    [Tutorial > Modeling] Arch in a curved wall.
    32 Posts 14 Posters 13.1k Views 14 Watching
      Hehe...
      I learn so many things every day... ๐Ÿ˜„
      Additionally, the modification keys (in Win) for the Eraser tool:
      Ctrl+Eraser = soften
      Shift+Eraser = hide
      You can soften a hidden line with this but cannot turn a softened line into hidden.
      Ctrl+Shift+Eraser = unsoften / turn a softened line hidden (works only with hidden geometry on of course)
      • N Offline
        not registered yet
        I seem to be having a problem with Step (Scene) 7.
        I draw my arc then attempt to push/pull through the face but I am getting an "Offset limited to ~7 3/8" message.
        Any suggestions?
        Thanks much.
        Marc
        (Elmarq)
        • boofredlayB Offline
          boofredlay
          Welcome Marc.
          Go ahead and push it to that offset limit. Then push it again and it should go through. If not, push it to that limit then hold ctl while pushing again, creating a copy. This should go through.
          Let me know if it works.
            Also, if you group either the curved face or the arch, it will not "report" this limit (in the latter case you need to edit it to be able to P/P). You can then explode the group and intersect.
            • N Offline
              not registered yet
              Thanks for the tips! That did the trick.
              Marc
              (Elmarq)
                PKast
                There was a good tip recently that relates to this tutorial. By using the "from Countours" tool from the "sandbox group" you can quickly and automatically stitch the area at the bottom of the arch.
                Select the two arcs that define the curve, select the "from Contours" tool and the curves become stitched. Clean up the excess stitching, and finish by smoothing the surface.
                  Katies29f
                  I cannot download this tutorial the link is busted
                    Yes we had some problem yesterday but it's fixed now.
                      Julius
                      very useful tutorial, but...how did you stitch together in scene 11?
                      • zx10r_GazZ Offline
                        zx10r_Gaz
                        Any suggestions?
                        Thanks much.
                        Marc
                        (Elmarq)
                        Hello Marc,
                        I think you will encounter this problem if you do not delete the "construction lines" from the arch to where you draw your arc. Delete these before you push/pull and it will work fine.
                        Gaz...
                          boofredlay
                          Basically I just drew points from each endpoint to another, triangulating the surfaces until they "Fill In". Nothing automated there, just drawing.
                            Julius
                            ok, so you drew lines, thank you!
                              Julius,
                              You can also use Darrel's "Skin.rb" plugin for this.
                              Marc,
                              Whenever you encounter such a problem (the PP tool not intending to push further), you can group any of the entities (either what you want to push or the one you want to push trough) and you can do the operation. Then you can just simply explode the group.
                                Julius
                                wow, great script! thanks gaieus and thanks darrel!
                                  trillium
                                  hi Gaieus, when you have time would you post a tutorial or quick steps list to show us how you did this one? it's beautiful!!
                                    Well, to tell the truth, I'm no longer sure how exactly it was modelled but what I'm sure about is that I'd definitely do it somehow else now.
                                    I remember suffering a lot with it (back then when I also have just started using SU) but now we have so many useful plugins that would make life easier that. Anyway, here's the model if you're interested (last year I re-uploaded it to the WH when we were going to test some new features there).
                                    Surely it would be worth a tutorial although it would probably be a bit lengthy. ๐Ÿ˜‰
                                    • charly2008C Offline
                                      charly2008
                                      Hi Scaba,
                                      a like such models. I tried also to construct such details but i was not so successfull like you.
                                      Karlheinz
                                        You always have to take into consideration that those SU surfaces though look curved, are actually faceted and then adjust your "mini galleries" (or what they're called) that way. Made from straight segments. I'm sure however that if you download my model, you'll find lots of mistakes in it (as I'm sure there are as as I said,it was a very early challenge for me, too). ๐Ÿ˜‰
                                          trillium
                                          thank you so much Gaieus, i got it!!!! and some of your other great models in the warehouse โ˜€
                                          i guess my main question is very similiar to Karl's - how to create push/pull kind of details and cuts on curved surfaces, plugins? or intersect?
                                            I'm really serious when saying that I can't remember. Nowadays it would be "easy" with Joint Push Pull and Tools on Surface plugins (both by Fredo) or Shape Bender (by Chris) but back then they didn't exist. It could be done by intersecting however. I'd need to put together a little tutorial for that but I have to tell the truth, I'm a bit behind my schedule. I'll do it anyway.
                                            BTW I "pulled down" most of my models from the WH once I got pissed off some guys there... ๐Ÿ˜’
                                            Only left those which I made for others (mainly).
