    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 588 Posters 12.0m Views 590 Watching
    • B
      Bublifuk21 @fredo6
      @fredo6 Dear fredo6, the new release 16.3b absolutely doesn not work for me. I am so sad.
        Rich O Brien Moderator @Bublifuk21
        That's rather vague. Please provide more concise information.
        • B
          Bublifuk21
          My last working release is 15.8.b. I need FredoScale. But this is working only with 15.9.d. and higher. Unfortunately, when I install 16.2. version all plugins stop to work. I menitoned it above. would like to install version 15.9.d, but I can not find this version anywhere. Is possible to download it somewhere?
          • B
            Bublifuk21
            Here is my error message:
            Error Loading File Fredo6_!LibFredo6.rb
            Error: #<NameError: uninitialized constant Traductor>
            c:/users/mcesak/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:362:in `startup'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:143:in `process'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:151:in `<module:LibFredo6_Loader>'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in `<top (required)>'
            Error Loading File Fredo6_Curviloft.rb
            Error: #<TypeError: can't convert nil into an exact number>
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `-'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:161:in `<top (required)>'
            C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:47:in `<module:Fredo6>'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>'
            Error Loading File Fredo6_FredoScale.rb
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in `<module:Fredo6>'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in `<top (required)>'
            Error Loading File Fredo6_JointPushPull.rb
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in `<module:Fredo6>'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
            Error Loading File Fredo6_RoundCorner.rb
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in `<module:Fredo6>'
            C:/Users/mcesak/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
            fredo6F 1 Reply Last reply
              Not here. Only recent versions are hosted.
              • fredo6F
                fredo6 @Bublifuk21
                @Bublifuk21
                You seem to have a wrong installation of LibFredo6 v16.3b.
                Open the Ruby console and copy / paste UI.openURL LibFredo6.sudir.
                I will open the Windows Explorer in the Sketchup Plugin directory.
                Locate the folder Fredo6_!LibFredo6 and erase it.
                Then reinstall LibFredo6
                By the way, it will also useful that you give us the content of what appears in the Ruby console when you invoke the menu Window > LibFredo6 Settings .... > Fredo6 Plugins Information for Sketcucation Support.
                Dave RD 1 Reply Last reply
                  Dave R @fredo6
                  @fredo6 should it be
                  without the final period?
                  • fredo6F
                    fredo6 @Dave R
                    Yes, definitely. Good you point it out,
                      maria0p03 Newcomers
                      After deleting the folder Fredo6_!LibFredo6 and reinstalling the plugin, the folder reappears, and the issue remains unresolved. In the "Fredo6 Plugins Information for SketchUcation Support" section, the console output looks like this:
                      TIGT 1 Reply Last reply
                        TIG Moderator @maria0p03
                        @maria0p03
                        The SketchUcation tools is not installed get its RBZ from the PluginStore, then install it using the Extension Manager...
                        It installs the SCFLicensing stuff with it...
                        • 111
                        • 112
                        • 113
                        • 114
                        • 115
                        • 115 / 115
