    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 241.6k Views 108 Watching
      morisdov
      @n lindenthal said:
      How can I tell the ruby console, to »Get Position - 2«?
      I ask this to have a proper animation, without getting all other remembers of a scene.
      Select only the objects you want to move to position 2 (those that indeed have position 2 set) and right mouse click "Transformation->Get position 2".
      Other objects will not "move".
      • N
        N Lindenthal
        @morisdov said:
        and right mouse click "Transformation->Get position 2". …
        Ah, I understand. Get Position - 2 is only available to those object, which have Set Position - 2. Now my question is, how not to use right mouse click, but to »Get Position - 2«. So my idea is, to us the ruby console to select one object (by name). Now my question is, how to tell the selected object to »Get Position - 2«?
          morisdov
          @n lindenthal said:
          use the mouse or ruby console to selectone object (by name). Now my question is, how to tell the selected object to »Get Position - 2«?
          Morisdov.transf_get("transf2")
          You must understand this is not the intentended use of this plugin -
          You will more productive following "normal" procedures.
            morisdov
            New version 1.04 released of - "Proper_Animation.rb"
            • added control of each animated scenes transition time - following users requests
            download from - http://morisdov.googlepages.com
            • N
              N Lindenthal
              I see no difference. My elevator in scene 1 is as fast as my elevator in scene 2. But to change from one scene to the other takes 8 or 2 seconds.
              • romboutR
                rombout
                He morisdov...
                kwel script!!! i got some problems. when ad i.e. 2 steps for a cube i than ad 2 scenes and update eacht scene with its own position of the cube. than i play the animation my cube disappears at one the positions???
                • P
                  princedragoncok
                  This is a great plugin Morisdov. My request would be avi. animation export however. I want rendering engines to recognise these movements for rendering animations. But again, thanks 👍
                  • N
                    N Lindenthal
                    Yes, I understand. But please know, that I write much ruby code about ruby console by using applescript scripts from database (FileMaker Pro 8.5). Its phantastic.
                    Now my question is, whether and how it is possible, to set transition time in this code line. For example:
                    Morisdov.transf_get("transf5") set transition time to 8
                      morisdov
                      No - transition times setting is a property of sketchups own scenes animation - not a property of "transf_get("transf5")" function, which is not designed to be called from the ruby console.
                      Please follow the "readme.txt" instructions, grab one of the sample models submitted by MALAISE, or use the http://morisdov.googlepages.com/xml_dictionary_attributes.zip - plugin to debug your model.
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&p=79744#p79168
                      If there is a will there is a way - look at TOMASZ render -
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&st=0&sk=t&sd=a&start=30#p80623
                      i guess we will get sketchup 7 before sketchup crew gives an answer
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10926&p=73880#p73880
                      Moris
                        A little tut 💚
                        Splash.skp
                          Seems the plug don't work when you make File/Exportation/ animation/avi 😕
                          Am i right? Or I misse something?
                          • C
                            captainping
                            Hi all,
                            I'm looking for a 3D modeling program that will allow me to model machines with moving parts (shafts, gears, pushrods, etc...) I'd like to be able to specify axes of rotation and such and then see if my machine go, on a mouse click or whatever. I don't need to be able to export a movie (though that'd be nice). I don't need high-quality rendering. It looks like SketchUp with Proper Animation would work. Would it?
                            Looking over the new Dynamic Components feature in SketchUp 7, it doesn't look like it's what I want. Am I right?
                            ('m not a SketchUp user yet. I've been using VectorWorks for some time.)
                            Captain Ping
                              Presently if you want stay with Sketchup, better thing for your particular purpose will be SketchyPhysics2! 😎
                              (it's free) 😉
                              Arm's Robot(video)
                              Titanic Shaft(video)
                              And load this Steam Machine (post 2) ☀
                              of course you must have Sketchyphysics2 installed for work with the model and see animation)
                                Little tricks! 😉
                                As all objects must be a group or a component
                                For erase a position just explode the group or component then group it or make component again 😉
                                You can address all positions even you are in the scene 1 !!! 😮
                                Just don't overpass the number of scene existing for give a number to positions! ☀
                                • Z
                                  zeal
                                  it's really hard to express my thank to you.
                                  • Tim DanaherT
                                    Tim Danaher
                                    Phew, am I thick or what? I just cannot get this to work. I've had a look at Moris' & Pilou's explanations and the video... but it just don't werk for me...
                                    This is what I'm doing:
                                    I want to animate a lift / elevator car moving vertically within the elevator structure. I have four scenes in my file.
                                    I select the lift car, RMB > Transformation > Set position 1
                                    Start Animation Observer.
                                    Switch to scene 2, Then move lift car, Set Position 2.
                                    Switch to Scene 3, move lift car, Set Position 3
                                    Switch Scene 4, move lift car, Set position 4
                                    Stop Animation observer.
                                    Start animation / Slideshow in SU -- nothing happens. The views change between scenes, but the lift car stays in the last position I set it to.
                                    I can use 'Get Position X', and the car will move within the same scene, but not when playing back an animation / Slideshow.
                                    WTF am I doing wrong?
                                    TIA,
                                    Cheers,
                                    Tim
                                    http://vizarch.blogspot.com
                                    • soloS
                                      Without using layers, can this program do this?
                                      (I did this with 4 layers standard SU output, converted to .gif so quality is crappy)
                                      http://img6.imageshack.us/img6/1221/therunner.gif
                                      • MALAISEM
                                        MALAISE
                                        Hi All
                                        Solo, your running skeleton is first class 👍
                                        MALAISE
                                          Before launch the Animation observer (positions adressed), better is save, quit and restart!
                                          @Tim
                                          Start Animation Observer only when all positions Objects are adressed!!!
                                          That is that your error !
                                          Objects (must be grouped) are independent of the scene! But will be animated inside the moving of the scenes!
                                          Just go in the scene 1 and take 4 positions of your objects (or less) if you have 4 scenes
                                          @ Solo
                                          Yes 😉
                                          Just take the 4 positions (or less)of each objets in the scene 1 (if you have 4 scenes)
                                          And of course scenes can be rotated for Lelouch style! 😆 Your is fixed! Japan style 😄
                                          Very speedy conceptual 💚
                                          Load the file
                                          Play Animation (of the scenes) as normal way
                                          ani.skp
                                            Updated the anim above 💚
                                            Always very basic but showing that you can animate anything in classical way 😉
                                            All is time to make 😒
                                            Difference with the Layer method is that you have just to click on a group for change it
                                            • 12
                                            • 13
                                            • 3 / 13
