Rayscaper New Releases
I’ve just realized that it’s the material color that determines the color of the grass blades—much like in V-Ray—which is a really great feature.
However, the limit slider for the density parameter currently prevents this "grass material" from being effectively used as "fur." The density in "synthetic grass" mode is the highest (likely due to the shape of the blades).
Would it be possible to lift this density limit in the future, or perhaps create a "fur" preset that’s better suited for that purpose?
In any case, well done!
@krass - I'm not sure how it works in V-Ray, but in Rayscaper, the grass creates a scatter behind the scenes on the surface and then assigns UVs so your textures also work on the grass surface. We have some hard-coded grass patches in the software. The density limit is there for performance reasons; making it too dense could crash your GPU if it's not beefy enough, so there's a limit.
Way back, when I was a developer on the OctaneRender team, we implemented hair and fur using special hair "geometry," which is like tiny strings of geometry next to your normal triangles. I can also look at this method in Rayscaper. It's a bit of work, so I can't really promise this in the 1.0 release (which I wanna get out, because people think Rayscaper is crap because it's still in beta).
edit: I'll increase the density limit a bit in the next release anyway, then you are unblocked for creating carpets until we have something better.
Thanks, does it chage anything if I subdivide th rug face?
@pixelcruncher
Even in the beta phase, Rayscaper is still excellent, and the designers around me are looking forward to Rayscaper surpassing Thea Render in SketchUp -
lightscape said:
@pixelcruncher
Even in the beta phase, Rayscaper is still excellent, and the designers around me are looking forward to Rayscaper surpassing Thea Render in SketchUpI just completed a test scenario with a small resolution, and I used AI to remove the watermark (not for commercial use, just for the sake of visual appeal). Rayscaper's rendering capabilities are currently outstanding
@Krass No, it wouldn't really help. Rayscaper scatters the patches with the configured density over the faces. More faces means just more work for the scattering engine.
We did some experimenting this afternoon, and might have something better soon(-ish).
Stay tuned!
Cheers,
Thomas -
it's very good !
I believe you used synthetic grass with large blade size... -
when grass type changes to meadow there is a bug fix (crush) in sketchup 2025 , in sketchup 2026 is fine work
Using a texture as a scattering map—as well as deriving color from that texture—is a fantastic idea. However, I hope the issue regarding the inability to select a preset gets resolved; it’s a bug that causes a fatal error in SketchUp.
M majid referenced this topic
Hello,
Thomas
Could you share the Rayscaper rug model so I can understand how you made it? Is the logo an image, or was it drawn in SketchUp? -
@Alattab, yes, thanks for the report. We were able to reproduce this. We'll include a fix in the next version.
Cheers,
Thomas -
@Krass, I figured out how to hack the grass material to make rugs too. However, that required code changes in Rayscaper, so it will be available only in the new version. Stay tuned for this. I will share the skp file as well with the new version so you can have the same results.
Cheers,
Thomas -
I believe it is necessary to add a "mask map" alongside the alpha and opacity maps; otherwise, I cannot properly render the appearance of the fountain water—indicated by the number 1 in the image—as required. Furthermore, I think it is essential to include specific fluid presets—such as those for milk, carbonated water, aerated water, etc. In the image, the element marked with the number 2 represents the aerated water produced by a bubbler nozzle.
Interesting image. What software did you use to add the 1 and 2 highlights?
@ntxdave it is calld" Franzis cutout profistional "
@ntxdave if you mean number bubble tag , use softwear calld Ksnip it is freecharge , open source kind type
@Alattab, thanks for the clear example. You can render the spray (1) already today, without a separate mask map: the Opacity of a material takes any image and can read its brightness instead of its alpha, which is exactly what your black and white image is.
I tried it with your two images on a single upright face in a quick test scene:
Select the material of the jet in the material editor and set:
- Color: white, or a very light blue.
- Opacity: click the image icon, choose Image as the Texture Type and load the black and white image.
- Color Space: Linear.
- Channel: Luminance.
Black is then fully transparent, white is solid and the greys in between are partly see-through, so the soft edges of the spray stay soft. You don't need the colored PNG for this.
The fluid presets (milk, carbonated, and aerated water) are noted as a feature request. For the bubbler jets (2), the same trick with a picture of foamy water works best for now.
Cheers,
Thomas -
@pixelcruncher
With all due respect, Mr. Thomas, I appreciate your valuable efforts. I will keep you updated on any insights or feedback I come across as they arise. My only suggestion is to establish a set schedule for releasing new versions; this would allow us to thoroughly explore previous versions and, in turn, provide more comprehensive feedback. -
@Alattab, thanks for the feedback, but for now I'm not going on a fixed release cadence.
Rayscaper isn't my day job, so I have to make time to work on it. Last month was very productive because I could spend most days (and nights) developing, but that's not always a given. So I try to release as early as I can to get that valuable user feedback. I'm on a fast release cadence right now, but that's not always a given. I will always try to support customers as fast as I can, but regular development might take a backseat sometimes.
I'm also almost at the 1.0 stopping point. After that, I will take some time to develop the 2.0 features and build a solid beta set for the 2.0 release. Also, I've been working towards a 1.0 release for 3 years now (!!!), @rich-o-brien has been testing this monster since August 2023. I need to get something out.
Cheers,
Thomas
