    [Plugin] Front Face - 1.2
    57 Posts 29 Posters 86.5k Views 29 Watching
      alz
      Very useful!
      Could you add a "hold down left mouse" to have it be active? This would prevent accidental flipping when simply moving your mouse around in the scene.
      Another possibility -- when being used, toggle to a different Style (say Gray = front face, Red = back face).
      ๐Ÿ˜„
      • boofredlayB Offline
        boofredlay
        That or change the cursor to something different while active.
          tomasz
          Good idea Boofredlay - added to the 'TO DO' list.
          I think your finger will fail with big scenes to work correctly for a longer period ๐Ÿ˜„,
          but... I could turn it on permanently when a LMB would be pressed longer then.. say 5 sec.
          I prefer let user decide what monochrome style looks like.
          Tomasz
          Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
            Sorry but how call the Tig Orient.face.rb?
            In what Menu, or with what Click mouse?
            I suppose with the Ruby console?
            How must be the selection? Facets selected? Group Selected?...
            I obtain that with the ruby Console with "face.orient_faces" or "orient.face" input in the console
            Error; #<NameError; (eval);495; undefined local variable or method `face' for main;Object>
            > (eval);495
            So I am perplex ๐Ÿ˜‰
            As the guidance notes at the start say...
            It matches the orientation of a face to any connected 'co-edged' faces.
            It mimics SketchUp's "Orient Faces" Tool.
            It can sometimes produce slightly different results when more than two
            connected faces share a common edge. Its results are equally logical,
            and who's to say how they should orient anyway ?
            Ideas on how to duplicate the built-in tool are welcomed...
            You can call it from other scripts thus: face.orient_faces
            i.e. if you put the script in the Plugins Folder it creates a new method - a 'Face' now has an extra method called "orient_faces"
            Let's say you have a face that's been chosen in your script which has been given the variable 'face', then adding in the line
            face.orient_faces
            will make any other faces that adjoin it [or its neighbours etc] flip to match that chosen face's orientation (normal) - just like the built-in 'orient faces' does in the right-click context-menu when you select a face...
              Daniel Bouchard
              Thanks Tomasz for this great plugin. ๐Ÿ‘
                boofredlay
                Any progress on changing the cursor Tomasz?
                I am using it today and was just curious. Handy tool BTW.
                  Hi Tomasz,
                  Thanks for this gem!
                  One question (or maybe a feature request) - after reversing the face (and successfully applying the back face material on the front face), could the plugin also delete the material applied on the back face? I.e. to paint the back face with the default (grey/blue) material.
                  OR - alternatively - does anyone know a plugin that would delete all materials applied to back faces only?
                    I could add that to my Remove Marerials plugin.
                    • Rich O BrienR Online
                      Thom,
                      That'd be an excellent feature and much appreciated ๐Ÿ‘
                      Rich
                        Yes, Thom, that would be very handy.
                        But of course, such a (to me very sophisticated but for you, guys, probably easy) modification for this FrontFace Plugin would also be handy - so that you need not fiddle with two different plugins (although the very simplicity of this plugin is also charming - no settings, no hassle with dialogs - just "brush" over the model and voilรก)
                          tomasz
                          Hi Gaieus,
                          The option of having back material reset to default looks nice.
                          I am currently terribly busy, but Christmas is coming.
                          I will put it on my list.
                          Tomasz
                            ๐Ÿ˜„
                            I'd added the feature to Remove Materials. Will post it later.
                              tomasz
                              Checked the API. It looks easy...
                                Guys, I am amazed at the helpfulness of all of you.
                                Once I win this combpetition, I hope you will all come and enjoy the party.
                                ๐Ÿ˜‰
                                (BTW I am planning a difficult plugin - you will hate me...)
                                  In the meanwhile, before it gets written into something better - to make ALL rear faces in the model [and faces inside definitions too] have the default material on their backs, just copy and paste this line of code into the Ruby Console - I compressed it into one line for ease of pasting...
                                  m=Sketchup.active_model;es=m.entities;es.each{|e|e.back_material=nil if e.class==Sketchup;;Face};ds=m.definitions;ds.each{|d|d.entities.each{|e|e.back_material=nil if e.class==Sketchup;;Face}};return nil
                                    tomasz
                                    Ok. I said I was busy, but I had to refresh my memory, how to write a Tool in SU, so played with FrontFace and here we go:
                                    Version 1.2 is ready.
                                    Greetings
                                    Tomasz
                                      boofredlay
                                      Beautiful. Thank you. ๐Ÿ‘
                                      • E Offline
                                        Ecuadorian
                                        TIG, this is probably one of the most useful pieces of code ever. Thank you very much. ๐Ÿ‘
                                        -Miguel Lescano
                                        • FletchF Offline
                                          Fletch
                                          TIG, does it also make all groups and components have the default material? (in case one or two got accidentally painted somehow?)
                                          Fletch
                                          3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                                          • E Offline
                                            Ecuadorian
                                            Fletch, Matthieu Noblet wrote a plugin for that:
                                            http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                                            -Miguel Lescano
                                            • 2 / 3
