[Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
The installation did not work for me. I received an error message when I tried to use the add command. Any ideas?
Ruby error message :
Fredo6 Plugins Information on 2026-10-27 12:42:22 +0100
- Platform: x64-mswin64_140 - Ruby: 3.2.2
- Sketchup: 25.0.571
- LibFredo6: v16.3b
- LibFredo6 E6 Binary loaded
- LibFredo6 W6 Binary loaded
- LibFredo6 H6 Binary loaded
- Sketchucation Tools: 5.0.8
#<NoMethodError: undefined methodcall' for nil:NilClass> c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:190:inSHGetFolderPathW'
c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:134:inget_system_dir' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense.rbe:102:inget_localappdata_dir'
c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:340:intransfer_to_public' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:380:ininitialize'
c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:innew' c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:indynamic_token'
C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rb6:860:ininfo' C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb6:382:inblock in populate_support_menu'
C:/Users/legai/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb6:1573:in `block in add_command'
Somethings is wrong is the installation of Sketchucation Tools.
Could you- go to the Plugin directory: c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins
- Delete the folder Sketchucation
- Reinstall Sketchucation tools from the Sketchucation site
Please advise if this does not work.
Thanks, it's working now.
First, I deleted it, then I modified the signature authorisation in the warehouse extension. It was a signature issue.
In SketchUp:
Extensions → Extension Manager
Click the
️ Extension Manager Settings icon.
You'll find “Extension Loading Policy” / “Extension Loading Preferences.”
Select:
“Approve Unidentified Extensions”
Restart SketchUp. -
Bonjour
Avec la version 16.3b la fenĂŞtre traduction n'apparait plus sur tout les plugins frtedo6 -
@ID3D
which plugins for instance? -
@fredo6 please find attached.
Fredo6 Plugins Information on 2026-11-06 09:14:12 +0100- Platform: x64-mingw32 - Ruby: 2.2.4
- Sketchup: 17.2.2555
- LibFredo6: v16.1g
- LibFredo6 G6 Binary loaded
- LibFredo6 E6 Binary NOT loaded
- SCFLicense: v7.5a - 80
- Fredo6 Plugins
Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
FredoScale v3.7c
JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
RoundCorner v3.4a - licensed FULL: 263401 - HE1772082497.0K - SCFLicense directory present
Signature File: 2026-02-26 06:08:17 +0100
Curviloft: 2026-02-26 06:08:26 +0100
JointPushPull: 2026-02-26 10:15:01 +0100
RoundCorner: 2026-03-02 12:08:45 +0100
Hi, everyone. Running SU2027 on Mac. Have LibFredo6 installed. Installed several tools, including Curviloft. The menu bars appear, with clickable icons, but nothing happens when I click them.
I have restarted, rebooted, uninstalled, reinstalled, installed LibFredo6 first, checked for updates, etc. None of that makes any difference.
Any idea why? Thanks!
Hi, all. I'm running SU2027. I have LibFredo6 installed. I had several Fredo extensions installed, but have backed it off just to Curviloft as I troubleshoot.
The toolbars are present, buttons are there, but when pressed they do nothing. I have uninstalled, reinstalled, rebooted, etc., and none of that has changed anything.
Any ideas? Thanks.
Could you open the Ruby console before launching a plugin. If there are error showing up, copy and paste the text here.
Hi, Fredo.
Never mind! I found the problem. I just reinstalled Sketchucation Tools and voilĂ , everything came to life. Sorry about that!
