    [Plugin] Front Face - 1.2
    57 Posts 29 Posters 88.9k Views 29 Watching
    • GaieusG
      Hi Tomasz,
      Thanks for this gem!
      One question (or maybe a feature request) - after reversing the face (and successfully applying the back face material on the front face), could the plugin also delete the material applied on the back face? I.e. to paint the back face with the default (grey/blue) material.
      OR - alternatively - does anyone know a plugin that would delete all materials applied to back faces only?
        I could add that to my Remove Marerials plugin.
          Thom,
          That'd be an excellent feature and much appreciated 👍
          Rich
          • GaieusG
            Yes, Thom, that would be very handy.
            But of course, such a (to me very sophisticated but for you, guys, probably easy) modification for this FrontFace Plugin would also be handy - so that you need not fiddle with two different plugins (although the very simplicity of this plugin is also charming - no settings, no hassle with dialogs - just "brush" over the model and voilá)
            • T
              tomasz
              Hi Gaieus,
              The option of having back material reset to default looks nice.
              I am currently terribly busy, but Christmas is coming.
              I will put it on my list.
              Tomasz
                I'd added the feature to Remove Materials. Will post it later.
                • T
                  tomasz
                  Any progress on changing the cursor Tomasz?
                  I am using it today and was just curious. Handy tool BTW.
                  Checked the API. It looks easy...
                  • GaieusG
                    Guys, I am amazed at the helpfulness of all of you.
                    Once I win this combpetition, I hope you will all come and enjoy the party.
                    (BTW I am planning a difficult plugin - you will hate me...)
                      In the meanwhile, before it gets written into something better - to make ALL rear faces in the model [and faces inside definitions too] have the default material on their backs, just copy and paste this line of code into the Ruby Console - I compressed it into one line for ease of pasting...
                      m=Sketchup.active_model;es=m.entities;es.each{|e|e.back_material=nil if e.class==Sketchup;;Face};ds=m.definitions;ds.each{|d|d.entities.each{|e|e.back_material=nil if e.class==Sketchup;;Face}};return nil
                      • T
                        tomasz
                        Ok. I said I was busy, but I had to refresh my memory, how to write a Tool in SU, so played with FrontFace and here we go:
                        Version 1.2 is ready.
                        Greetings
                        Tomasz
                        • boofredlayB
                          boofredlay
                          Beautiful. Thank you. 👍
                          • E
                            Ecuadorian
                            TIG, this is probably one of the most useful pieces of code ever. Thank you very much. 👍
                            -Miguel Lescano
                            • FletchF
                              Fletch
                              TIG, does it also make all groups and components have the default material? (in case one or two got accidentally painted somehow?)
                              Fletch
                              • E
                                Ecuadorian
                                Fletch, Matthieu Noblet wrote a plugin for that:
                                http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                                -Miguel Lescano
                                  No, it fixes back_materials inside them, but not materials applied to them - to do that you need this line...
                                  Sketchup.active_model.definitions.each{|d|d.instances.each{|i|i.material=nil}}
                                    Royvas
                                    gosh thank you so much for this 😄 works great
                                    • alvisA
                                      alvis
                                      Tomasz
                                      • Z
                                        Zacchia
                                        Hi Tomasz
                                        I have found now this plugin!! This is fantastic. Thanks a lot!
                                        • Z
                                          Zacchia
                                          Thomasz
                                          It seams that when material is on normal face and i use this plugin then material will be default SU material when turned the faces. Why is it like this? I think it should keep material and just turn faces.
                                            Jrudd
                                            Hi all,
                                            Proud to announce that there is finally a solution to the face flipping problem. You can now reverse faces and preserve UV coordinates! I tested it and the results are accurate!
                                            The UV Toolkit makes it possible. You also need to download the TT_Lib and put it in your plugins folder.
                                            To reverse a face, first select what you want reversed, then go to Plugins > UV Toolkit > Frontface material to Backface (or the opposite).
                                            Hope it helps,
                                            Jeremy
                                            • 2 / 3
