could you please check the download link and advise whether LibFredo6 16.3b fixes this selection error on SketchUp 2026 for Mac?
                    Thank you.
                      Hello Fredo6,
                      Thank you.
                      • G
                        goyatea Newcomers
                        The installation did not work for me. I received an error message when I tried to use the add command. Any ideas?
                          Rich O Brien Moderator @goyatea
                          Please share the error message, your SketchUp version and Operating System
                          • G
                            goyatea Newcomers
                            Ruby error message :
                            Fredo6 Plugins Information on 2026-10-27 12:42:22 +0100
                            • Sketchup: 25.0.571
                            • LibFredo6: v16.3b
                            • LibFredo6 E6 Binary loaded
                            • LibFredo6 W6 Binary loaded
                            • LibFredo6 H6 Binary loaded
                            • Sketchucation Tools: 5.0.8
                              #<NoMethodError: undefined method call' for nil:NilClass> c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:190:in SHGetFolderPathW'
                              c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:134:in get_system_dir' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:102:in get_localappdata_dir'
                              c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:340:in transfer_to_public' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:380:in initialize'
                              c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:in new' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:in dynamic_token'
                              C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rb6:860:in info' C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb6:382:in block in populate_support_menu'
                              C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb6:1573:in `block in add_command'
                            • G
                              goyatea Newcomers
                              • fredo6F
                                Somethings is wrong is the installation of Sketchucation Tools.
                                Could you
                                1. go to the Plugin directory: c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins
                                2. Delete the folder Sketchucation
                                3. Reinstall Sketchucation tools from the Sketchucation site
                                Please advise if this does not work.
                                • G
                                  goyatea Newcomers
                                  Thanks, it's working now.
                                  First, I deleted it, then I modified the signature authorisation in the warehouse extension. It was a signature issue.
                                  In SketchUp:
                                  Extensions → Extension Manager
                                  Click the ⚙️ Extension Manager Settings icon.
                                  You'll find “Extension Loading Policy” / “Extension Loading Preferences.”
                                  Select:
                                  “Approve Unidentified Extensions”
                                  Restart SketchUp.
                                  • I
                                    ID3D
                                    Bonjour
                                    Avec la version 16.3b la fenêtre traduction n'apparait plus sur tout les plugins frtedo6
                                    • fredo6F
                                      fredo6 @ID3D
                                      @ID3D
                                      which plugins for instance?
                                      • B
                                        Bublifuk21 @fredo6
                                        @fredo6 please find attached.
                                        Fredo6 Plugins Information on 2026-11-06 09:14:12 +0100
                                        • Platform: x64-mingw32 - Ruby: 2.2.4
                                        • Sketchup: 17.2.2555
                                        • LibFredo6: v16.1g
                                        • LibFredo6 G6 Binary loaded
                                        • LibFredo6 E6 Binary NOT loaded
                                        • SCFLicense: v7.5a - 80
                                        • Fredo6 Plugins
                                          Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
                                          FredoScale v3.7c
                                          JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
                                          RoundCorner v3.4a - licensed FULL: 263401 - HE1772082497.0K
                                          Signature File: 2026-02-26 06:08:17 +0100
                                          Curviloft: 2026-02-26 06:08:26 +0100
                                          JointPushPull: 2026-02-26 10:15:01 +0100
                                          RoundCorner: 2026-03-02 12:08:45 +0100
                                          studioae
                                          Hi, everyone. Running SU2027 on Mac. Have LibFredo6 installed. Installed several tools, including Curviloft. The menu bars appear, with clickable icons, but nothing happens when I click them.
                                          I have restarted, rebooted, uninstalled, reinstalled, installed LibFredo6 first, checked for updates, etc. None of that makes any difference.
                                          Any idea why? Thanks!
                                            studioae
                                            Hi, all. I'm running SU2027. I have LibFredo6 installed. I had several Fredo extensions installed, but have backed it off just to Curviloft as I troubleshoot.
                                            The toolbars are present, buttons are there, but when pressed they do nothing. I have uninstalled, reinstalled, rebooted, etc., and none of that has changed anything.
                                            Any ideas? Thanks.
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 117
                                            • 115 / 117
