[Plugin Library] LibFredo6 - v16.4a - 11 Nov 26
Somethings is wrong is the installation of Sketchucation Tools.
Could you- go to the Plugin directory: c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins
- Delete the folder Sketchucation
- Reinstall Sketchucation tools from the Sketchucation site
Please advise if this does not work.
Thanks, it's working now.
First, I deleted it, then I modified the signature authorisation in the warehouse extension. It was a signature issue.
In SketchUp:
Extensions → Extension Manager
Click the
️ Extension Manager Settings icon.
You'll find “Extension Loading Policy” / “Extension Loading Preferences.”
Select:
“Approve Unidentified Extensions”
Restart SketchUp. -
Bonjour
Avec la version 16.3b la fenêtre traduction n'apparait plus sur tout les plugins frtedo6 -
@ID3D
which plugins for instance? -
@fredo6 please find attached.
Fredo6 Plugins Information on 2026-11-06 09:14:12 +0100- Platform: x64-mingw32 - Ruby: 2.2.4
- Sketchup: 17.2.2555
- LibFredo6: v16.1g
- LibFredo6 G6 Binary loaded
- LibFredo6 E6 Binary NOT loaded
- Sketchucation Tools: 5.0.8
- SCFLicense: v7.5a - 80
- Fredo6 Plugins
Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
FredoScale v3.7c
JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
RoundCorner v3.4a - licensed FULL: 263401 - HE1772082497.0K - SCFLicense directory present
Signature File: 2026-02-26 06:08:17 +0100
Curviloft: 2026-02-26 06:08:26 +0100
JointPushPull: 2026-02-26 10:15:01 +0100
RoundCorner: 2026-03-02 12:08:45 +0100
Hi, everyone. Running SU2027 on Mac. Have LibFredo6 installed. Installed several tools, including Curviloft. The menu bars appear, with clickable icons, but nothing happens when I click them.
I have restarted, rebooted, uninstalled, reinstalled, installed LibFredo6 first, checked for updates, etc. None of that makes any difference.
Any idea why? Thanks!
Hi, all. I'm running SU2027. I have LibFredo6 installed. I had several Fredo extensions installed, but have backed it off just to Curviloft as I troubleshoot.
The toolbars are present, buttons are there, but when pressed they do nothing. I have uninstalled, reinstalled, rebooted, etc., and none of that has changed anything.
Any ideas? Thanks.
Could you open the Ruby console before launching a plugin. If there are error showing up, copy and paste the text here.
Hi, Fredo.
Never mind! I found the problem. I just reinstalled Sketchucation Tools and voilà, everything came to life. Sorry about that!
NEW RELEASE: LibFredo6 v16.4a - 11 Nov 26
LibFredo6 16.4a is a maintenance release. It includes changes related to:
- Compatibility SU2027
- Technical adjustments
- Bug Fixing
If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.2a. Otherwise, LOTT will not be activated
Hello! @fredo6 I’d like to know if there will be a bundle for the 2027 version soon. Thxx
Hi Fredo, hi everyone,
I have just installed SketchUp 2027 and I am unable to get LibFredo6 or any of the FredoBundle plugins to work.
I downloaded and installed the latest version of LibFredo6 (v16.4a) together with the latest versions of the FredoBundle plugins. The plugins are installed, the toolbars appear, but none of the tools work.
In SketchUp's Extension Manager, LibFredo6 appears with:
- Version: 1.0
- Author: (blank)
- Description: (blank)
I also get the following error:
NameError (uninitialized constant E6B)For comparison, I am running the same plugins on SketchUp 2026 without any issues.
Has anyone experienced the same problem with SketchUp 2027?
Extension Errors Report SketchUp: 27.0.267 OS: Windows 11 Ruby: 3.4.9 Extension: Fredo6 LibFredo6 (1.0) Error: NameError (uninitialized constant E6B) C:/Users/user/AppData/Local/Temp/Fredo6__loader_top_1794588161.rb:1:in '<top (required)>' C:/Program Files/SketchUp/SketchUp 2027/SketchUp/Tools/extensions.rb:209:in 'Sketchup.require' C:/Program Files/SketchUp/SketchUp 2027/SketchUp/Tools/extensions.rb:209:in 'SketchupExtension#load' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:153:in 'Sketchup.register_extension' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:153:in 'LibFredo6_Loader.process' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:164:in 'module:LibFredo6_Loader' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in '<top (required)>'Any help would be greatly appreciated.
Thank you!
It might be a problem of installation where the main file Fredo6_!LibFredo6.rb has not been replaced. I don't know how you installed it.
Could you go to the plugin directory, and erase:
- Fredo6_!LibFredo6.rb file
- Fredo6_!LibFredo6 subfolder
And then reinstall LibFredo6.
Hi @fredo6,
Thank you very much for your reply.
I installed the plugins through SU's Extension Manager.
I deleted the file and folder you mentioned, and that partially solved the problem. I was able to install LibFredo and the other plugins, and they now show up correctly. The tools are listed, and the correct versions are displayed in the Extension Manager.
The problem is that none of them actually work. I've tried JointPushPull, RoundCorner and FredoScale, but when I select any of the tools, they don't work. I've tried launching them both from the toolbars and from the Tools > Fredo Collection menu, but nothing happens.
I can't even open the License option to load my license.
Do you have any idea what might be causing this?
Thanks again for your help!
Why didn't you install LibFredo6 and the other extensions with the Sketchucation Tool? You have to have the current version of the tool installed to manage the licenses for Fredo's extensions.
What version of LibFredo6? What are the version numbers of Joint P/P, RoundCorner, and FredoScale?
What version of SketchUp are you using? On what operating system?
Hi @Dave-R,
Thanks for your reply.
I've always installed the plugins through the Extension Manager and never had any issues until I upgraded to SU 2027. In fact, as I mentioned in my original post, the plugins work perfectly fine in SU 2026. In any case, if you think that might be the cause, I'll give it a try.
As for the extension versions, I'm using the latest ones available in the Plugin Store. I downloaded them again a couple of days ago:
- LibFredo_v16.4a
- RoundCorner_v3.4a
- FredoScale_v3.7c
- JointPushPull_v4.9a
Windows and SketchUp versions are included in my original post, but I'll list them again here:
SketchUp: 27.0.267
OS: Windows 11Thanks for your time.
Hi again @Dave-R ,
I’ve just uninstalled everything and reinstalled it using the SketchUcation ExtensionStore, but the result is exactly the same. All the tools show up, but none of them work.
It is important to know what you mean by 'none of them work'. Do you get a message?
Can you open the Ruby console before launching the tool.
Could you also copy/paste the output when you invoke the meny Window > LibFredo6 Settings... > Fredo6 Plugins Information for Sketchucation Support.
Also, make ure you installed the latest version of the Sketchucation Tools.
SketchUp 2026 / Windows 11
LibFredo6 version 16.4a
Windows Code Integrity Event ID: 3077
Blocked component: SU26-0/E6B.so
Windows Smart App Control: ON
Request: A trusted, properly signed version of the E6B component compatible with Windows Smart App Control.
