    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 185.4k Views 108 Watching
      morisdov
      New version 1.03 released of - "Proper_Animation.rb"
      • no more need to restart "Animation Observer" to reflect new/deleted scenes
        I have implemented the "PagesObserver interface" so this is done automatically now
      http://morisdov.googlepages.com
      • N Offline
        N Lindenthal
        How can I tell the ruby console, to »Get Position - 2«?
        I ask this to have a proper animation, without getting all other remembers of a scene.
          morisdov
          Select only the objects you want to move to position 2 (those that indeed have position 2 set) and right mouse click "Transformation->Get position 2".
          Other objects will not "move".
          • N Offline
            N Lindenthal
            @morisdov said:
            and right mouse click "Transformation->Get position 2". …
            Ah, I understand. Get Position - 2 is only available to those object, which have Set Position - 2. Now my question is, how not to use right mouse click, but to »Get Position - 2«. So my idea is, to us the ruby console to select one object (by name). Now my question is, how to tell the selected object to »Get Position - 2«?
              morisdov
              @n lindenthal said:
              use the mouse or ruby console to selectone object (by name). Now my question is, how to tell the selected object to »Get Position - 2«?
              Morisdov.transf_get("transf2")
              You must understand this is not the intentended use of this plugin -
              You will more productive following "normal" procedures.
                morisdov
                New version 1.04 released of - "Proper_Animation.rb"
                • added control of each animated scenes transition time - following users requests
                download from - http://morisdov.googlepages.com
                • N Offline
                  N Lindenthal
                  I see no difference. My elevator in scene 1 is as fast as my elevator in scene 2. But to change from one scene to the other takes 8 or 2 seconds.
                  • romboutR Offline
                    rombout
                    He morisdov...
                    kwel script!!! i got some problems. when ad i.e. 2 steps for a cube i than ad 2 scenes and update eacht scene with its own position of the cube. than i play the animation my cube disappears at one the positions???
                    • P Offline
                      princedragoncok
                      This is a great plugin Morisdov. My request would be avi. animation export however. I want rendering engines to recognise these movements for rendering animations. But again, thanks 👍
                      • N Offline
                        N Lindenthal
                        Yes, I understand. But please know, that I write much ruby code about ruby console by using applescript scripts from database (FileMaker Pro 8.5). Its phantastic.
                        Now my question is, whether and how it is possible, to set transition time in this code line. For example:
                        Morisdov.transf_get("transf5") set transition time to 8
                          morisdov
                          No - transition times setting is a property of sketchups own scenes animation - not a property of "transf_get("transf5")" function, which is not designed to be called from the ruby console.
                          Please follow the "readme.txt" instructions, grab one of the sample models submitted by MALAISE, or use the http://morisdov.googlepages.com/xml_dictionary_attributes.zip - plugin to debug your model.
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&p=79744#p79168
                          If there is a will there is a way - look at TOMASZ render -
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&st=0&sk=t&sd=a&start=30#p80623
                          i guess we will get sketchup 7 before sketchup crew gives an answer
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10926&p=73880#p73880
                          Moris
                            A little tut 💚
                            Splash.skp
                              Seems the plug don't work when you make File/Exportation/ animation/avi 😕
                              Am i right? Or I misse something?
                                captainping
                                Hi all,
                                I'm looking for a 3D modeling program that will allow me to model machines with moving parts (shafts, gears, pushrods, etc...) I'd like to be able to specify axes of rotation and such and then see if my machine go, on a mouse click or whatever. I don't need to be able to export a movie (though that'd be nice). I don't need high-quality rendering. It looks like SketchUp with Proper Animation would work. Would it?
                                Looking over the new Dynamic Components feature in SketchUp 7, it doesn't look like it's what I want. Am I right?
                                ('m not a SketchUp user yet. I've been using VectorWorks for some time.)
                                Thanks!
                                Captain Ping
                                  Presently if you want stay with Sketchup, better thing for your particular purpose will be SketchyPhysics2! 😎
                                  (it's free) 😉
                                  Arm's Robot(video)
                                  Titanic Shaft(video)
                                  And load this Steam Machine (post 2) ☀
                                  of course you must have Sketchyphysics2 installed for work with the model and see animation)
                                    Little tricks! 😉
                                    As all objects must be a group or a component
                                    For erase a position just explode the group or component then group it or make component again 😉
                                    You can address all positions even you are in the scene 1 !!! 😮
                                    Just don't overpass the number of scene existing for give a number to positions! ☀
                                    • Z Offline
                                      zeal
                                      it's really hard to express my thank to you.
                                        Tim Danaher
                                        Phew, am I thick or what? I just cannot get this to work. I've had a look at Moris' & Pilou's explanations and the video... but it just don't werk for me...
                                        This is what I'm doing:
                                        I want to animate a lift / elevator car moving vertically within the elevator structure. I have four scenes in my file.
                                        I select the lift car, RMB > Transformation > Set position 1
                                        Start Animation Observer.
                                        Switch to scene 2, Then move lift car, Set Position 2.
                                        Switch to Scene 3, move lift car, Set Position 3
                                        Switch Scene 4, move lift car, Set position 4
                                        Stop Animation observer.
                                        Start animation / Slideshow in SU -- nothing happens. The views change between scenes, but the lift car stays in the last position I set it to.
                                        I can use 'Get Position X', and the car will move within the same scene, but not when playing back an animation / Slideshow.
                                        WTF am I doing wrong?
                                        TIA,
                                        Cheers,
                                        Tim
                                        http://vizarch.blogspot.com
                                        • soloS Offline
                                          solo
                                          Without using layers, can this program do this?
                                          (I did this with 4 layers standard SU output, converted to .gif so quality is crappy)
                                          http://img6.imageshack.us/img6/1221/therunner.gif
                                          http://www.solos-art.com
                                          • MALAISEM Offline
                                            MALAISE
                                            Hi All
                                            Solo, your running skeleton is first class 👍
                                            MALAISE
                                            • 12
                                            • 13
                                            • 3 / 13
