    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 241.6k Views 108 Watching
      Morisdov 👍 👍
      you may use few scenes as part of a single long leg of a animation part
      Seems the cool trick! ☀
      MALAISE 👍
      • MALAISEM
        MALAISE
        THX guys
        I've effectively downloaded the release and saw some changes in the ruby file.
        -- About Transformation: just click on the last shown position in the list and then
        a new one will be created automatically. (It's not obvious the first time ) 😉
        MALAISE
          redot
          Thank you Morisdov. This is brilliant. Just what i've been looking for for interior walkthroughs.
          Great work
            roberta
            So happy to have found this great plugin! Thanks a lot morisdov!
            • MALAISEM
              MALAISE
              HI John
              Just have look on this ( on the same thread Ruby). Don't worry about frenglish
              You'll find probably some interesting solutions.
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390
              Friendly
              MALAISE 😄
                morisdov
                I am glad you all find this plugin usefull and hopefully are able to get more out of SketchUp and are more productive for your customers.
                John - you already have the functionality you requested - note that the "get" is grayed out until you "set" its position, only after which it becomes "active" non grayed.
                Anyway all your feedbacks will be noted and considered for coming versions.
                Cheers, Moris
                  morisdov
                  if you want a full report of all entities "Position X" data with all other "dictionary attributes" - you can use "xml_dictionary_attributes.zip" from http://morisdov.googlepages.com - you get an online web dialog with all the data in addition to the XML file on the disk.
                  • JClementsJ
                    JClements
                    Hi Morris:
                    I tried the script last night. It was easy enough to figure out how to "tag" groups with the Set and Get parameters. Very nice.
                    However, I found I stumbled with saving things with a Scene. Probably just my slow mind ... but a set of a few screen captures with text explanations OR video with Narration might be helpful for others too.
                    One place I found where one could easily screw up, is if you are careless and accidentally click on a Set Position for an group which already has a position(s) assigned to it. Perhaps there could be an default option to warn user before overwritting the existing parameter?
                    I wish there were a way to analysis the entire model as to which objects are tagged, with their positions settings and do so for all of them at once ... perhaps in the transform dialog there could be a SHOW command which would display some type of labeling of objects and their tags?
                    Regards,
                    John
                      morisdov
                      New version 1.03 released of - "Proper_Animation.rb"
                      • no more need to restart "Animation Observer" to reflect new/deleted scenes
                        I have implemented the "PagesObserver interface" so this is done automatically now
                      Error 404 (Not Found)!!1
                      (morisdov.googlepages.com)
                      • N
                        N Lindenthal
                        How can I tell the ruby console, to »Get Position - 2«?
                        I ask this to have a proper animation, without getting all other remembers of a scene.
                          morisdov
                          Select only the objects you want to move to position 2 (those that indeed have position 2 set) and right mouse click "Transformation->Get position 2".
                          Other objects will not "move".
                          • N
                            N Lindenthal
                            @morisdov said:
                            and right mouse click "Transformation->Get position 2". …
                            Ah, I understand. Get Position - 2 is only available to those object, which have Set Position - 2. Now my question is, how not to use right mouse click, but to »Get Position - 2«. So my idea is, to us the ruby console to select one object (by name). Now my question is, how to tell the selected object to »Get Position - 2«?
                              morisdov
                              @n lindenthal said:
                              use the mouse or ruby console to selectone object (by name). Now my question is, how to tell the selected object to »Get Position - 2«?
                              Morisdov.transf_get("transf2")
                              You must understand this is not the intentended use of this plugin -
                              You will more productive following "normal" procedures.
                                morisdov
                                New version 1.04 released of - "Proper_Animation.rb"
                                • added control of each animated scenes transition time - following users requests
                                download from - http://morisdov.googlepages.com
                                • N
                                  N Lindenthal
                                  I see no difference. My elevator in scene 1 is as fast as my elevator in scene 2. But to change from one scene to the other takes 8 or 2 seconds.
                                  • romboutR
                                    rombout
                                    He morisdov...
                                    kwel script!!! i got some problems. when ad i.e. 2 steps for a cube i than ad 2 scenes and update eacht scene with its own position of the cube. than i play the animation my cube disappears at one the positions???
                                    • P
                                      princedragoncok
                                      This is a great plugin Morisdov. My request would be avi. animation export however. I want rendering engines to recognise these movements for rendering animations. But again, thanks 👍
                                      • N
                                        N Lindenthal
                                        Yes, I understand. But please know, that I write much ruby code about ruby console by using applescript scripts from database (FileMaker Pro 8.5). Its phantastic.
                                        Now my question is, whether and how it is possible, to set transition time in this code line. For example:
                                        Morisdov.transf_get("transf5") set transition time to 8
                                          morisdov
                                          No - transition times setting is a property of sketchups own scenes animation - not a property of "transf_get("transf5")" function, which is not designed to be called from the ruby console.
                                          Please follow the "readme.txt" instructions, grab one of the sample models submitted by MALAISE, or use the http://morisdov.googlepages.com/xml_dictionary_attributes.zip - plugin to debug your model.
                                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&p=79744#p79168
                                          If there is a will there is a way - look at TOMASZ render -
                                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&st=0&sk=t&sd=a&start=30#p80623
                                          i guess we will get sketchup 7 before sketchup crew gives an answer
                                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10926&p=73880#p73880
                                          Moris
                                            A little tut 💚
                                            Splash.skp
                                            • 12
                                            • 13
                                            • 3 / 13
