    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 241.6k Views 108 Watching
      morisdov
      New version 1.04 released of - "Proper_Animation.rb"
      • added control of each animated scenes transition time - following users requests
      download from - http://morisdov.googlepages.com
      • N
        N Lindenthal
        I see no difference. My elevator in scene 1 is as fast as my elevator in scene 2. But to change from one scene to the other takes 8 or 2 seconds.
        • romboutR
          rombout
          He morisdov...
          kwel script!!! i got some problems. when ad i.e. 2 steps for a cube i than ad 2 scenes and update eacht scene with its own position of the cube. than i play the animation my cube disappears at one the positions???
          • P
            princedragoncok
            This is a great plugin Morisdov. My request would be avi. animation export however. I want rendering engines to recognise these movements for rendering animations. But again, thanks ๐Ÿ‘
            • N
              N Lindenthal
              @morisdov said:
              โ€ฆ
              Morisdov.transf_get("transf2")
              You must understand this is not the intentended use of this plugin -
              โ€ฆ
              Yes, I understand. But please know, that I write much ruby code about ruby console by using applescript scripts from database (FileMaker Pro 8.5). Its phantastic.
              Now my question is, whether and how it is possible, to set transition time in this code line. For example:
              Morisdov.transf_get("transf5") set transition time to 8
                morisdov
                No - transition times setting is a property of sketchups own scenes animation - not a property of "transf_get("transf5")" function, which is not designed to be called from the ruby console.
                Please follow the "readme.txt" instructions, grab one of the sample models submitted by MALAISE, or use the http://morisdov.googlepages.com/xml_dictionary_attributes.zip - plugin to debug your model.
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&p=79744#p79168
                If there is a will there is a way - look at TOMASZ render -
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11390&st=0&sk=t&sd=a&start=30#p80623
                i guess we will get sketchup 7 before sketchup crew gives an answer
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10926&p=73880#p73880
                Moris
                  A little tut ๐Ÿ’š
                  Splash.skp
                    Seems the plug don't work when you make File/Exportation/ animation/avi ๐Ÿ˜•
                    Am i right? Or I misse something?
                    • C
                      captainping
                      Hi all,
                      I'm looking for a 3D modeling program that will allow me to model machines with moving parts (shafts, gears, pushrods, etc...) I'd like to be able to specify axes of rotation and such and then see if my machine go, on a mouse click or whatever. I don't need to be able to export a movie (though that'd be nice). I don't need high-quality rendering. It looks like SketchUp with Proper Animation would work. Would it?
                      Looking over the new Dynamic Components feature in SketchUp 7, it doesn't look like it's what I want. Am I right?
                      ('m not a SketchUp user yet. I've been using VectorWorks for some time.)
                      Captain Ping
                        Presently if you want stay with Sketchup, better thing for your particular purpose will be SketchyPhysics2! ๐Ÿ˜Ž
                        (it's free) ๐Ÿ˜‰
                        Arm's Robot(video)
                        Titanic Shaft(video)
                        And load this Steam Machine (post 2) โ˜€
                        of course you must have Sketchyphysics2 installed for work with the model and see animation)
                          Little tricks! ๐Ÿ˜‰
                          As all objects must be a group or a component
                          For erase a position just explode the group or component then group it or make component again ๐Ÿ˜‰
                          You can address all positions even you are in the scene 1 !!! ๐Ÿ˜ฎ
                          Just don't overpass the number of scene existing for give a number to positions! โ˜€
                          • Z
                            zeal
                            it's really hard to express my thank to you.
                            • Tim DanaherT
                              Tim Danaher
                              Phew, am I thick or what? I just cannot get this to work. I've had a look at Moris' & Pilou's explanations and the video... but it just don't werk for me...
                              This is what I'm doing:
                              I want to animate a lift / elevator car moving vertically within the elevator structure. I have four scenes in my file.
                              I select the lift car, RMB > Transformation > Set position 1
                              Start Animation Observer.
                              Switch to scene 2, Then move lift car, Set Position 2.
                              Switch to Scene 3, move lift car, Set Position 3
                              Switch Scene 4, move lift car, Set position 4
                              Stop Animation observer.
                              Start animation / Slideshow in SU -- nothing happens. The views change between scenes, but the lift car stays in the last position I set it to.
                              I can use 'Get Position X', and the car will move within the same scene, but not when playing back an animation / Slideshow.
                              WTF am I doing wrong?
                              TIA,
                              Cheers,
                              Tim
                              http://vizarch.blogspot.com
                              • soloS
                                Without using layers, can this program do this?
                                (I did this with 4 layers standard SU output, converted to .gif so quality is crappy)
                                http://img6.imageshack.us/img6/1221/therunner.gif
                                • MALAISEM
                                  MALAISE
                                  Hi All
                                  Solo, your running skeleton is first class ๐Ÿ‘
                                  MALAISE
                                  La Connaissance n'a de valeur que partagรฉe
                                    Before launch the Animation observer (positions adressed), better is save, quit and restart!
                                    @Tim
                                    Start Animation Observer only when all positions Objects are adressed!!!
                                    That is that your error !
                                    Objects (must be grouped) are independent of the scene! But will be animated inside the moving of the scenes!
                                    Just go in the scene 1 and take 4 positions of your objects (or less) if you have 4 scenes
                                    @ Solo
                                    Yes ๐Ÿ˜‰
                                    Just take the 4 positions (or less)of each objets in the scene 1 (if you have 4 scenes)
                                    And of course scenes can be rotated for Lelouch style! ๐Ÿ˜† Your is fixed! Japan style ๐Ÿ˜„
                                    Very speedy conceptual ๐Ÿ’š
                                    Load the file
                                    Play Animation (of the scenes) as normal way
                                    ani.skp
                                      Updated the anim above ๐Ÿ’š
                                      Always very basic but showing that you can animate anything in classical way ๐Ÿ˜‰
                                      All is time to make ๐Ÿ˜’
                                      Difference with the Layer method is that you have just to click on a group for change it
                                      • Tim DanaherT
                                        Tim Danaher
                                        @Tim
                                        Pilou --
                                        Thanks, but...
                                        in Scene 1: Set Position - 1 (start), move car, Set Position - 2, move car, Set Position -3, move car, Set Position -4.
                                        Start Animation observer.
                                        Play scene animation.
                                        Car does not move. The car is a self-contained group.
                                        Cheers,
                                        Tim
                                          You have not save, quit reload! ๐Ÿ˜„
                                          and why 1 (start), move car ? Start is only when all is adressed!
                                          Can you post your car or a simple objects with same nature group
                                          • Tim DanaherT
                                            Tim Danaher
                                            Yes, I have. Just didn't state it.
                                            Because, in my experience with other packages, I want to set a keyframe for the starting position.
                                            OK. 'Lift Car' is the name of the group that I want to animate.
                                            Earl's Court Lifts_Proper_Anim_Simple.skp.zip
                                            Cheers,
                                            Tim
                                            • 12
                                            • 13
                                            • 3 / 13
