    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Tutorial > Modeling] Arch in a curved wall.
    32 Posts 14 Posters 11.2k Views 14 Watching
    • boofredlayB Offline
      boofredlay
      Here is a tut I created for modelling an arch in a curved wall.
      I have to do a number of these on a project next week (hopefully)
      and I wanted to see if I could do it. So here is my stab.
      I used an extreme example. The arches I will be doing will
      be a bit more subtle.
      http://www.sketchucation.com/forums/scf/sas/Tutorials/ArcToArch.jpg
      Download tutorial here.
        Nice one, Eric, really!
        A little different approach though but I also had to modell something with curved arches (please, don't look at the "non-arched" material of the arches now ๐Ÿ˜„ )
          boofredlay
          That's beautiful Gaieus.
            titmas
            Eric,
            That was easy, thanks.
            the only tedious step was to 'soften/smooth' the stitching, I had to right click each stitch, one at a time, and select 'soften'. is there easier/quicker way?
            http://www.sketchucation.com/forums/scf/sas/test/ArcToArch model.png
              Just simply use the Ctrl+Eraser tool to do a "smear" of softening edges on a surface by hand.
              (Plus make sure you have the same faces facing outside - in your pic there are front and back (white and blue) faces mixed).
                Well, James, that's another way of saying the same...
                ๐Ÿ˜ฎ
                  Oh, sorry James, I didn't mean to!
                  But at least Sean can make sure that the same info from two sources must work.
                  ๐Ÿ˜„
                    titmas
                    titmas, just hold down the ctl key while erasing. This will smooth the edges very quickly.
                    Oh wait... did someone already say that ๐Ÿ˜ฎ
                      thanks, that was helpful.
                      • Paul RussamP Offline
                        Paul Russam
                        We need an emote for 'bangs head of desk'
                        I never knew we could do this in SU, I've been selecting faces and picking soften/smooth edges from the context menu. ๐Ÿ˜ฎ
                        This is what I love about SU and here, always something new or a new way to do something.
                        Paul Russam
                        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                          Hehe...
                          I learn so many things every day... ๐Ÿ˜„
                          Additionally, the modification keys (in Win) for the Eraser tool:
                          Ctrl+Eraser = soften
                          Shift+Eraser = hide
                          You can soften a hidden line with this but cannot turn a softened line into hidden.
                          Ctrl+Shift+Eraser = unsoften / turn a softened line hidden (works only with hidden geometry on of course)
                          • N Offline
                            not registered yet
                            I seem to be having a problem with Step (Scene) 7.
                            I draw my arc then attempt to push/pull through the face but I am getting an "Offset limited to ~7 3/8" message.
                            Any suggestions?
                            Thanks much.
                            Marc
                            (Elmarq)
                              boofredlay
                              Welcome Marc.
                              Go ahead and push it to that offset limit. Then push it again and it should go through. If not, push it to that limit then hold ctl while pushing again, creating a copy. This should go through.
                              Let me know if it works.
                                Also, if you group either the curved face or the arch, it will not "report" this limit (in the latter case you need to edit it to be able to P/P). You can then explode the group and intersect.
                                • N Offline
                                  not registered yet
                                  Thanks for the tips! That did the trick.
                                  Marc
                                  (Elmarq)
                                    PKast
                                    There was a good tip recently that relates to this tutorial. By using the "from Countours" tool from the "sandbox group" you can quickly and automatically stitch the area at the bottom of the arch.
                                    Select the two arcs that define the curve, select the "from Contours" tool and the curves become stitched. Clean up the excess stitching, and finish by smoothing the surface.
                                      Katies29f
                                      I cannot download this tutorial the link is busted
                                        Yes we had some problem yesterday but it's fixed now.
                                          Julius
                                          very useful tutorial, but...how did you stitch together in scene 11?
                                          • zx10r_GazZ Offline
                                            zx10r_Gaz
                                            Any suggestions?
                                            Thanks much.
                                            Marc
                                            (Elmarq)
                                            Hello Marc,
                                            I think you will encounter this problem if you do not delete the "construction lines" from the arch to where you draw your arc. Delete these before you push/pull and it will work fine.
                                            Gaz...
