    Push and pull tool
    19 Posts 12 Posters 4.3k Views 12 Watching
    • Wo3DanW Offline
      Wo3Dan
      @jean lemire said:
      I folks.
      See attached SU file for ideas.
      Jean,
      Once again you proved to obtain a solution with basic SU tools, great!!
      We tend to forget the possibilities of more 'complex' ++ or +/- selections with Crtl and Shift.
      Thanks for sharing.
      (Wo3Dan)
        Very witty, Jean!
        • EdsonE Offline
          Edson
          this a great tut, jean. very useful indeed.
          gai, we should move jean's tuts to the tutorials section, don't you think so?
          http://www.mahfuz.arq.br
            I agree, Edson!
            And don't forget that both you and Jean are mods who can easily do this!
            • EdsonE Offline
              Edson
              no, i do not forget that. i am just not sure how to do it.
                Hm...
                It's quite easy, Edson! See here:
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=20&t=756
                • EdsonE Offline
                  Edson
                  gotcha.
                  • TIGT Online
                    I wrote a random pushpull script ages ago - it's still available free on Didier's site and elsewhere...
                    IF you make the max. and min. variation in the 'range' then it push/pulls the selected faces by the same amount in one go...
                    Its function with a range and allowing random or stepped amounts of push/pulling gives similar results to the 'Grebble' script that's under discussion in other threads...
                      SchreiberBike
                      Jean (Johnny) Lemire,
                      You have a gift for making what seems impossible easy.
                      • bradB Offline
                        brad
                        Hi All,
                        You could also used the attached Ruby script.
                        Description:
                        Push pull faces along a vector given with 2 clicks, in any direction.
                        Instruction/Usage:
                        Install:Just drop it in Plugins folder.
                        Menu: Context
                        Hope that helps.
                        pushpull_tool.rb
                        Brad
                        SketchUp QA
                        • EdsonE Offline
                          Edson
                          thanks, brad. indeed, it allows one to push-pull in directions the straight tool will not allow. i played with it for a short while and came across some unexpected results, like being able to copy a face along one of its sides (see attached).
                          i wonder if anyone who has been using it for some time can tell us some practical ways to use it.
                          • FletchF Offline
                            Fletch
                            why not just use the "push/pull multiple faces" ruby for this? That's what I use 😉
                            Fletch
