    Rayscaper New Releases
    rayscaperrender
    785 Posts 14 Posters 363.4k Views 15 Watching
    • KrassK
      Krass
      Thanks,
      The translation is pretty good. I did consider switching it back to English, as technical terms and software-related language can often lead to misunderstandings, but I’ll leave it in French for now.
      I’ll keep an eye out and let you know if I spot any incorrect or ambiguous translations.
      Your grass material is truly excellent—it’s a significant milestone for this version. And the customizable shortcuts are a big deal for me, so I’m really happy about that. Well done!
      Krass
      KrassK 1 Reply Last reply ♥
      • KrassK
        Krass @Krass
        Rayscaper
        The grass settings are absolutely perfect. I'm now going to try to repurpose this function to generate carpets. The presets are good; the hue is very natural, whereas in many other programs you get an unrealistic, vivid green.
        Krass
        • KrassK
          Krass
          I’ve just realized that it’s the material color that determines the color of the grass blades—much like in V-Ray—which is a really great feature.
          However, the limit slider for the density parameter currently prevents this "grass material" from being effectively used as "fur." ​​The density in "synthetic grass" mode is the highest (likely due to the shape of the blades).
          Would it be possible to lift this density limit in the future, or perhaps create a "fur" preset that’s better suited for that purpose?
          In any case, well done!
          Krass
          • pixelcruncherP
            @krass - I'm not sure how it works in V-Ray, but in Rayscaper, the grass creates a scatter behind the scenes on the surface and then assigns UVs so your textures also work on the grass surface. We have some hard-coded grass patches in the software. The density limit is there for performance reasons; making it too dense could crash your GPU if it's not beefy enough, so there's a limit.
            Way back, when I was a developer on the OctaneRender team, we implemented hair and fur using special hair "geometry," which is like tiny strings of geometry next to your normal triangles. I can also look at this method in Rayscaper. It's a bit of work, so I can't really promise this in the 1.0 release (which I wanna get out, because people think Rayscaper is crap because it's still in beta).
            edit: I'll increase the density limit a bit in the next release anyway, then you are unblocked for creating carpets until we have something better.
            L 1 Reply Last reply
            • KrassK
              Krass
              Thanks, does it chage anything if I subdivide th rug face?
              Krass
              • L
                lightscape Newcomers @pixelcruncher
                @pixelcruncher
                Even in the beta phase, Rayscaper is still excellent, and the designers around me are looking forward to Rayscaper surpassing Thea Render in SketchUp
                Reply Quote 2
                • L
                  lightscape Newcomers @lightscape
                  lightscape said:
                  @pixelcruncher
                  I just completed a test scenario with a small resolution, and I used AI to remove the watermark (not for commercial use, just for the sake of visual appeal). Rayscaper's rendering capabilities are currently outstanding72eec337-7b22-4b78-978c-6c1f15f5a54a.png
                  Reply Quote 3
                  • pixelcruncherP
                    @Krass No, it wouldn't really help. Rayscaper scatters the patches with the configured density over the faces. More faces means just more work for the scattering engine.
                    We did some experimenting this afternoon, and might have something better soon(-ish).
                    Stay tuned!
                    Cheers,
                    Thomas
                    Reply Quote 2
                    • KrassK
                      Krass
                      it's very good !
                      I believe you used synthetic grass with large blade size...
                      Krass
                      Reply Quote 2
                        Alattab
                        when grass type changes to meadow there is a bug fix (crush) in sketchup 2025 , in sketchup 2026 is fine work
                          Alattab
                          Using a texture as a scattering map—as well as deriving color from that texture—is a fantastic idea. However, I hope the issue regarding the inability to select a preset gets resolved; it’s a bug that causes a fatal error in SketchUp.
                          • majidM majid referenced this topic
                          • KrassK
                            Krass
                            Hello,
                            Thomas
                            Could you share the Rayscaper rug model so I can understand how you made it? Is the logo an image, or was it drawn in SketchUp?
                            Krass
                            • pixelcruncherP
                              pixelcruncher Extension Creator @Alattab
                              @Alattab, yes, thanks for the report. We were able to reproduce this. We'll include a fix in the next version.
                              Cheers,
                              Thomas
                              1 Reply Last reply 😊
                              • pixelcruncherP
                                @Krass, I figured out how to hack the grass material to make rugs too. However, that required code changes in Rayscaper, so it will be available only in the new version. Stay tuned for this. I will share the skp file as well with the new version so you can have the same results.
                                Cheers,
                                Thomas
                                  Alattab
                                  I believe it is necessary to add a "mask map" alongside the alpha and opacity maps; otherwise, I cannot properly render the appearance of the fountain water—indicated by the number 1 in the image—as required. Furthermore, I think it is essential to include specific fluid presets—such as those for milk, carbonated water, aerated water, etc. In the image, the element marked with the number 2 represents the aerated water produced by a bubbler nozzle.
                                  A 1 Reply Last reply
                                  • ntxdaveN
                                    ntxdave
                                    Interesting image. What software did you use to add the 1 and 2 highlights?
                                    Press F1...thank me later
                                    A 2 Replies Last reply
                                      Alattab
                                        Alattab @ntxdave
                                        @ntxdave it is calld" Franzis cutout profistional "
                                          Alattab @ntxdave
                                          @ntxdave if you mean number bubble tag , use softwear calld Ksnip it is freecharge , open source kind type
                                          • pixelcruncherP
                                            @Alattab, thanks for the clear example. You can render the spray (1) already today, without a separate mask map: the Opacity of a material takes any image and can read its brightness instead of its alpha, which is exactly what your black and white image is.
                                            I tried it with your two images on a single upright face in a quick test scene:
                                            Select the material of the jet in the material editor and set:
                                            1. Color: white, or a very light blue.
                                            2. Opacity: click the image icon, choose Image as the Texture Type and load the black and white image.
                                            3. Color Space: Linear.
                                            4. Channel: Luminance.
                                            Black is then fully transparent, white is solid and the greys in between are partly see-through, so the soft edges of the spray stay soft. You don't need the colored PNG for this.
                                            The fluid presets (milk, carbonated, and aerated water) are noted as a feature request. For the bubbler jets (2), the same trick with a picture of foamy water works best for now.
                                            Cheers,
                                            Thomas
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 39
                                            • 40
                                            • 33 / 40
