    Push and pull tool
    19 Posts 12 Posters 4.7k Views 12 Watching
    • N
      not registered yet
      Hello,
      Quick question.
      I have created many line objects (outlines of buildings) using the line tool. I want to select all of them (roughly 100+) and use the push and pull them to 12' all at once. Is there a way to do this?
      Many thanks,
      (soccer)
        SchreiberBike
        If I understand your question, the answer is no. But to do what you seem to want, you could push/pull the first one 12', then double click on each of the others with the push/pull tool. That will extend each one the same amount as your last.
        A sample of what you are working on would make it easier to advise.
          Daniel S
          Hi soccer:
          Yes, it can be done.
          http://www.pixero.com/downloads_sketchup.html
          donwload JS Extrude.
          Daniel S
            sorgesu
            You could also select all the top surfaces that you would have wished to push pull up, use the MOVE tool instead of the push pull and tap the "up" arrow key which will lock all the movement to the z axis direction. MOVe Up 12'. all the attached geometry will follow as it does the push pull tool.
            Susan Sorger
            Former Seller Hand Rendered Entourage
            Former Canadian Authorized Training Centre, SketchUp
            • GaieusG
              Susan, this would only work if those "objects" he is mentioning would already have some thickness. If they are true "outlines" only (i.e. 2D faces), all of them would just be lifted into the air.
                sorgesu
                TRUE. WAS ASSUMING. silly.
                Susan Sorger
                • Jean LemireJ
                  Jean Lemire
                  I folks.
                  See attached SU file for ideas.
                  Pulling multiple shapes.skp
                  • Wo3DanW
                    Wo3Dan
                    @jean lemire said:
                    I folks.
                    Jean,
                    Once again you proved to obtain a solution with basic SU tools, great!!
                    We tend to forget the possibilities of more 'complex' ++ or +/- selections with Crtl and Shift.
                    Thanks for sharing.
                    (Wo3Dan)
                    • GaieusG
                      Very witty, Jean!
                      • EdsonE
                        Edson
                        this a great tut, jean. very useful indeed.
                        gai, we should move jean's tuts to the tutorials section, don't you think so?
                        http://www.mahfuz.arq.br
                        • GaieusG
                          I agree, Edson!
                          And don't forget that both you and Jean are mods who can easily do this!
                          • EdsonE
                            Edson
                            no, i do not forget that. i am just not sure how to do it.
                            • GaieusG
                              Hm...
                              It's quite easy, Edson! See here:
                              http://www.sketchucation.com/forums/scf/viewtopic.php?f=20&t=756
                              • EdsonE
                                Edson
                                gotcha.
                                  I wrote a random pushpull script ages ago - it's still available free on Didier's site and elsewhere...
                                  IF you make the max. and min. variation in the 'range' then it push/pulls the selected faces by the same amount in one go...
                                  Its function with a range and allowing random or stepped amounts of push/pulling gives similar results to the 'Grebble' script that's under discussion in other threads...
                                    SchreiberBike
                                    Jean (Johnny) Lemire,
                                    You have a gift for making what seems impossible easy.
                                    • bradB
                                      brad
                                      Hi All,
                                      You could also used the attached Ruby script.
                                      Description:
                                      Push pull faces along a vector given with 2 clicks, in any direction.
                                      Instruction/Usage:
                                      Install:Just drop it in Plugins folder.
                                      Menu: Context
                                      Hope that helps.
                                      pushpull_tool.rb
                                      Brad
                                      SketchUp QA
                                      • EdsonE
                                        Edson
                                        thanks, brad. indeed, it allows one to push-pull in directions the straight tool will not allow. i played with it for a short while and came across some unexpected results, like being able to copy a face along one of its sides (see attached).
                                        i wonder if anyone who has been using it for some time can tell us some practical ways to use it.
                                        • FletchF
                                          Fletch
                                          why not just use the "push/pull multiple faces" ruby for this? That's what I use 😉
                                          Fletch
