    [Tutorial > Modeling] Arch in a curved wall.
    32 Posts 14 Posters 14.1k Views 14 Watching
    • GaieusG
      thanks, that was helpful.
      • Paul RussamP
        Paul Russam
        We need an emote for 'bangs head of desk'
        I never knew we could do this in SU, I've been selecting faces and picking soften/smooth edges from the context menu. 😮
        This is what I love about SU and here, always something new or a new way to do something.
        Paul Russam
        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        • GaieusG
          Hehe...
          I learn so many things every day... 😄
          Additionally, the modification keys (in Win) for the Eraser tool:
          Ctrl+Eraser = soften
          Shift+Eraser = hide
          You can soften a hidden line with this but cannot turn a softened line into hidden.
          Ctrl+Shift+Eraser = unsoften / turn a softened line hidden (works only with hidden geometry on of course)
          • N
            not registered yet
            I seem to be having a problem with Step (Scene) 7.
            I draw my arc then attempt to push/pull through the face but I am getting an "Offset limited to ~7 3/8" message.
            Any suggestions?
            Thanks much.
            Marc
            (Elmarq)
            • boofredlayB
              boofredlay
              Welcome Marc.
              Go ahead and push it to that offset limit. Then push it again and it should go through. If not, push it to that limit then hold ctl while pushing again, creating a copy. This should go through.
              Let me know if it works.
              • GaieusG
                Also, if you group either the curved face or the arch, it will not "report" this limit (in the latter case you need to edit it to be able to P/P). You can then explode the group and intersect.
                • N
                  not registered yet
                  Thanks for the tips! That did the trick.
                  Marc
                  (Elmarq)
                  • P
                    PKast
                    There was a good tip recently that relates to this tutorial. By using the "from Countours" tool from the "sandbox group" you can quickly and automatically stitch the area at the bottom of the arch.
                    Select the two arcs that define the curve, select the "from Contours" tool and the curves become stitched. Clean up the excess stitching, and finish by smoothing the surface.
                    • K
                      Katies29f
                      I cannot download this tutorial the link is busted
                      • GaieusG
                        Yes we had some problem yesterday but it's fixed now.
                          Julius
                          very useful tutorial, but...how did you stitch together in scene 11?
                          • zx10r_GazZ
                            zx10r_Gaz
                            Any suggestions?
                            Thanks much.
                            Marc
                            (Elmarq)
                            Hello Marc,
                            I think you will encounter this problem if you do not delete the "construction lines" from the arch to where you draw your arc. Delete these before you push/pull and it will work fine.
                            Gaz...
                            • boofredlayB
                              boofredlay
                              Basically I just drew points from each endpoint to another, triangulating the surfaces until they "Fill In". Nothing automated there, just drawing.
                                Julius
                                ok, so you drew lines, thank you!
                                • GaieusG
                                  Julius,
                                  You can also use Darrel's "Skin.rb" plugin for this.
                                  Marc,
                                  Whenever you encounter such a problem (the PP tool not intending to push further), you can group any of the entities (either what you want to push or the one you want to push trough) and you can do the operation. Then you can just simply explode the group.
                                    Julius
                                    wow, great script! thanks gaieus and thanks darrel!
                                    • T
                                      trillium
                                      hi Gaieus, when you have time would you post a tutorial or quick steps list to show us how you did this one? it's beautiful!!
                                      • GaieusG
                                        Well, to tell the truth, I'm no longer sure how exactly it was modelled but what I'm sure about is that I'd definitely do it somehow else now.
                                        I remember suffering a lot with it (back then when I also have just started using SU) but now we have so many useful plugins that would make life easier that. Anyway, here's the model if you're interested (last year I re-uploaded it to the WH when we were going to test some new features there).
                                        Surely it would be worth a tutorial although it would probably be a bit lengthy. 😉
                                        • charly2008C
                                          charly2008
                                          Hi Scaba,
                                          a like such models. I tried also to construct such details but i was not so successfull like you.
                                          Karlheinz
                                          • GaieusG
                                            You always have to take into consideration that those SU surfaces though look curved, are actually faceted and then adjust your "mini galleries" (or what they're called) that way. Made from straight segments. I'm sure however that if you download my model, you'll find lots of mistakes in it (as I'm sure there are as as I said,it was a very early challenge for me, too). 😉
