    [Plugin] Front Face - 1.2
    57 Posts 29 Posters 88.9k Views 29 Watching
    • GaieusG
      Yes, Thom, that would be very handy.
      But of course, such a (to me very sophisticated but for you, guys, probably easy) modification for this FrontFace Plugin would also be handy - so that you need not fiddle with two different plugins (although the very simplicity of this plugin is also charming - no settings, no hassle with dialogs - just "brush" over the model and voilá)
      • T
        tomasz
        Hi Gaieus,
        The option of having back material reset to default looks nice.
        I am currently terribly busy, but Christmas is coming.
        I will put it on my list.
        Tomasz
          I'd added the feature to Remove Materials. Will post it later.
          • T
            tomasz
            Any progress on changing the cursor Tomasz?
            I am using it today and was just curious. Handy tool BTW.
            Checked the API. It looks easy...
            • GaieusG
              Guys, I am amazed at the helpfulness of all of you.
              Once I win this combpetition, I hope you will all come and enjoy the party.
              (BTW I am planning a difficult plugin - you will hate me...)
                In the meanwhile, before it gets written into something better - to make ALL rear faces in the model [and faces inside definitions too] have the default material on their backs, just copy and paste this line of code into the Ruby Console - I compressed it into one line for ease of pasting...
                m=Sketchup.active_model;es=m.entities;es.each{|e|e.back_material=nil if e.class==Sketchup;;Face};ds=m.definitions;ds.each{|d|d.entities.each{|e|e.back_material=nil if e.class==Sketchup;;Face}};return nil
                • T
                  tomasz
                  Ok. I said I was busy, but I had to refresh my memory, how to write a Tool in SU, so played with FrontFace and here we go:
                  Version 1.2 is ready.
                  Greetings
                  Tomasz
                  • boofredlayB
                    boofredlay
                    Beautiful. Thank you. 👍
                    • E
                      Ecuadorian
                      TIG, this is probably one of the most useful pieces of code ever. Thank you very much. 👍
                      -Miguel Lescano
                      • FletchF
                        Fletch
                        TIG, does it also make all groups and components have the default material? (in case one or two got accidentally painted somehow?)
                        Fletch
                        • E
                          Ecuadorian
                          Fletch, Matthieu Noblet wrote a plugin for that:
                          http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                          -Miguel Lescano
                            No, it fixes back_materials inside them, but not materials applied to them - to do that you need this line...
                            Sketchup.active_model.definitions.each{|d|d.instances.each{|i|i.material=nil}}
                              Royvas
                              gosh thank you so much for this 😄 works great
                              • alvisA
                                alvis
                                Tomasz
                                • Z
                                  Zacchia
                                  Hi Tomasz
                                  I have found now this plugin!! This is fantastic. Thanks a lot!
                                  • Z
                                    Zacchia
                                    Thomasz
                                    It seams that when material is on normal face and i use this plugin then material will be default SU material when turned the faces. Why is it like this? I think it should keep material and just turn faces.
                                      Jrudd
                                      Hi all,
                                      Proud to announce that there is finally a solution to the face flipping problem. You can now reverse faces and preserve UV coordinates! I tested it and the results are accurate!
                                      The UV Toolkit makes it possible. You also need to download the TT_Lib and put it in your plugins folder.
                                      To reverse a face, first select what you want reversed, then go to Plugins > UV Toolkit > Frontface material to Backface (or the opposite).
                                      Hope it helps,
                                      Jeremy
                                        simoni
                                        I find it works 50% of the time, sometimes textures are mapped wrongly, maybe I am doing something wrong?
                                        • N
                                          Need2SeeAttachments
                                          LOOK AT MY USER NAME, ENOUGH SAID. Need2SeeAttachments.
                                          I WANT TO DOWNLOAD, NOW BYE FOREVER SKETCHUCATION.
                                          Meant no offence, k thx bai.
                                            Bye bye.
                                            • 2 / 3
