    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.3m Views 594 Watching
      As Dave says, your posts in the LibFredo6 thread says nothing about that ?
      It does nothing on its own, but supports most of Fredo6's extensions.
      If you are having problems with one of his extensions please post in its thread, and explain what the problem is with at least some clues so we can try and help you.
      Also - as Dave points out - you have your active Tag [previously called 'layers'] set up wrongly - named 'Etiquetas' in your language. All geometry -i.e. edges and faces - should be made/associated with 'Untagged' - i.e. 'Sin etiqueta' - you can then assign different Tags to selected groups and component-instances, using the Entity Info panel ['Información de la entidad'] - later it can be used to control their visibility whilst modelling and editing...
        jesuscarrazoni Newcomers
        Hello Fredo6,
        I am using SketchUp 2026 on macOS with TopoShaper 2.7b and LibFredo6 15.9c.
        TopoShaper fails when analysing the initial selection. The Ruby Console reports:
        NameError: undefined local variable or method 'accept_current_selection'
        I tried to download LibFredo6 16.3b from the official SketchUcation page, but the download reports a database connection error. The file page also shows a size of 0.00 MB, and clicking Download leads to a “File does not exist” message for LibFredo6.rbz.
        Could you please check the download link and advise whether LibFredo6 16.3b fixes this selection error on SketchUp 2026 for Mac?
        Thank you.
          Hello Fredo6,
          Thank you.
          • G
            goyatea Newcomers
            The installation did not work for me. I received an error message when I tried to use the add command. Any ideas?
              Rich O Brien Moderator @goyatea
              Please share the error message, your SketchUp version and Operating System
              • G
                goyatea Newcomers
                Ruby error message :
                Fredo6 Plugins Information on 2026-10-27 12:42:22 +0100
                • Sketchup: 25.0.571
                • LibFredo6: v16.3b
                • LibFredo6 E6 Binary loaded
                • LibFredo6 W6 Binary loaded
                • LibFredo6 H6 Binary loaded
                • Sketchucation Tools: 5.0.8
                  #<NoMethodError: undefined method call' for nil:NilClass> c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:190:in SHGetFolderPathW'
                  c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:134:in get_system_dir' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:102:in get_localappdata_dir'
                  c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:340:in transfer_to_public' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:380:in initialize'
                  c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:in new' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:in dynamic_token'
                  C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rb6:860:in info' C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb6:382:in block in populate_support_menu'
                  C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb6:1573:in `block in add_command'
                • G
                  goyatea Newcomers
                  • fredo6F
                    Somethings is wrong is the installation of Sketchucation Tools.
                    Could you
                    1. go to the Plugin directory: c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins
                    2. Delete the folder Sketchucation
                    3. Reinstall Sketchucation tools from the Sketchucation site
                    Please advise if this does not work.
                    • G
                      goyatea Newcomers
                      Thanks, it's working now.
                      First, I deleted it, then I modified the signature authorisation in the warehouse extension. It was a signature issue.
                      In SketchUp:
                      Extensions → Extension Manager
                      Click the ⚙️ Extension Manager Settings icon.
                      You'll find “Extension Loading Policy” / “Extension Loading Preferences.”
                      Select:
                      “Approve Unidentified Extensions”
                      Restart SketchUp.
                      • I
                        ID3D
                        Bonjour
                        Avec la version 16.3b la fenêtre traduction n'apparait plus sur tout les plugins frtedo6
                        fredo6F 1 Reply Last reply
                        • fredo6F
                          fredo6 @ID3D
                          @ID3D
                          which plugins for instance?
                          • 112
                          • 113
                          • 114
                          • 115
                          • 116
                          • 116 / 116
