    [Plugin] FredoBend - v1..2c - 25 Mar 26
    45 Posts 10 Posters 603 Views 10 Watching
    • fredo6F Offline
      fredo6 @alexpacio2013
      @alexpacio2013 said:
      mx_constructtools
      It looks like the plugin mx_constructtools is redefining a base method (Array#sum), which is not a good practice and is dangerous for other plugins. This is causing the error.
      • fredo6F Offline
        fredo6 @rv1974
        @rv1974 said:
        Looks great Fredo. This is destructive one, isn't it? No way to edit afterwards
        The bent object is of course new geometry.
        However, as shown in the main video:
        • the original object is untouched
        • If you modify this original object, you can update the bent object in one click.
        • you can also edit the bent object and change the bending parameters. If the original object has been modified, the new bent object will be updated.
        • there is an option to save a copy of the original object to an external file. This is for the case where you delete the original object in the model, including its definition.
        • chonC Offline
          chon
          Hi all,
          running FredoBend v1.2b with LibFredo v15.9a on SU 2019 / Win11 and i've got an issue on the bend generation step with this error log :
          "Date: 27-Mar-26 09:24:41 - SU2019.3 - LibFredo6 - v15.9a
          Une erreur s'est produite dans
          Error in Bend Generation
          undefined method `save_copy' for #<Sketchup::ComponentDefinition:0x0000023c3844c1d8>
          fredobendcurvetool.rbe: 1195 -- saver_solid_comp
          fredobendcurvetool.rbe: 2425 -- generation_step_prepare
          fredobendcurvetool.rbe: 3270 -- job_perform
          fredobendcurvetool.rbe: 3212 -- job_notification
          body_lib6webprogress.rbe: 104 -- call
          body_lib6webprogress.rbe: 104 -- process_notify
          body_lib6webprogress.rbe: 388 -- fast_process_next_step
          body_lib6webprogress.rbe: 358 -- fast_process_start
          body_lib6webprogress.rbe: 370 -- fast_process_next
          body_lib6webprogress.rbe: 346 -- fast_process_top
          body_lib6webprogress.rbe: 123 -- invoke
          fredobendcurvetool.rbe: 3158 -- job_start
          fredobendcurvetool.rbe: 2392 -- block in generation_launch"
          In the Parameters window / Generation parameters, i don't see the build options as shown in the tuto :
          Is that the problem ?
          Thanks for response
          • fredo6F Offline
            NEW RELEASE: FredoBend v1.2c - 27 Mar 26
            Requirements
            • LibFredo6: v15.9a or above
            FredoBend 1.2c is a maintenance release including:
            • Bug fixing
            • Evolution of the Save Original objects with 3 options and the capability to retrive the original object, even if it is not present in the model any longer.
            Home Page of FredoBend for information and Download.
            Main post of this FredoBend thread.
            Spirou4DS 1 Reply Last reply Reply Quote 1
            • Spirou4DS Offline
              Spirou4D @fredo6
              @fredo6
              I just installed FredoBend v1.2c + LibFredo6 15.9a - 25 Mar 26 on my SketchUp Make 2017 v 17.2.2555 64bits .
              I have the tools but after I choose my Text object and place to the courve....NOTHING !
              Impossible to place on the curve ???
              Traceback Rubby:
              c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1656:in `placement_manage'
              c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1618:in `placement_dragging_move'
              c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:421:in `onMouseMove'
              Error: #<NoMethodError: undefined method `sum' for #<Array:0x0002627992fa30>>
              • Spirou4DS Offline
                Spirou4D
                Hi @fredo6
                I just ended the french translation of the LibFredo6 15.9a messages.
                And FredoBend v1.2c too.
                How to send you the result "LibFredo6_FR.lang" + "FredoBend_FR.lang" please?
                fredo6F 1 Reply Last reply Reply Quote 0
                • fredo6F Offline
                  NEW RELEASE: FredoBend v1.2d - 28 Mar 26
                  Requirements
                  FredoBend 1.2d is a maintenance release including:
                  • Bug fixing for SU2017
                  • fredo6F Offline
                    fredo6 @Spirou4D
                    Many thanks. I am lazy to do it.
                    Just PM the .lang files to me on this forum.
                    For LibFredo6, this is useful.
                    For FredoBend, I did not make it translatable yet, until I finish the other features. So, the translation is uncomplete.
                    • Spirou4DS Offline
                      Spirou4D
                      This post is deleted!
                      • Spirou4DS Offline
                        Spirou4D
                        • Spirou4DS Offline
                          Spirou4D
                          • Spirou4DS Offline
                            Spirou4D
                            But made here :
                            • Spirou4DS Offline
                              Spirou4D
                              Top-notch @fredo6 the addon run very well now! Thks a lot and congrats.
                              • 3 / 3
