Rayscaper New Releases
Using a texture as a scattering map—as well as deriving color from that texture—is a fantastic idea. However, I hope the issue regarding the inability to select a preset gets resolved; it’s a bug that causes a fatal error in SketchUp.
M majid referenced this topic
Hello,
Thomas
Could you share the Rayscaper rug model so I can understand how you made it? Is the logo an image, or was it drawn in SketchUp? -
@Alattab, yes, thanks for the report. We were able to reproduce this. We'll include a fix in the next version.
Cheers,
Thomas -
@Krass, I figured out how to hack the grass material to make rugs too. However, that required code changes in Rayscaper, so it will be available only in the new version. Stay tuned for this. I will share the skp file as well with the new version so you can have the same results.
Cheers,
Thomas -
I believe it is necessary to add a "mask map" alongside the alpha and opacity maps; otherwise, I cannot properly render the appearance of the fountain water—indicated by the number 1 in the image—as required. Furthermore, I think it is essential to include specific fluid presets—such as those for milk, carbonated water, aerated water, etc. In the image, the element marked with the number 2 represents the aerated water produced by a bubbler nozzle.
Interesting image. What software did you use to add the 1 and 2 highlights?
@ntxdave it is calld" Franzis cutout profistional "
@ntxdave if you mean number bubble tag , use softwear calld Ksnip it is freecharge , open source kind type
